Hi, I am in need of some guidance.
The overall goal is to set up MQTT/TLS communication from end devices in a thread network, via a border router to the AWS cloud.
I have my nrf52840DK up and running in the thread network, it has got a IPv6 address from the border router (a KiBRA KTBRN1) via DHCPv6 and I am able to ping in both directions.
My problem is that the TCP connection is not setup correctly and I suspect that I have missed something in the configuration.
on my dev pc:
ubuntu:~$ ifconfig | grep inet
inet 192.168.1.49 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fd47:d3c:923f:0:20c:29ff:fe88:7ce1 prefixlen 64 scopeid 0x0<global>
ubuntu:~$ ping -6 -c2 fd7e:b200:ced:0:0:0:a2e:24
PING fd7e:b200:ced:0:0:0:a2e:24(fd7e:b200:ced::a2e:24) 56 data bytes
64 bytes from fd7e:b200:ced::a2e:24: icmp_seq=1 ttl=63 time=42.5 ms
64 bytes from fd7e:b200:ced::a2e:24: icmp_seq=2 ttl=63 time=39.0 ms
--- fd7e:b200:ced:0:0:0:a2e:24 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1002ms
rtt min/avg/max/mdev = 39.054/40.793/42.532/1.739 ms
ubuntu:~$ nc -l 1234
Then on the thread device:
uart:~$ ot ipaddr
fdd9:20b7:f073:0:0:ff:fe00:1800
fdd9:20b7:f073:0:597f:71e6:d5f5:3775
fe80:0:0:0:b849:ed15:1dba:12ab
Done
uart:~$ ot ping 64:ff9b::c0a8:131
Done
16 bytes from 64:ff9b:0:0:0:0:c0a8:131: icmp_seq=1 hlim=63 time=57ms
uart:~$ ot ping fd47:d3c:923f:0:20c:29ff:fe88:7ce1
Done
16 bytes from fd47:d3c:923f:0:20c:29ff:fe88:7ce1: icmp_seq=2 hlim=63 time=58ms
uart:~$
uart:~$ net ping 64:ff9b::c0a8:131
PING 64:ff9b::c0a8:131
8 bytes from 64:ff9b::c0a8:131 to fd7e:b200:ced::a2e:24: icmp_seq=0 ttl=63 rssi=0 time=88.50 ms
8 bytes from 64:ff9b::c0a8:131 to fd7e:b200:ced::a2e:24: icmp_seq=1 ttl=63 rssi=0 time=87.65 ms
8 bytes from 64:ff9b::c0a8:131 to fd7e:b200:ced::a2e:24: icmp_seq=2 ttl=63 rssi=0 time=87.40 ms
uart:~$ net ping fd47:d3c:923f:0:20c:29ff:fe88:7ce1
PING fd47:d3c:923f:0:20c:29ff:fe88:7ce1
8 bytes from fd47:d3c:923f:0:20c:29ff:fe88:7ce1 to fd7e:b200:ced::a2e:24: icmp_seq=0 ttl=63 rssi=0 time=88.17 ms
8 bytes from fd47:d3c:923f:0:20c:29ff:fe88:7ce1 to fd7e:b200:ced::a2e:24: icmp_seq=1 ttl=63 rssi=0 time=114.07 ms
8 bytes from fd47:d3c:923f:0:20c:29ff:fe88:7ce1 to fd7e:b200:ced::a2e:24: icmp_seq=2 ttl=63 rssi=0 time=88.01 ms
So far it looks good, but when I try to open a tcp connection it fails.
uart:~$ net tcp connect fd47:d3c:923f:0:20c:29ff:fe88:7ce1 1234
Connecting from [fd7e:b200:ced::a2e:24]:0 to [fd47:d3c:923f:0:20c:29ff:fe88:7ce1]:1234
uart:~$
Here is the debuglog:
D: (shell_uart): conn: 0x2001b780, ref_count: 1
D: (shell_uart): Context 0x2000c3e0 binding to TCP [fd7e:b200:ced::a2e:24]:35896 iface 0x200008e4
D: (shell_uart): context: 0x2000c3e0, local: fd7e:b200:ced::a2e:24, remote: fd47:d3c:923f:0:20c:29ff:fe88:7ce1
D: (shell_uart): conn: 0x2001b780 src: fd7e:b200:ced::a2e:24, dst: fd47:d3c:923f:0:20c:29ff:fe88:7ce1
D: (shell_uart): [0x2000c8d8/6/2/0x7f] remote fd47:d3c:923f:0:20c:29ff:fe88:7ce1/1234
D: (shell_uart): local fd7e:b200:ced::a2e:24/35896 cb 0x19ea9 ud 0x2000c3e0
D: (shell_uart): [LISTEN Seq=3781784924 Ack=0]
D: (shell_uart): On iface 0x200008e4 size 20
D: (shell_uart): HDRs length estimation 68
D: (shell_uart): Data allocation maximum size 88 (requested 20)
D: (shell_uart): TDATA (?) [0] frag 0x20019d58 ref 1 (tcp_out_ext():776)
D: (shell_uart): pkt 0x20018ad0 data 0x20019fc0 length 40
D: (shell_uart): pkt 0x20018ad0 skip 40
D: (shell_uart): pkt 0x20018ad0 data 0x20019fe8 length 20
D: (shell_uart): pkt 0x20018ad0 skip 20
D: (shell_uart): pkt 0x20018ad0 skip 8
D: (shell_uart): pkt 0x20018ad0 skip 32
D: (shell_uart): SYN Seq=3781784924 Len=0
D: (shell_uart): On iface 0x200008e4 size 60
D: (shell_uart): Data allocation maximum size 60 (requested 60)
D: (shell_uart): TDATA (?) [0] frag 0x20019d70 ref 1 (net_pkt_clone():1765)
D: (shell_uart): pkt 0x20018a80 skip 40
D: (shell_uart): Cloned 0x20018ad0 to 0x20018a80
D: (shell_uart): TX [12] pkt 0x20018a80 ref 2 (tcp_send():284)
D: (tx_q[0]): Processing (pkt 0x20018a80, prio 1) network packet iface 0x200008e4/1
D: (openthread): TX [12] pkt 0x20018a80 ref 1 frags 0x20019d70 (openthread_handle_frame_to_send():362)
D: (shell_uart): TX [12] pkt 0x20018a80 ref 0 frags 0x20019d70 (tcp_send():325)
D: (shell_uart): TDATA (?) [0] frag 0x20019d70 ref 0 frags (nil) (tcp_send():325)
D: (shell_uartD: (ot_radio_workq): On iface 0x200008e4 size 3
D: (ot_radio_workq): Data allocation maximum size 3 (requested 3)
D: (ot_radio_workq): TDATA (?) [0] frag 0x20019d88 ref 1 (handle_ack():384)
D: (ot_radio_workq): pkt 0x20018a30 data 0x2001088d length 3
D: (ot_radio_workq): pkt 0x20018a30 data 0x2000cbe4 length 3
D: (ot_radio_workq): TX [11] pkt 0x20018a30 ref 0 frags 0x20019d88 (handle_ack():412)
D: (ot_radio_workq): TDATA (?) [0] frag 0x20019d88 ref 0 frags (nil) (handle_ack():412)
D: (ot_radio_workq): TDATA (?) [0] frag 0x20019d88 ref 0 (net_pkt_unref_debug():586)
): TDATA (?) [0] frag 0x20019d70 ref 0 (net_pkt_unref_debug():586)
D: (shell_uart): LISTEN->SYN_SENT
D: (shell_uart): conn: 0x2001b780, ref_count=1
D: (shell_uart): Connection handler 0x2000c8d8 removed
D: (shell_uart): context: 0x2000c3e0, conn: (nil)
D: (shell_uart): Context 0x2000c3e0 released
D: (shell_uart): TX [13] pkt 0x20018ad0 ref 0 frags 0x20019d58 (tcp_send_queue_flush():336)
D: (shell_uart): TDATA (?) [0] frag 0x20019d58 ref 0 frags (nil) (tcp_send_queue_flush():336)
D: (shell_uart): TDATA (?) [0] frag 0x20019d58 ref 0 (net_pkt_unref_debug():586)
D: (shell_uart): TX [14] pkt 0x20018b20 ref 0 frags (nil) (tcp_conn_unref():389)
D: (shell_uart): RX [9] pkt 0x20018670 ref 0 frags (nil) (tcp_conn_unref():392)
D: (shell_uart): conn: 0x2001b780, ret=-116
My configuration
CONFIG_GPIO=y
CONFIG_FPU=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_MBEDTLS_HEAP_SIZE=10240
CONFIG_OPENTHREAD_RADIO_WORKQUEUE_STACK_SIZE=1024
# CONFIG_MBEDTLS_CIPHER_MODE_CBC is not set
# CONFIG_MBEDTLS_CIPHER_MODE_CTR is not set
# CONFIG_MBEDTLS_CHACHA20_C is not set
# CONFIG_MBEDTLS_POLY1305_C is not set
# CONFIG_MBEDTLS_DHM_C is not set
# CONFIG_MBEDTLS_RSA_C is not set
# CONFIG_MBEDTLS_SHA1_C is not set
# CONFIG_MBEDTLS_SHA512_C is not set
CONFIG_OPENTHREAD_LIBRARY_1_1=y
CONFIG_OPENTHREAD_NORDIC_LIBRARY_MASTER=y
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_ARM_MPU=y
CONFIG_NUM_METAIRQ_PRIORITIES=1
CONFIG_CONSOLE=y
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_UART_LINE_CTRL=y
CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
CONFIG_USB=y
CONFIG_NEWLIB_LIBC=y
# CONFIG_STDOUT_CONSOLE is not set
CONFIG_STACK_SENTINEL=y
CONFIG_NETWORKING=y
CONFIG_NET_L2_OPENTHREAD=y
CONFIG_OPENTHREAD_MANUAL_START=y
CONFIG_OPENTHREAD_FULL_LOGS=y
CONFIG_OPENTHREAD_JOINER_AUTOSTART=y
CONFIG_OPENTHREAD_JOINER_PSKD="1LABAB"
CONFIG_OPENTHREAD_DEBUG=y
CONFIG_OPENTHREAD_L2_DEBUG=y
CONFIG_OPENTHREAD_L2_LOG_LEVEL_INF=y
# CONFIG_OPENTHREAD_MBEDTLS is not set
CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=4
# CONFIG_NET_IPV6_MLD is not set
# CONFIG_NET_IPV6_NBR_CACHE is not set
CONFIG_NET_SHELL=y
CONFIG_NET_TCP=y
CONFIG_NET_PKT_RX_COUNT=10
CONFIG_NET_PKT_TX_COUNT=16
CONFIG_NET_BUF_DATA_SIZE=256
CONFIG_NET_STATISTICS=y
CONFIG_NET_LOG=y
CONFIG_NET_CONN_LOG_LEVEL_DBG=y
CONFIG_MQTT_LIB=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_POLL_MAX=4
CONFIG_NET_CONNECTION_MANAGER=y
CONFIG_UART_SHELL_ON_DEV_NAME="CDC_ACM_0"
CONFIG_USB_DEVICE_VID=0x1915
CONFIG_USB_DEVICE_PID=0x520F
CONFIG_USB_DEVICE_MANUFACTURER="Unitware"
CONFIG_USB_DEVICE_PRODUCT="Zigbee NCP"
CONFIG_USB_CDC_ACM=y
CONFIG_DEBUG_OPTIMIZATIONS=y
