I warry wander this fact.
I have migrated my project from SDK5 to ZEPHYR (nrf connect). Two devices - Central and Peripheral - Long range coded_phy.
I used next samples <peripheral_hr_coded> & <central_hr_coded> for coded_phy implementation and <shell_bt_nus> & <central_uart> for NUS implementation.
So, when I include coded_phy part of samples to NUS samples - Peripheral and Central did not see each other, but SDK5 version of Peripheral connected to Zephyr Central
And Zephyr Peripheral connect to SDK5 Central.
So I dont understand, why Zephyr Perihperal dont connect (even dont see) to Zephyr Central???
#PERIPHERAL CONFIG_NCS_SAMPLES_DEFAULTS=n CONFIG_HEAP_MEM_POOL_SIZE=2048 CONFIG_MAIN_STACK_SIZE=2048 CONFIG_BT=y CONFIG_BT_SMP=n CONFIG_BT_PERIPHERAL=y CONFIG_BT_DEVICE_NAME="BT_NUS_shell" CONFIG_BT_DEVICE_APPEARANCE=833 CONFIG_BT_MAX_CONN=2 #CONFIG_BT_MAX_PAIRED=2 CONFIG_BT_CTLR_PHY_CODED=y CONFIG_BT_EXT_ADV=y CONFIG_BT_USER_PHY_UPDATE=y # Enable the BT NUS CONFIG_SHELL_BT_NUS=y CONFIG_SHELL_BT_NUS_LOG_LEVEL_DBG=y # Config logger CONFIG_LOG=y CONFIG_LOG_MINIMAL=n CONFIG_USE_SEGGER_RTT=y CONFIG_LOG_BACKEND_RTT=y CONFIG_LOG_BACKEND_UART=n CONFIG_LOG_DEFAULT_LEVEL=3 CONFIG_BT_CTLR_TX_PWR_PLUS_8=y #CONFIG_BT_CTLR_TX_PWR_MINUS_40=y CONFIG_BT_CTLR=y CONFIG_BT_HCI=y CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=n CONFIG_BT_CTLR_ADVANCED_FEATURES=y CONFIG_BT_CTLR_CONN_RSSI=y CONFIG_BT_LL_SW_SPLIT=y CONFIG_BT_CTLR_ADV_EXT=y CONFIG_BT_CTLR_ADV_PERIODIC=y #CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=768 CONFIG_BOARD_ENABLE_DCDC=n CONFIG_UART_NRFX=n CONFIG_SERIAL=n CONFIG_UART_CONSOLE=n #DFU #CONFIG_MCUMGR_CMD_OS_MGMT=y #CONFIG_MCUMGR_CMD_IMG_MGMT=y #CONFIG_MCUMGR_SMP_BT=y #CONFIG_MCUMGR=y #CONFIG_BOOTLOADER_MCUBOOT=y #CONFIG_ROM_START_OFFSET=0xC200 CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24 CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40 CONFIG_BT_PERIPHERAL_PREF_SLAVE_LATENCY=0 CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42 CONFIG_BT_CTLR_DATA_LENGTH_MAX=251 CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=251 CONFIG_GPIO=y CONFIG_CONSOLE=n CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_MPU_ALLOW_FLASH_WRITE=y
#CENTRAL # Enable the UART driver CONFIG_UART_ASYNC_API=y CONFIG_NRFX_UARTE0=y CONFIG_SERIAL=y CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y # Enable the BLE stack with GATT Client configuration CONFIG_BT=y CONFIG_BT_CENTRAL=y #CONFIG_BT_SMP=y CONFIG_BT_GATT_CLIENT=y # Enable the BLE modules from NCS CONFIG_BT_NUS_CLIENT=y CONFIG_BT_SCAN=y CONFIG_BT_SCAN_FILTER_ENABLE=y CONFIG_BT_SCAN_UUID_CNT=1 CONFIG_BT_GATT_DM=y CONFIG_HEAP_MEM_POOL_SIZE=2048 # This example requires more workqueue stack CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 # Enable bonding CONFIG_BT_SETTINGS=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_SETTINGS=y # Config logger CONFIG_LOG=y CONFIG_USE_SEGGER_RTT=y CONFIG_LOG_BACKEND_RTT=y CONFIG_LOG_BACKEND_UART=y CONFIG_ASSERT=y CONFIG_BT_CTLR_PHY_CODED=y CONFIG_BT_CTLR_ADV_EXT=y CONFIG_BT_EXT_ADV=y CONFIG_BT_USER_PHY_UPDATE=y CONFIG_BT_CTLR_SYNC_PERIODIC=y CONFIG_BT_CTLR_TX_PWR_PLUS_8=y CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=3000 CONFIG_BT_BACKGROUND_SCAN_INTERVAL=100 CONFIG_BT_BACKGROUND_SCAN_WINDOW=80 CONFIG_BT_CREATE_CONN_TIMEOUT=3 CONFIG_BT_MAX_CONN=16 CONFIG_BT_CTLR_DATA_LENGTH_MAX=247 CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=247 #CONFIG_BT_LL_SW_SPLIT=y
I have changed everything.... Zero effect
Help me please! I dont have a time((((
