TWIM issue
Hello ,
I am working on a project which contains I2C communication,
When I test the twi scanner example on my sensor and it works fine
But when I do the combination with the usbd_ble_uart example to send the data to uart I encountered a problem during an I2C read operation. My code stuck in this infinite loop
bool transmission_finished = false;
        do {
            if (nrf_twim_event_check(p_twim, NRF_TWIM_EVENT_SUSPENDED))
                transmission_finished = true;
            if (nrf_twim_event_check(p_twim, NRF_TWIM_EVENT_STOPPED))
                nrf_twim_event_clear(p_twim, NRF_TWIM_EVENT_STOPPED);
            if (nrf_twim_event_check(p_twim, NRF_TWIM_EVENT_ERROR))
                nrf_twim_event_clear(p_twim, NRF_TWIM_EVENT_ERROR);
                bool lasttx_triggered = nrf_twim_event_check(p_twim, NRF_TWIM_EVENT_LASTTX);
                uint32_t shorts_mask = nrf_twim_shorts_get(p_twim);
                if (!(lasttx_triggered && (shorts_mask & NRF_TWIM_SHORT_LASTTX_STOP_MASK)))
                    // Unless LASTTX event arrived and LASTTX_STOP shortcut is active,
                    // triggering of STOP task in case of error has to be done manually.
                    nrf_twim_task_trigger(p_twim, NRF_TWIM_TASK_RESUME);
                    nrf_twim_task_trigger(p_twim, NRF_TWIM_TASK_STOP);
                    // Mark transmission as not finished yet,
                    // as STOPPED event is expected to arrive.
                    // If LASTTX_SUSPENDED shortcut is active,
                    // NACK has been received on last byte sent
                    // and SUSPENDED event happened to be checked before ERROR,
                    // transmission will be marked as finished.
                    // In such case this flag has to be overwritten.
                if (lasttx_triggered && (shorts_mask & NRF_TWIM_SHORT_LASTTX_SUSPEND_MASK))
                    // When STOP task was triggered just before SUSPEND task has taken effect,
                    // SUSPENDED event may not arrive.
                    // However if SUSPENDED arrives it always arrives after ERROR.
                    // Therefore SUSPENDED has to be cleared
                    // so it does not cause premature termination of busy loop
                    // waiting for STOPPED event to arrive.
                    nrf_twim_event_clear(p_twim, NRF_TWIM_EVENT_SUSPENDED);
                    // for same reasons as above.
        } while (!transmission_finished);
Although I tried to copy all the configuration performed in the example of twi scanner
Please Help me .
  • Please make sure that all returned error codes are passed to an APP_ERROR_CHECK or similar, so that you will know in the case that you will know if the function call failed, for whatever reason.
    I have already verified that all returned error codes are passed to APP_ERROR_CHECK
    Looking briefly through the code you shared this seems not to be the case in your functions Read, Send and Samplesready, at least.
    nikola said:
    I have already tried to insert my code and and I cannot
    That is unfortunate. If the problem persists, you might try to upload it as a complete file, using the Insert -> File option instead.
    Karl
  • there is my main code I want to divide it into two parts, this is the first part :
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_usbd.h"
    #include "nrf_drv_clock.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "nrf_drv_power.h"
    #include "app_error.h"
    #include "app_util.h"
    #include "app_usbd_core.h"
    #include "app_usbd.h"
    #include "app_usbd_string_desc.h"
    #include "app_usbd_cdc_acm.h"
    #include "app_usbd_serial_num.h"
    /*********************PPG Librairies ***********************/
    #include <stdint.h>
    #include <stdbool.h>
    #include "boards.h"
    #include "nrf_drv_twi.h"
    #include "nrf.h"
    #include "nrf_drv_rtc.h"
    /*****************************End of PPG Librairies *****************/
    /**************************TWI initailisation of PPG ********************/
    /* TWI instance ID. */
    #if TWI0_ENABLED
    #define TWI_INSTANCE_ID     0
    #elif TWI1_ENABLED
    #define TWI_INSTANCE_ID     1
     /* Number of possible TWI addresses. */
    #define TWI_ADDRESSES      127
    /************************** End of TWI initailisation of PPG ********************/
    #define LED_BLE_NUS_CONN (BSP_BOARD_LED_0)
    #define LED_BLE_NUS_RX   (BSP_BOARD_LED_1)
    #define LED_CDC_ACM_CONN (BSP_BOARD_LED_2)
    #define LED_CDC_ACM_RX   (BSP_BOARD_LED_3)
    #define LED_BLINK_INTERVAL 800
    APP_TIMER_DEF(m_blink_ble);
    APP_TIMER_DEF(m_blink_cdc);
     * @brief App timer handler for blinking the LEDs.
     * @param p_context LED to blink.
    void blink_handler(void * p_context)
        bsp_board_led_invert((uint32_t) p_context);
    #define ENDLINE_STRING "\r\n"
    // USB DEFINES START
    static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                        app_usbd_cdc_acm_user_event_t event);
    #define CDC_ACM_COMM_INTERFACE  0
    #define CDC_ACM_COMM_EPIN       NRF_DRV_USBD_EPIN2
    #define CDC_ACM_DATA_INTERFACE  1
    #define CDC_ACM_DATA_EPIN       NRF_DRV_USBD_EPIN1
    #define CDC_ACM_DATA_EPOUT      NRF_DRV_USBD_EPOUT1
    static char m_cdc_data_array[BLE_NUS_MAX_DATA_LEN];
    /** @brief CDC_ACM class instance */
    APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                                cdc_acm_user_ev_handler,
                                CDC_ACM_COMM_INTERFACE,
                                CDC_ACM_DATA_INTERFACE,
                                CDC_ACM_COMM_EPIN,
                                CDC_ACM_DATA_EPIN,
                                CDC_ACM_DATA_EPOUT,
                                APP_USBD_CDC_COMM_PROTOCOL_AT_V250);
    // USB DEFINES END
    // BLE DEFINES START
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
    #define DEVICE_NAME                     "Nordic_USBD_BLE_UART"                      /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms). Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms). Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating an event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump. Can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    /*************************Max30105**********************/
    /*MX30105*/
    //Spo2
    #define FreqS 25    //sampling frequency
    #define BUFFER_SIZE (FreqS * 4)
    #define MA4_SIZE 4 // DONOT CHANGE
    #define MX30105_ADDR 0x57
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    static char m_nus_data_array[BLE_NUS_MAX_DATA_LEN];
    // BLE DEFINES END
    /***********************Define the varibles of PPG ************************/
    uint32_t example =   0x00;
    int32_t BPM = 0x00;
    int32_t HZ = 0x00;
    int8_t finger = 0;
    int8_t error = 0;
    int16_t example1 = 0;
    uint32_t examplered;
    uint32_t examplegreen;
    uint32_t exampleIR;
    uint32_t validHeartRate = 0 ;
    uint32_t heartRate = 0 ;
    uint32_t validSPO2 = 0;
    uint32_t spo2 = 0;
    /******************************End of definition of varibles PPG *****************/
    /* Timer Stuff */
    const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(0);
    static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
        if (int_type == NRF_DRV_RTC_INT_COMPARE0)
             NRF_LOG_INFO("Compare event  ");
        else if (int_type == NRF_DRV_RTC_INT_TICK)
             NRF_LOG_INFO(" Tick Event ");
    /** @brief Function starting the internal LFCLK XTAL oscillator.
    /*static void lfclk_config(void)
    {    ret_code_t err_code = nrf_drv_clock_init();
        NRF_LOG_INFO(" Low Frequency Configuration done ");
    /*static void rtc_config(void)
        uint32_t err_code;
        //Initialize RTC instance
        nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
        config.prescaler = 327;
        err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
        nrf_drv_rtc_enable(&rtc);
        NRF_LOG_INFO("RTC Configuration done");
    static  int32_t an_x[ BUFFER_SIZE]; //ir
    static  int32_t an_y[ BUFFER_SIZE]; //red
    const uint8_t uch_spo2_table[184]={ 95, 95, 95, 96, 96, 96, 97, 97, 97, 97, 97, 98, 98, 98, 98, 98, 99, 99, 99, 99,
                  99, 99, 99, 99, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100,
                  100, 100, 100, 100, 99, 99, 99, 99, 99, 99, 99, 99, 98, 98, 98, 98, 98, 98, 97, 97,
                  97, 97, 96, 96, 96, 96, 95, 95, 95, 94, 94, 94, 93, 93, 93, 92, 92, 92, 91, 91,
                  90, 90, 89, 89, 89, 88, 88, 87, 87, 86, 86, 85, 85, 84, 84, 83, 82, 82, 81, 81,
                  80, 80, 79, 78, 78, 77, 76, 76, 75, 74, 74, 73, 72, 72, 71, 70, 69, 69, 68, 67,
                  66, 66, 65, 64, 63, 62, 62, 61, 60, 59, 58, 57, 56, 56, 55, 54, 53, 52, 51, 50,
                  49, 48, 47, 46, 45, 44, 43, 42, 41, 40, 39, 38, 37, 36, 35, 34, 33, 31, 30, 29,
                  28, 27, 26, 25, 23, 22, 21, 20, 19, 17, 16, 15, 14, 12, 11, 10, 9, 7, 6, 5,
                  3, 2, 1 } ;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
     * @brief TWI initialization.
    void twi_init (void)
        ret_code_t err_code;
        const nrf_drv_twi_config_t twi_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = true
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
        nrf_drv_twi_enable(&m_twi);
     uint32_t redBuffer[100];
     uint32_t irBuffer[100];
     uint32_t greenBuffer[100];
     * @brief Function for assert macro callback.
     *          how your product is supposed to react in case of an assert.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /** @brief Function for initializing the timer module. */
    static void timers_init(void)
        err_code = app_timer_create(&m_blink_ble, APP_TIMER_MODE_REPEATED, blink_handler);
        err_code = app_timer_create(&m_blink_cdc, APP_TIMER_MODE_REPEATED, blink_handler);
     * @brief Function for the GAP initialization.
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
     * @brief Function for handling the data from the Nordic UART Service.
     * @details This function processes the data received from the Nordic UART BLE Service and sends
     *          it to the USBD CDC ACM module.
     * @param[in] p_evt Nordic UART Service event.
            bsp_board_led_invert(LED_BLE_NUS_RX);
            NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on CDC ACM.");
            memcpy(m_nus_data_array, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            // Add endline characters
            uint16_t length = p_evt->params.rx_data.length;
            if (length + sizeof(ENDLINE_STRING) < BLE_NUS_MAX_DATA_LEN)
                memcpy(m_nus_data_array + length, ENDLINE_STRING, sizeof(ENDLINE_STRING));
                length += sizeof(ENDLINE_STRING);
            // Send data through CDC ACM
            ret_code_t ret = app_usbd_cdc_acm_write(&m_app_cdc_acm,
                                                    m_nus_data_array,
                                                    length);
            if(ret != NRF_SUCCESS)
                NRF_LOG_INFO("CDC ACM unavailable, data received: %s", m_nus_data_array);
    /** @brief Function for initializing services that will be used by the application. */
        uint32_t       err_code;
        ble_nus_init_t nus_init;
     * @brief Function for handling errors from the Connection Parameters module.
        APP_ERROR_HANDLER(nrf_error);
    /** @brief Function for initializing the Connection Parameters module. */
        cp_init.disconnect_on_fail             = true;
        cp_init.evt_handler                    = NULL;
     * @brief Function for putting the chip into sleep mode.
     * @note This function does not return.
        // Prepare wakeup buttons.
    /** @brief Function for starting advertising. */
     * @brief Function for handling advertising events.
     * @details This function is called for advertising events which are passed to the application.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                err_code = app_timer_start(m_blink_ble,
                                           APP_TIMER_TICKS(LED_BLINK_INTERVAL),
                                           (void *) LED_BLE_NUS_CONN);
            case BLE_ADV_EVT_IDLE:
                NRF_LOG_INFO("Advertising timeout, restarting.")
                advertising_start();
     * @brief Function for handling BLE events.
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("BLE NUS connected");
                err_code = app_timer_stop(m_blink_ble);
                bsp_board_led_on(LED_BLE_NUS_CONN);
                NRF_LOG_INFO("BLE NUS disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported.
            case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
                ble_gap_data_length_params_t dl_params;
                // Clearing the struct will effectively set members to @ref BLE_GAP_DATA_LENGTH_AUTO.
                memset(&dl_params, 0, sizeof(ble_gap_data_length_params_t));
                err_code = sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle, &dl_params, NULL);
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
                // No implementation needed.
     * @brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /** @brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /** @brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, 64);
     * @brief Function for handling events from the BSP module.
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
    /** @brief Function for initializing the Advertising functionality. */
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    /** @brief Function for initializing buttons and LEDs. */
    static void buttons_leds_init(void)
        uint32_t err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    /** @brief Function for initializing the nrf_log module. */
    static void log_init(void)
    /** @brief Function for placing the application in low power state while waiting for events. */
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
     * @brief Function for handling the idle state (main loop).
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        power_manage();
    // USB CODE START
    static bool m_usb_connected = false;
    /** @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t */
        app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
        switch (event)
            case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
                /*Set up the first transfer*/
                ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                                       m_cdc_data_array,
                                                       1);
                UNUSED_VARIABLE(ret);
                ret = app_timer_stop(m_blink_cdc);
                APP_ERROR_CHECK(ret);
                bsp_board_led_on(LED_CDC_ACM_CONN);
                NRF_LOG_INFO("CDC ACM port opened");
            case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
                NRF_LOG_INFO("CDC ACM port closed");
                if (m_usb_connected)
                    ret_code_t ret = app_timer_start(m_blink_cdc,
                                                     (void *) LED_CDC_ACM_CONN);
            case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
            case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
                ret_code_t ret;
                static uint8_t index = 0;
                index++;
                do
                    if ((m_cdc_data_array[index - 1] == '\n') ||
                        (m_cdc_data_array[index - 1] == '\r') ||
                        (index >= (m_ble_nus_max_data_len)))
                        if (index > 1)
                            bsp_board_led_invert(LED_CDC_ACM_RX);
                            NRF_LOG_HEXDUMP_DEBUG(m_cdc_data_array, index);
                            NRF_LOG_INFO ( "%s" , m_cdc_data_array);
                         //   readuart(m_cdc_data_array,index)
                          //  NRF_LOG_INFO(m_cdc_data_array);
                            do
                                    memcpy(m_cdc_data_array + length, ENDLINE_STRING, sizeof(ENDLINE_STRING));
                                                    m_cdc_data_array,
                                                    index);
                                ret = ble_nus_data_send(&m_nus,
                                                        (uint8_t *) m_cdc_data_array,
                                                        &length,
                                                        m_conn_handle);
                                if (ret == NRF_ERROR_NOT_FOUND)
                                    NRF_LOG_INFO("BLE NUS unavailable, data received: %s", m_cdc_data_array);
                                if (ret == NRF_ERROR_RESOURCES)
                                    NRF_LOG_ERROR("BLE NUS Too many notifications queued.");
                                if ((ret != NRF_ERROR_INVALID_STATE) && (ret != NRF_ERROR_BUSY))
                            while (ret == NRF_ERROR_BUSY);
                        index = 0;
                    /*Get amount of data transferred*/
                    size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
                    NRF_LOG_DEBUG("RX: size: %lu char: %c", size, m_cdc_data_array[index - 1]);
                    /* Fetch data until internal buffer is empty */
                                                &m_cdc_data_array[index],
                                                1);
                    if (ret == NRF_SUCCESS)
                        index++;
                while (ret == NRF_SUCCESS);
    static void usbd_user_ev_handler(app_usbd_event_type_t event)
        switch (event)
            case APP_USBD_EVT_DRV_SUSPEND:
            case APP_USBD_EVT_DRV_RESUME:
            case APP_USBD_EVT_STARTED:
            case APP_USBD_EVT_STOPPED:
                app_usbd_disable();
            case APP_USBD_EVT_POWER_DETECTED:
                NRF_LOG_INFO("USB power detected");
                if (!nrf_drv_usbd_is_enabled())
                    app_usbd_enable();
            case APP_USBD_EVT_POWER_REMOVED:
                NRF_LOG_INFO("USB power removed");
                ret_code_t err_code = app_timer_stop(m_blink_cdc);
                bsp_board_led_off(LED_CDC_ACM_CONN);
                app_usbd_stop();
            case APP_USBD_EVT_POWER_READY:
                NRF_LOG_INFO("USB ready");
                ret_code_t err_code = app_timer_start(m_blink_cdc,
                m_usb_connected = true;
                app_usbd_start();
    // USB CODE END
    void sendcom(char  c[]){
             uint8_t length;
             length =strlen(c);
                                                    c,
                                                    length);
     while(true)
            uint8_t bufferLength = 100;
            for(uint8_t k =0 ; k <  bufferLength ; k++)
            err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&FIFO_Write_PointerADD, 1, false);
            nrf_delay_ms(5);
            err_code = nrf_drv_twi_rx(&m_twi, MX30105_ADDR, &FIFO_Write_Pointer,1);
            nrf_delay_ms(5);
            if (err_code != NRF_SUCCESS)
                NRF_LOG_INFO(" ERROR IN Write Pointer:  0x%x", FIFO_Write_Pointer);
                NRF_LOG_FLUSH();
                error = 1;
                    err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&FIFO_Read_PointerADD, 1, false);
            nrf_delay_ms(5);
            err_code = nrf_drv_twi_rx(&m_twi, MX30105_ADDR, &FIFO_Read_Pointer,1);
            nrf_delay_ms(5);
               NRF_LOG_INFO(" ERROR IN Read Pointer 0x%x", FIFO_Read_Pointer);
               NRF_LOG_FLUSH();
               error = 1;
            err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&Over_Flow_CounterADD, 1, false);
            nrf_delay_ms(5);
            err_code = nrf_drv_twi_rx(&m_twi, MX30105_ADDR, &Over_Flow_Counter,1);
            nrf_delay_ms(5);
            if (err_code == NRF_SUCCESS)
               // NRF_LOG_INFO(" Overflowed:  0x%x", Over_Flow_Counter);
            if (FIFO_Write_Pointer >  FIFO_Read_Pointer){ReadySamples = FIFO_Write_Pointer - FIFO_Read_Pointer;}
            if (FIFO_Write_Pointer <  FIFO_Read_Pointer ){ReadySamples = FIFO_Write_Pointer+32 - FIFO_Read_Pointer;}
            if (FIFO_Write_Pointer ==  FIFO_Read_Pointer)
            ReadySamples = 0;
            k--;
            if (error == 1 )
            ReadySamples = 0;
            k--;
            if ( ReadySamples > 0){
                    bsp_board_led_invert(3);
                    err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&FIFO_Data_RegisterADD, 1, false);
                    err_code = nrf_drv_twi_rx(&m_twi, MX30105_ADDR, &FIFO_Data_Register,3*ReadySamples*lednumber);
                    nrf_delay_ms(4);
                      error = 0;
                      uint8_t i=0;
                      if (lednumber == 1)
                            for (i=0;i<ReadySamples*3;i=i+3)
                                 Max_ADC = ((uint32_t)FIFO_Data_Register[i] << 16) | ((uint32_t)FIFO_Data_Register[i+1] << 8) | FIFO_Data_Register[i+2];
                                 example = (((uint32_t)FIFO_Data_Register[i] << 16) | ((uint32_t)FIFO_Data_Register[i+1] << 8) | FIFO_Data_Register[i+2]);
                                  redBuffer[k]=Max_ADC;
                                  NRF_LOG_INFO("RED : %d,Samples %d %d %d %d", Max_ADC, ReadySamples, Over_Flow_Counter,FIFO_Read_Pointer,FIFO_Write_Pointer );
                                  NRF_LOG_FLUSH();
                      if ( lednumber == 2 )
                                 for (i=0;i<ReadySamples*3*2;i=i+6)
                                 Max_ADC2 = ((uint32_t)FIFO_Data_Register[i+3] << 16) | ((uint32_t)FIFO_Data_Register[i+4] << 8) | FIFO_Data_Register[i+5];
                                // example = (((uint32_t)FIFO_Data_Register[i] << 16) | ((uint32_t)FIFO_Data_Register[i+1] << 8) | FIFO_Data_Register[i+2]);
                                 irBuffer[k]=Max_ADC2;
                                 //NRF_LOG_INFO("RED : %d,Samples %d %d %d %d", Max_ADC, ReadySamples, Over_Flow_Counter,FIFO_Read_Pointer,FIFO_Write_Pointer );
                                 //NRF_LOG_INFO("IR : %d,Samples %d %d %d %d", Max_ADC2, ReadySamples, Over_Flow_Counter,FIFO_Read_Pointer,FIFO_Write_Pointer );
                                 NRF_LOG_FLUSH();
                      if (lednumber == 3 )
                       for (i=0;i<ReadySamples*3*3;i=i+9)
                                 Max_ADC3 = ((uint32_t)FIFO_Data_Register[i+6] << 16) | ((uint32_t)FIFO_Data_Register[i+7] << 8) | FIFO_Data_Register[i+8];
                                 greenBuffer[k]=Max_ADC3;
                                // NRF_LOG_INFO("IR : %d,Samples %d %d %d %d", Max_ADC2, ReadySamples, Over_Flow_Counter,FIFO_Read_Pointer,FIFO_Write_Pointer );
                                // NRF_LOG_INFO("GREEN : %d,Samples %d %d %d %d", Max_ADC3, ReadySamples, Over_Flow_Counter,FIFO_Read_Pointer,FIFO_Write_Pointer );
                                NRF_LOG_FLUSH();
      //timer=nrfx_rtc_counter_get(&rtc);
      maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
      //Continuously taking samples from MAX30102.  Heart rate and SpO2 are calculated every 1 second
      while (1)
        //dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
        for (uint8_t k = 25; k < 100; k++)
          redBuffer[k - 25] = redBuffer[k];
          irBuffer[k - 25] = irBuffer[k];
        //take 25 sets of samples before calculating the heart rate.
        for (uint8_t k = 75; k < 100; k++)
            nrf_delay_ms(5);
            nrf_delay_ms(5);
                NRF_LOG_FLUSH();
                error = 1;
            nrf_delay_ms(5);
            nrf_delay_ms(5);
               NRF_LOG_FLUSH();
               error = 1;
            nrf_delay_ms(5);
            nrf_delay_ms(5);
            ReadySamples = 0;
            k--;
            if (error == 1 )
            ReadySamples = 0;
            k--;
                    nrf_delay_ms(4);
                      error = 0;
                      uint8_t i=0;
                      if (lednumber == 1)
                                  NRF_LOG_FLUSH();
                                 NRF_LOG_FLUSH();
                                NRF_LOG_FLUSH();
        NRF_LOG_INFO(" %d  ", spo2 );
         BPM = (int32_t)60000/(int32_t)heartRate;
                NRF_LOG_INFO("Data not sent,Please Open Com to send data : %s", c);
  • this is the second part :
    /** @brief Application main function. */
    /*******************************For PPG ********************/
        uint32_t Max_ADC;
        uint32_t Max_ADC2;
        uint32_t Max_ADC3;
        uint8_t address;
        uint8_t sample_data;
        uint8_t FIFO_Configuration = 0;
        uint8_t Mode_Configuration = 0;
        uint8_t SpO2_Configuration = 0;
        uint8_t RESERVED;
        uint8_t Multi_LED_Mode_Control1= 0;
        uint8_t Multi_LED_Mode_Control2= 0;
        uint8_t FIFO_Write_Pointer= 0;
        uint8_t Over_Flow_Counter= 0;
        uint8_t FIFO_Read_Pointer=0;
        uint8_t FIFO_Data_Register[288];
        uint8_t FIFO_Configuration1 = 0;
        uint8_t Mode_Configuration1 = 0;
        uint8_t SpO2_Configuration1 = 0;
        uint8_t RESERVED1;
        uint8_t Multi_LED_Mode_Control11= 0;
        uint8_t Multi_LED_Mode_Control21= 0;
        uint8_t FIFO_Write_Pointer1= 0;
        uint8_t Over_Flow_Counter1= 0;
        uint8_t FIFO_Read_Pointer1=0;
        uint8_t FIFO_Data_Register1[288];
    //configuration :
       const uint8_t FIFO_Write_PointerADD = 0x04;
       const uint8_t Over_Flow_CounterADD = 0x05;
       const uint8_t FIFO_Read_PointerADD = 0x06;
       const uint8_t FIFO_Data_RegisterADD = 0x07;
       const uint8_t FIFO_ConfigurationADD = 0x08;
       const uint8_t Mode_ConfigurationADD = 0x09;
       const uint8_t SpO2_ConfigurationADD = 0x0A;
       const uint8_t RESERVEDADD = 0x0B;
       const uint8_t LED_PulseAmplitude1ADD = 0x0C;
       const uint8_t LED_PulseAmplitude2ADD = 0x0D;
       const uint8_t LED_PulseAmplitude3ADD = 0x0E;
       const uint8_t LED_PulseAmplitude4ADD = 0x0F;
       const uint8_t Multi_LED_Mode_Control1ADD = 0x11;
       const uint8_t Multi_LED_Mode_Control2ADD = 0x12;
       const uint8_t Temp_Integer = 0x1F;
       const uint8_t Temp_Fraction = 0x20; //only last 4 bits
       const uint8_t Die_Temperature_Config = 0x21; //only one bit
        //masks//
        const uint8_t SMP_AVE_MASK          =0x1F;
        const uint8_t FIFO_ROLLOVER_EN_MASK =0xEF;
        const uint8_t FIFO_A_FULL_MASK      =0xF0;
        const uint8_t SHDN_MASK             =0x7F;
        const uint8_t RESET_MASK            =0xBF;
        const uint8_t MODE_MASK             =0xF8;
        const uint8_t SPO2_ADC_RGE_MASK     =0x9F;
        const uint8_t SPO2_SR_MASK          =0xE3;
        const uint8_t LED_PW_MASK           =0xFC;
        const uint8_t SLOT1_MASK            =0xF8;
        const uint8_t SLOT2_MASK            =0x8F;
        const uint8_t SLOT3_MASK            =0xF8;
        const uint8_t SLOT4_MASK            =0x8F;
          // test variables
        uint8_t masked =    0x00; // too
        uint8_t notshifted= 0x01;
        uint8_t shifted =   0x00;
        uint8_t ReadySamples = 0x00;
         //Configuration of MAX30105                         Heart Rate   -------  SPO2
         uint8_t SMP_AVE          =0x00;
         uint8_t FIFO_ROLLOVER_EN =0x00;
         uint8_t FIFO_A_FULL      =0x00 ;
         uint8_t SHDN             =0x00 ;
         uint8_t RESET            =0x00 ;
         uint8_t MODE             =0x00 ;
         uint8_t SPO2_ADC_RGE     =0x00 ;
         uint8_t SPO2_SR          =0x00 ;
         uint8_t LED_PulseAmplitude1 = 0x00;
         uint8_t LED_PulseAmplitude2 = 0x00;
         uint8_t LED_PulseAmplitude3 = 0x00;
         uint8_t LED_PulseAmplitude4 = 0x00;
         uint8_t LED_PW           =0x00;
         uint8_t SLOT1            =0x00 ;
         uint8_t SLOT2            =0x00 ;
         uint8_t SLOT3            =0x00 ;
         uint8_t SLOT4            =0x00 ;
         uint8_t lednumber = 0x00;
        ret_code_t ret;
        static const app_usbd_config_t usbd_config = {
            .ev_state_proc = usbd_user_ev_handler
        // Initialize.
     bool detected_device = false;
        log_init();
       // APP_ERROR_CHECK(NRF_LOG_INIT(NULL));
        //NRF_LOG_DEFAULT_BACKENDS_INIT();
        twi_init();
        for (address = 1; address <= TWI_ADDRESSES; address++)
            err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
                detected_device = true;
               NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
            NRF_LOG_FLUSH();
            nrf_delay_ms(10);
        if (!detected_device)
            NRF_LOG_INFO("hi there");
                    NRF_LOG_INFO("No device was found.");
            NRF_LOG_FLUSH();
        timers_init();
        buttons_leds_init();
        app_usbd_serial_num_generate();
        ret = nrf_drv_clock_init();
        NRF_LOG_INFO("USBD BLE UART example started.");
        ret = app_usbd_init(&usbd_config);
        app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
        ret = app_usbd_class_append(class_cdc_acm);
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        /*********************************************For PPG**************************************/
        /*--------------------------------------READING COMMAND-------------------------------*/
            uint8_t Read(uint8_t address)
            uint8_t temp;
            bsp_board_led_invert(4);
            err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&address, 1, false);
            nrf_delay_ms(10);
            err_code = nrf_drv_twi_rx(&m_twi, MX30105_ADDR, &temp,1);
            nrf_delay_ms(10);
               // NRF_LOG_RAW_INFO(" 0x%x  at 0x%x                          ", temp ,address );
                //NRF_LOG_INFO(" ");
                NRF_LOG_FLUSH();
                return temp;
    /*--------------------------------------SENDING COMMAND-------------------------------*/
            void Send(uint8_t address, uint8_t command)
              uint8_t fifoconfig_Reg[2]={address,command} ;
              bsp_board_led_invert(2);
              err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&fifoconfig_Reg, sizeof(fifoconfig_Reg), false);
              nrf_delay_ms(10);
               // NRF_LOG_INFO(" Sent : 0x%x to 0x%x", command,address);
                //NRF_LOG_FLUSH();
            void Softreset()
          //  NRF_LOG_RAW_INFO("Reading Mode_Configuration for Reset : ");
            Mode_Configuration = Read(Mode_ConfigurationADD);
            Mode_Configuration =  (Mode_Configuration & RESET_MASK) | (0x01 << 6) ;
            Send(Mode_ConfigurationADD,Mode_Configuration);
            nrf_delay_ms(250);
           // NRF_LOG_INFO("                      Soft Reset Done                    ");
            void Readall(){
           // NRF_LOG_RAW_INFO("FIFO_Configuration  : ");
            FIFO_Configuration = Read(FIFO_ConfigurationADD);
            //NRF_LOG_RAW_INFO("Mode_Configuration  : ");
            //NRF_LOG_RAW_INFO("SpO2_Configuration  : ");
            SpO2_Configuration = Read(SpO2_ConfigurationADD);
           // NRF_LOG_RAW_INFO("Multi_LED_Mode_Con1 : ");
            Multi_LED_Mode_Control1 = Read(Multi_LED_Mode_Control1ADD);
            //NRF_LOG_RAW_INFO("Multi_LED_Mode_Con2 : ");
            Multi_LED_Mode_Control2 = Read(Multi_LED_Mode_Control2ADD);
            //NRF_LOG_RAW_INFO("LED_PulseAmplitude1 : ");
            LED_PulseAmplitude1 = Read(LED_PulseAmplitude1ADD);
            //NRF_LOG_RAW_INFO("LED_PulseAmplitude2 : ");
            LED_PulseAmplitude2 = Read(LED_PulseAmplitude2ADD);
            //NRF_LOG_RAW_INFO("LED_PulseAmplitude3 : ");
            LED_PulseAmplitude3 = Read(LED_PulseAmplitude3ADD);
            //NRF_LOG_RAW_INFO("LED_PulseAmplitude4 : ");
            LED_PulseAmplitude4 = Read(LED_PulseAmplitude4ADD);
            void ConfigureSampleAverage(uint8_t SampleAverage)
            SampleAverage = SampleAverage << 5;
            //NRF_LOG_RAW_INFO("Reading FIFO_CONFIGURATION for SampleAverage : ");
            FIFO_Configuration =  (FIFO_Configuration & SMP_AVE_MASK) | SampleAverage ;
            Send(FIFO_ConfigurationADD,FIFO_Configuration);
            void Enablefiforollover()
            //NRF_LOG_RAW_INFO("Reading FIFO_CONFIGURATION for Enabling Rollover : ");
            FIFO_Configuration =  (FIFO_Configuration & FIFO_ROLLOVER_EN_MASK) | ( 0x01 << 4 ) ;
           // NRF_LOG_RAW_INFO("comfirm FIFO_CONFIGURATION for Enabling Rollover : ");
            void Disablefiforollover()
            FIFO_Configuration =  (FIFO_Configuration & FIFO_ROLLOVER_EN_MASK) | ( 0x00 << 4 ) ;
            NRF_LOG_RAW_INFO("Comfirm FIFO_CONFIGURATION for Enabling Rollover : ");
            void Setmode(uint8_t mode)
            if (mode == 0x02){
            lednumber =1;
            if (mode == 0x03){
            lednumber =2;
            if (mode == 0x07){
            lednumber =3;
             // NRF_LOG_RAW_INFO("Reading Mode_CONFIGURATION for Enabling Rollover : ");
            Mode_Configuration =  (Mode_Configuration & MODE_MASK) | mode ;
            //NRF_LOG_RAW_INFO("Comfirm Mode_CONFIGURATION for Enabling Rollover : ");
            void Ledpulsewidth(uint8_t LED_PW){
            //NRF_LOG_RAW_INFO("Reading Spo2_CONFIGURATION for Led pulse width : ");
            SpO2_Configuration =  (SpO2_Configuration & LED_PW_MASK) | LED_PW ;
            Send(SpO2_ConfigurationADD,SpO2_Configuration);
            //NRF_LOG_RAW_INFO("comfirm Spo2_CONFIGURATION for Led pulse width : ");
            void Spo2samplerate(uint8_t SPO2_SR)
            SPO2_SR = SPO2_SR << 2;
            //NRF_LOG_RAW_INFO("Reading Spo2_CONFIGURATION for Spo2samplerate : ");
            SpO2_Configuration =  (SpO2_Configuration & SPO2_SR_MASK) | SPO2_SR ;
            void Spo2adcrange(uint8_t SPO2_ADC_RGE ){
            SPO2_ADC_RGE = SPO2_ADC_RGE << 5;
           // NRF_LOG_RAW_INFO("Reading Spo2_CONFIGURATION for Spo2adcrange : ");
            SpO2_Configuration =  (SpO2_Configuration & SPO2_ADC_RGE_MASK) | SPO2_ADC_RGE ;
            //NRF_LOG_RAW_INFO("comfirm Spo2_CONFIGURATION for Spo2adcrange : ");
            void Led1pulseamplitude(uint8_t amplitude){
            Send( LED_PulseAmplitude1ADD,amplitude);
           // NRF_LOG_RAW_INFO("Led1 Pulse Amplitude : ");
            amplitude = Read(LED_PulseAmplitude1ADD);
             void Led2pulseamplitude(uint8_t amplitude){
            Send( LED_PulseAmplitude2ADD,amplitude);
            //NRF_LOG_RAW_INFO("Led2 Pulse Amplitude : ");
            amplitude = Read(LED_PulseAmplitude2ADD);
             void Led3pulseamplitude(uint8_t amplitude){
            Send( LED_PulseAmplitude3ADD,amplitude);
            //NRF_LOG_RAW_INFO("Led3 Pulse Amplitude : ");
            amplitude = Read(LED_PulseAmplitude3ADD);
             void Led4pulseamplitude(uint8_t amplitude){
            Send( LED_PulseAmplitude4ADD,amplitude);
            //NRF_LOG_RAW_INFO("Led4 Pulse Amplitude : ");
            amplitude = Read(LED_PulseAmplitude4ADD);
            void  slot1(uint8_t SLOT1) {
           //NRF_LOG_RAW_INFO("Reading Multi_LED_Mode_Control1 for SLOT1 : ");
           Multi_LED_Mode_Control1 = Read(Multi_LED_Mode_Control1ADD) ;
           Multi_LED_Mode_Control1 =  (Multi_LED_Mode_Control1 & SLOT1_MASK) | SLOT1 ;
           Send( Multi_LED_Mode_Control1ADD,Multi_LED_Mode_Control1);
            //NRF_LOG_RAW_INFO("Comfirm Multi_LED_Mode_Control1 for SLOT1 : ");
            void  slot2(uint8_t SLOT2) {
            SLOT2 =SLOT2 << 4;
           //NRF_LOG_RAW_INFO("Reading Multi_LED_Mode_Control1 for SLOT2 : ");
           Multi_LED_Mode_Control1 =  (Multi_LED_Mode_Control1 & SLOT2_MASK) | SLOT2 ;
            //NRF_LOG_RAW_INFO("Comfirm Multi_LED_Mode_Control1 for SLOT2 : ");
             void  slot3(uint8_t SLOT3) {
           Multi_LED_Mode_Control2 = Read(Multi_LED_Mode_Control2ADD) ;
           Multi_LED_Mode_Control2 =  (Multi_LED_Mode_Control2 & SLOT3_MASK) | SLOT3 ;
           Send( Multi_LED_Mode_Control2ADD,Multi_LED_Mode_Control2);
           void  slot4(uint8_t SLOT4) {
            SLOT4 =SLOT4 << 4;
           //NRF_LOG_RAW_INFO("Reading Multi_LED_Mode_Control2 for SLOT2 : ");
           Multi_LED_Mode_Control2 =  (Multi_LED_Mode_Control2 & SLOT4_MASK) | SLOT4 ;
            //NRF_LOG_RAW_INFO("Comfirm Multi_LED_Mode_Control2 for SLOT2 : ");
            Readall();
            Softreset();
            Readall();
            bsp_board_led_invert(0);
            Enablefiforollover();
            ConfigureSampleAverage(0x02); //Sample Average 4 ; FOR SPO2
            Setmode(0x03); // 2 is red only, 3 is red + IR , 7 is Green + Red + IR ; ledMode = 2;
            Spo2adcrange(0x01); //2048 in arduino.
            Spo2samplerate(0x01);  // 50 in arduino.
            Ledpulsewidth(0x03); // pulse Width is us ms ;
            //if 1 led = > 1 slot and put Red in it, if 2 leds , 2 slots and put IR in second one, if 3 slots , put Red in first, IR in second and green in third.
            //we have red only so: ( RED 0x01, IR 0x02, Green 0x03)
            slot1(0x01);
            slot2(0x02);
            slot3(0x03);
            Led1pulseamplitude(0x1F);
            Led2pulseamplitude(0x1F);
            Led3pulseamplitude(0x1F);
            NRF_LOG_FLUSH();
            //TESTING BEAT STUFF//
     int16_t IR_AC_Max = 20;
    int16_t IR_AC_Min = -20;
    //int16_t example1 = 0;
    int16_t IR_AC_Signal_Previous;
    int16_t IR_AC_Signal_min = 0;
    int16_t IR_AC_Signal_max = 0;
    int16_t IR_Average_Estimated;
    int16_t positiveEdge = 0;
    int16_t negativeEdge = 0;
    int32_t ir_avg_reg = 0;
    int16_t cbuf[32];
    uint8_t offset = 0;
    static const uint16_t FIRCoeffs[12] = {172, 321, 579, 927, 1360, 1858, 2390, 2916, 3391, 3768, 4012, 4096};
    //  Average DC Estimator
    int16_t averageDCEstimator(int32_t *p, uint16_t x)
      *p += ((((long) x << 15) - *p) >> 4);
      return (*p >> 15);
    int32_t mul16(int16_t x, int16_t y)
      return((long)x * (long)y);
    //  Low Pass FIR Filter
    int16_t lowPassFIRFilter(int16_t din)
      cbuf[offset] = din;
      int32_t z = mul16(FIRCoeffs[11], cbuf[(offset - 11) & 0x1F]);
      for (uint8_t i = 0 ; i < 11 ; i++)
        z += mul16(FIRCoeffs[i], cbuf[(offset - i) & 0x1F] + cbuf[(offset - 22 + i) & 0x1F]);
      offset++;
      offset %= 32; //Wrap condition
      return(z >> 15);
    //  Heart Rate Monitor functions takes a sample value and the sample number
    //  Returns true if a beat is detected
    //  A running average of four samples is recommended for display on the screen.
    bool checkForBeat(int32_t sample)
      bool beatDetected = false;
      //  Save current state
      IR_AC_Signal_Previous = example1;
      //This is good to view for debugging
      //Serial.print("Signal_Current: ");
      //Serial.println(example);
      //  Process next data sample
      IR_Average_Estimated = averageDCEstimator(&ir_avg_reg, sample);
      example1 = lowPassFIRFilter(sample - IR_Average_Estimated);
      //  Detect positive zero crossing (rising edge)
      if ((IR_AC_Signal_Previous < 0) & (example1 >= 0))
        IR_AC_Max = IR_AC_Signal_max; //Adjust our AC max and min
        IR_AC_Min = IR_AC_Signal_min;
        positiveEdge = 1;
        negativeEdge = 0;
        //if ((IR_AC_Max - IR_AC_Min) > 100 & (IR_AC_Max - IR_AC_Min) < 1000)
        if ((IR_AC_Max - IR_AC_Min) > 20 & (IR_AC_Max - IR_AC_Min) < 1000)
          //Heart beat!!!
          beatDetected = true;
      //  Detect negative zero crossing (falling edge)
      if ((IR_AC_Signal_Previous > 0) & (example1 <= 0))
        positiveEdge = 0;
        negativeEdge = 1;
      //  Find Maximum value in positive cycle
      if (positiveEdge & (example1 > IR_AC_Signal_Previous))
        IR_AC_Signal_max = example1;
      //  Find Minimum value in negative cycle
      if (negativeEdge & (example1 < IR_AC_Signal_Previous))
        IR_AC_Signal_min = example1;
      return(beatDetected);
    //end of Testing beat
    //rtc_config();
    //lfclk_config();
    uint8_t Readysamplesnumber()
    uint8_t write;
    uint8_t read;
    uint8_t error;
    error = 0;
    nrf_delay_ms(5);
    nrf_delay_ms(5);
            read = FIFO_Read_Pointer;
            if (err_code !=NRF_SUCCESS)
            error = 1 ;
    nrf_delay_ms(5);
    nrf_delay_ms(5);
            write = FIFO_Write_Pointer;
            error = 1 ;
    if (error = 0 ){
      if ( write > read )
      return write - read ;
      if ( write < read )
      return write+32 -read;
    error =0;
    /////////////////////////////////////////////////////////////SPO2//////////////////////////////////////////////////////////////
    void maxim_sort_indices_descend(  int32_t  *pn_x, int32_t *pn_indx, int32_t n_size)
    * \brief        Sort indices
    * \par          Details
    *               Sort indices according to descending order (insertion sort algorithm)
    * \retval       None
      int32_t i, j, n_temp;
      for (i = 1; i < n_size; i++) {
        n_temp = pn_indx[i];
        for (j = i; j > 0 && pn_x[n_temp] > pn_x[pn_indx[j-1]]; j--)
          pn_indx[j] = pn_indx[j-1];
        pn_indx[j] = n_temp;
    void maxim_sort_ascend(int32_t  *pn_x, int32_t n_size)
    * \brief        Sort array
    * \par          Details
    *               Sort array in ascending order (insertion sort algorithm)
    * \retval       None
        n_temp = pn_x[i];
        for (j = i; j > 0 && n_temp < pn_x[j-1]; j--)
            pn_x[j] = pn_x[j-1];
        pn_x[j] = n_temp;
    void maxim_remove_close_peaks(int32_t *pn_locs, int32_t *pn_npks, int32_t *pn_x, int32_t n_min_distance)
    * \brief        Remove peaks
    * \par          Details
    *               Remove peaks separated by less than MIN_DISTANCE
    * \retval       None
      int32_t i, j, n_old_npks, n_dist;
      /* Order peaks from large to small */
      maxim_sort_indices_descend( pn_x, pn_locs, *pn_npks );
      for ( i = -1; i < *pn_npks; i++ ){
        n_old_npks = *pn_npks;
        *pn_npks = i+1;
        for ( j = i+1; j < n_old_npks; j++ ){
          n_dist =  pn_locs[j] - ( i == -1 ? -1 : pn_locs[i] ); // lag-zero peak of autocorr is at index -1
          if ( n_dist > n_min_distance || n_dist < -n_min_distance )
            pn_locs[(*pn_npks)++] = pn_locs[j];
      // Resort indices int32_to ascending order
      maxim_sort_ascend( pn_locs, *pn_npks );
    void maxim_peaks_above_min_height( int32_t *pn_locs, int32_t *n_npks,  int32_t  *pn_x, int32_t n_size, int32_t n_min_height )
    * \brief        Find peaks above n_min_height
    * \par          Details
    *               Find all peaks above MIN_HEIGHT
    * \retval       None
      int32_t i = 1, n_width;
      *n_npks = 0;
      while (i < n_size-1){
        if (pn_x[i] > n_min_height && pn_x[i] > pn_x[i-1]){      // find left edge of potential peaks
          n_width = 1;
          while (i+n_width < n_size && pn_x[i] == pn_x[i+n_width])  // find flat peaks
            n_width++;
          if (pn_x[i] > pn_x[i+n_width] && (*n_npks) < 15 ){      // find right edge of peaks
            pn_locs[(*n_npks)++] = i;
            // for flat peaks, peak location is left edge
            i += n_width+1;
            i += n_width;
          i++;
    void maxim_find_peaks( int32_t *pn_locs, int32_t *n_npks,  int32_t  *pn_x, int32_t n_size, int32_t n_min_height, int32_t n_min_distance, int32_t n_max_num )
    * \brief        Find peaks
    * \par          Details
    *               Find at most MAX_NUM peaks above MIN_HEIGHT separated by at least MIN_DISTANCE
    * \retval       None
      maxim_peaks_above_min_height( pn_locs, n_npks, pn_x, n_size, n_min_height );
      maxim_remove_close_peaks( pn_locs, n_npks, pn_x, n_min_distance );
      //added a min here, because min doesn't exist
      if (*n_npks > n_max_num){
       *n_npks = n_max_num;
     // *n_npks = min( *n_npks, n_max_num );
      if (*n_npks < n_max_num){
      *n_npks = *n_npks;
    void maxim_heart_rate_and_oxygen_saturation(uint32_t *pun_ir_buffer, int32_t n_ir_buffer_length, uint32_t *pun_red_buffer, int32_t *pn_spo2, int8_t *pch_spo2_valid,
                    int32_t *pn_heart_rate, int8_t *pch_hr_valid)
    * \brief        Calculate the heart rate and SpO2 level
    * \par          Details
    *               By detecting  peaks of PPG cycle and corresponding AC/DC of red/infra-red signal, the an_ratio for the SPO2 is computed.
    *               Since this algorithm is aiming for Arm M0/M3. formaula for SPO2 did not achieve the accuracy due to register overflow.
    *               Thus, accurate SPO2 is precalculated and save longo uch_spo2_table[] per each an_ratio.
    * \param[in]    *pun_ir_buffer           - IR sensor data buffer
    * \param[in]    n_ir_buffer_length      - IR sensor data buffer length
    * \param[in]    *pun_red_buffer          - Red sensor data buffer
    * \param[out]    *pn_spo2                - Calculated SpO2 value
    * \param[out]    *pch_spo2_valid         - 1 if the calculated SpO2 value is valid
    * \param[out]    *pn_heart_rate          - Calculated heart rate value
    * \param[out]    *pch_hr_valid           - 1 if the calculated heart rate value is valid
    * \retval       None
      uint32_t un_ir_mean;
      int32_t k, n_i_ratio_count;
      int32_t i, n_exact_ir_valley_locs_count, n_middle_idx;
      int32_t n_th1, n_npks;
      int32_t an_ir_valley_locs[15] ;
      int32_t n_peak_interval_sum;
      int32_t n_y_ac, n_x_ac;
      int32_t n_spo2_calc;
      int32_t n_y_dc_max, n_x_dc_max;
      int32_t n_y_dc_max_idx = 0;
      int32_t n_x_dc_max_idx = 0;
      int32_t an_ratio[5], n_ratio_average;
      int32_t n_nume, n_denom ;
      // calculates DC mean and subtract DC from ir
      un_ir_mean =0;
      for (k=0 ; k<n_ir_buffer_length ; k++ ) un_ir_mean += pun_ir_buffer[k] ;
      un_ir_mean =un_ir_mean/n_ir_buffer_length ;
      // remove DC and invert signal so that we can use peak detector as valley detector
        an_x[k] = -1*(pun_ir_buffer[k] - un_ir_mean) ;
      // 4 pt Moving Average
      for(k=0; k< BUFFER_SIZE-MA4_SIZE; k++){
        an_x[k]=( an_x[k]+an_x[k+1]+ an_x[k+2]+ an_x[k+3])/(int)4;
      // calculate threshold
      n_th1=0;
      for ( k=0 ; k<BUFFER_SIZE ;k++){
        n_th1 +=  an_x[k];
      n_th1=  n_th1/ ( BUFFER_SIZE);
      if( n_th1<30) n_th1=30; // min allowed
      if( n_th1>60) n_th1=60; // max allowed
      for ( k=0 ; k<15;k++) an_ir_valley_locs[k]=0;
      // since we flipped signal, we use peak detector as valley detector
      maxim_find_peaks( an_ir_valley_locs, &n_npks, an_x, BUFFER_SIZE, n_th1, 4, 15 );//peak_height, peak_distance, max_num_peaks
      n_peak_interval_sum =0;
      if (n_npks>=2){
        for (k=1; k<n_npks; k++) n_peak_interval_sum += (an_ir_valley_locs[k] -an_ir_valley_locs[k -1] ) ;
        n_peak_interval_sum =n_peak_interval_sum/(n_npks-1);
        *pn_heart_rate =(int32_t)( (FreqS*60)/ n_peak_interval_sum );
        *pch_hr_valid  = 1;
      else  {
        *pn_heart_rate = -999; // unable to calculate because # of peaks are too small
        *pch_hr_valid  = 0;
      //  load raw value again for SPO2 calculation : RED(=y) and IR(=X)
      for (k=0 ; k<n_ir_buffer_length ; k++ )  {
          an_x[k] =  pun_ir_buffer[k] ;
          an_y[k] =  pun_red_buffer[k] ;
      // find precise min near an_ir_valley_locs
      n_exact_ir_valley_locs_count =n_npks;
      //using exact_ir_valley_locs , find ir-red DC andir-red AC for SPO2 calibration an_ratio
      //finding AC/DC maximum of raw
      n_ratio_average =0;
      n_i_ratio_count = 0;
      for(k=0; k< 5; k++) an_ratio[k]=0;
      for (k=0; k< n_exact_ir_valley_locs_count; k++){
        if (an_ir_valley_locs[k] > BUFFER_SIZE ){
          *pn_spo2 =  -999 ; // do not use SPO2 since valley loc is out of range
          *pch_spo2_valid  = 0;
          return;
      // find max between two valley locations
      // and use an_ratio betwen AC compoent of Ir & Red and DC compoent of Ir & Red for SPO2
      for (k=0; k< n_exact_ir_valley_locs_count-1; k++){
        n_y_dc_max= -16777216 ;
        n_x_dc_max= -16777216;
        if (an_ir_valley_locs[k+1]-an_ir_valley_locs[k] >3){
            for (i=an_ir_valley_locs[k]; i< an_ir_valley_locs[k+1]; i++){
              if (an_x[i]> n_x_dc_max) {n_x_dc_max =an_x[i]; n_x_dc_max_idx=i;}
              if (an_y[i]> n_y_dc_max) {n_y_dc_max =an_y[i]; n_y_dc_max_idx=i;}
          n_y_ac= (an_y[an_ir_valley_locs[k+1]] - an_y[an_ir_valley_locs[k] ] )*(n_y_dc_max_idx -an_ir_valley_locs[k]); //red
          n_y_ac=  an_y[an_ir_valley_locs[k]] + n_y_ac/ (an_ir_valley_locs[k+1] - an_ir_valley_locs[k])  ;
          n_y_ac=  an_y[n_y_dc_max_idx] - n_y_ac;    // subracting linear DC compoenents from raw
          n_x_ac= (an_x[an_ir_valley_locs[k+1]] - an_x[an_ir_valley_locs[k] ] )*(n_x_dc_max_idx -an_ir_valley_locs[k]); // ir
          n_x_ac=  an_x[an_ir_valley_locs[k]] + n_x_ac/ (an_ir_valley_locs[k+1] - an_ir_valley_locs[k]);
          n_x_ac=  an_x[n_y_dc_max_idx] - n_x_ac;      // subracting linear DC compoenents from raw
          n_nume=( n_y_ac *n_x_dc_max)>>7 ; //prepare X100 to preserve floating value
          n_denom= ( n_x_ac *n_y_dc_max)>>7;
          if (n_denom>0  && n_i_ratio_count <5 &&  n_nume != 0)
            an_ratio[n_i_ratio_count]= (n_nume*100)/n_denom ; //formular is ( n_y_ac *n_x_dc_max) / ( n_x_ac *n_y_dc_max) ;
            n_i_ratio_count++;
      // choose median value since PPG signal may varies from beat to beat
      maxim_sort_ascend(an_ratio, n_i_ratio_count);
      n_middle_idx= n_i_ratio_count/2;
      if (n_middle_idx >1)
        n_ratio_average =( an_ratio[n_middle_idx-1] +an_ratio[n_middle_idx])/2; // use median
        n_ratio_average = an_ratio[n_middle_idx ];
      if( n_ratio_average>2 && n_ratio_average <184){
        n_spo2_calc= uch_spo2_table[n_ratio_average] ;
        *pn_spo2 = n_spo2_calc ;
        *pch_spo2_valid  = 1;//  float_SPO2 =  -45.060*n_ratio_average* n_ratio_average/10000 + 30.354 *n_ratio_average/100 + 94.845 ;  // for comparison with table
      else{
        *pn_spo2 =  -999 ; // do not use SPO2 since signal an_ratio is out of range
        ret = app_usbd_power_events_enable();
       // Enter main loop
        for (;;)
          while (app_usbd_event_queue_process())
             sendcom("hello");
            idle_state_handle();
  • Looking briefly through the code you shared this seems not to be the case in your functions Read, Send and Samplesready, at least.
    ok i want to check that
