BLE_GAP_EVT_SEC_REQUEST event missing?
Hello everyone,
1st of all, thank you for taking your time to have a look over my "problem".
I have a device that I am working on, that acts as aperipheral, it is a non NRF one.
I also have a NRF52DK that I am using to develop the central device for my peripheral.
In the central (NRF52DK), for connection, I am scanning for Local Name (shortened local name never works for me).
Immediately after a connection is estabilished, from peripheral I issue a BLE_GAP_EVT_SEC_REQUEST, that is visible on the sniffer log, but I seem to get no event in the central device at ble_evt_handler level.
Probably I am completely missing something, but please, can anyone help me out finding out what am I missing?
Thank you in advance,
Victor
  • Changing #define NRF_LOG_DEFAULT_LEVEL 4 in sdk_config.h file and using unchanged main.c file you attached.
    changing the name and adding authenticate in blinky peripheral example at the connected event as below
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                bsp_board_led_on(CONNECTED_LED);
                bsp_board_led_off(ADVERTISING_LED);
                err_code = app_button_enable();
                sd_ble_gap_authenticate(m_conn_handle, &sec_params );
    I get the event you said is missing in your end.
    <debug> nrf_ble_gq: Registering connection handle: 0x0000
    <debug> ble_db_disc: Starting discovery of service with UUID 0x1523 on connection handle 0x0.
    <debug> nrf_ble_gq: Adding item to the request queue
    <debug> nrf_ble_gq: GATTC Primary Services Discovery Request
    <debug> nrf_ble_gq: SD GATT procedure (2) succeeded on connection handle: 0.
    <debug> app: security requested
    <debug> ble_db_disc: Found service UUID 0x1523.
    <debug> nrf_ble_gq: GATTC Characteristic Discovery Request
    <debug> nrf_ble_gq: SD GATT procedure (3) succeeded on connection handle: 0.
    <debug> nrf_ble_gq: Processing the request queue...
    <debug> nrf_ble_gq: GATTC Characteristic Descriptor Request
    <debug> nrf_ble_gq: SD GATT procedure (4) succeeded on connection handle: 0.
    <debug> ble_db_disc: Discovery of service with UUID 0x1523 completed with success on connection handle 0x0.
    <debug> ble_lbs_c: LED Button Service discovered at peer.
    <info> app: LED Button service discovered on conn_handle 0x0.
    <debug> ble_lbs_c: Configuring CCCD. CCCD Handle = 14, Connection Handle = 0
    <debug> nrf_ble_gq: GATTC Write Request
    <debug> nrf_ble_gq: SD GATT procedure (1) succeeded on connection handle: 0.
  • Hello Susheel,
    thank you for your reply.
    This means you get the case at the lines 285-290 in my main.c hit?
  • Yes, please see the log i attached in my previous reply
  • but of course you get it hit, I can see it in the log.
    Thank you for your time!
  • one more thing, in order to get an automatic response to that security request, do I have to enable PM?
