Communication With SIM800L
I am trying to communicate SIM800L with nRF52840. I am using nRF5_SDK_17.0.0_9d13099\examples\peripheral\libuarte.
I am not getting where I should set simple AT command and check response.(Using PuTTY terminal for a response.)
Here is the code. Can you guide how can I send and receive commands? Also is there any exmple code for sending AT commands?
Thanks
 * Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup libuarte_example_main main.c
 * @ingroup libuarte_example
 * @brief Libuarte Example Application main file.
 * This file contains the source code for a sample application using libuarte.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "nrf_libuarte_async.h"
#include "nrf_drv_clock.h"
#include <bsp.h>
#include "nrf_log_ctrl.h"
#include "nrf_queue.h"
#include "nrf_delay.h"
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
static uint8_t text[] = "UART example started.\r\nLoopback:\r\n";
static uint8_t text_size = sizeof(text);
static volatile bool m_loopback_phase;
typedef struct {
    uint8_t * p_data;
    uint32_t length;
} buffer_t;
NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
    nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
    ret_code_t ret;
    switch (p_evt->type)
        case NRF_LIBUARTE_ASYNC_EVT_ERROR:
            bsp_board_led_invert(0);
        case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
            ret = nrf_libuarte_async_tx(p_libuarte,p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
            if (ret == NRF_ERROR_BUSY)
                buffer_t buf = {
                    .p_data = p_evt->data.rxtx.p_data,
                    .length = p_evt->data.rxtx.length,
                ret = nrf_queue_push(&m_buf_queue, &buf);
                APP_ERROR_CHECK(ret);
                if(buf.length==2)
                //    bsp_board_led_invert(1);
                //    nrf_delay_ms(1000);
           // ret_code_t err_code;
           // err_code = nrf_libuarte_async_tx(&libuarte, text, text_size);
           // APP_ERROR_CHECK(err_code);
            m_loopback_phase = true;
        case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
            if (m_loopback_phase)
                nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
                if (!nrf_queue_is_empty(&m_buf_queue))
                    buffer_t buf;
                    ret = nrf_queue_pop(&m_buf_queue, &buf);
                    UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
            bsp_board_led_invert(2);
    ret_code_t ret = nrf_drv_clock_init();
    ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
            .tx_pin     = TX_PIN_NUMBER,
            .rx_pin     = RX_PIN_NUMBER,
            .baudrate   = NRF_UARTE_BAUDRATE_9600,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 100,
            .int_prio   = APP_IRQ_PRIORITY_LOW
    err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    nrf_libuarte_async_enable(&libuarte);
 //   NRF_LOG_INFO("Template example started.");
    while (true)
        NRF_LOG_FLUSH();
