Hi Devzone,
I use Thingy91. On the nrf9160 side, I run mqtt_simple example; on the nrf52840, I run connectivity_bridge with BLE feature.
When I send "900" via nus service, what I receive on nrf9160 side are:
The reason is because of noise or software config?
Thanks in advance.
Development setup: Ubuntu, ncs v1.5.1, Thingy91.
And this is my additional file to the original example. I also change AT Host to uart1 (to unused it)
#include "my_uart_handler.h"
#include <drivers/uart.h>
#include <zephyr.h>
#include <stdio.h>
#include <string.h>
#include <logging/log.h>
#include "my_led.h"
LOG_MODULE_REGISTER(my_uart, 3);
#define CONFIG_UART_0_NAME "UART_0"
static led_color color = {.c[0] = 250, .c[1] = 10, .c[2] = 5};
static const struct device *uart_dev;
char my_rx_buffer[100];
static uint8_t i;
bool rcv_flg = false;
bool ctrl_flag = false;
static bool receive_handler(char input)
switch (input)
case 'I':
rcv_flg = true;
return;
case 'Q':
rcv_flg = false;
if (rcv_flg)
if ((input >= 48)&&(input <= 57))
strcat(my_rx_buffer,&input);
ctrl_flag = true;
//if (i++ >= 5) rcv_flg = false;
//LOG_INF("rcv12: %s",log_strdup(my_rx_buffer));
if (ctrl_flag)
color.c[0] = my_rx_buffer[0];
color.c[1] = my_rx_buffer[1];
color.c[2] = my_rx_buffer[2];
pwm_out(&color);
ctrl_flag = false;
memset(my_rx_buffer,0,100);
static void isr(const struct device *dev, void *user_data)
ARG_UNUSED(user_data);
char character;
uart_irq_update(dev);
if (!uart_irq_rx_ready(dev)) {
return;
LOG_INF("rcv");
while (uart_fifo_read(dev, &character, 1))
receive_handler(character);
static int my_uart_init(const struct device *arg)
ARG_UNUSED(arg);
int err;
uint8_t dummy;
uart_dev = device_get_binding(CONFIG_UART_0_NAME);
if (uart_dev == NULL) {
LOG_ERR("Cannot bind %s\n", CONFIG_UART_0_NAME);
return -EINVAL;
uint32_t start_time = k_uptime_get_32();
/* Wait for the UART line to become valid */
do {
err = uart_err_check(uart_dev);
if (err) {
if (k_uptime_get_32() - start_time >
500) {
LOG_ERR("UART check failed: %d. "
"UART initialization timed out.", err);
return -EIO;
LOG_INF("UART check failed: %d. "
"Dropping buffer and retrying.", err);
while (uart_fifo_read(uart_dev, &dummy, 1)) {
/* Do nothing with the data */
k_sleep(K_MSEC(10));
} while (err);
uart_irq_callback_set(uart_dev, isr);
uart_irq_rx_enable(uart_dev);
return err;
SYS_INIT(my_uart_init, APPLICATION, CONFIG_KERNEL_INIT_PRIORITY_DEFAULT);
