Starting a new thread from a BLE callback
I have a BLE service:
BT_GATT_SERVICE_DEFINE(lres_svc,
    BT_GATT_PRIMARY_SERVICE(BT_UUID_LRES),
    BT_GATT_CHARACTERISTIC(BT_UUID_LRES_STAT, BT_GATT_CHRC_NOTIFY,
                   BT_GATT_PERM_NONE, NULL, NULL, NULL),
    BT_GATT_CCC(lec_ccc_cfg_changed,
            BT_GATT_PERM_READ | BT_GATT_PERM_WRITE),
    BT_GATT_CHARACTERISTIC(BT_UUID_LRES_EXP, BT_GATT_CHRC_WRITE,
                   BT_GATT_PERM_WRITE, NULL, exp_settings_cb, NULL),
In the callback exp_settings_cb I would like to start a new thread, which I tried to do like this: First I defined stack size etc:
#define STACK_SIZE 1024
#define MY_PRIORITY 7
K_THREAD_STACK_DEFINE(stack_area, STACK_SIZE);
void testThread1(void *a, void *b, void *c) {
    printk("sth\n");
    return;
The callback itself looks like this:
static ssize_t exp_settings_cb(struct bt_conn *conn, const struct bt_gatt_attr *attr,
             const void *buf, uint16_t len, uint16_t offset, uint8_t sth)
    struct k_thread thread_data;
    k_tid_t my_tid = k_thread_create(&thread_data, stack_area,
                                 K_THREAD_STACK_SIZEOF(stack_area),
                                 testThread1,
                                 NULL, NULL, NULL,
                                 MY_PRIORITY, K_USER, K_NO_WAIT);
    return 0;
The problem is when I trigger the callback by writing to the corresponding characteristic I get:
00> [00:00:13.605,834] <err> os: ***** MPU FAULT *****
00> [00:00:13.605,865] <err> os:   Instruction Access Violation
00> [00:00:13.605,865] <err> os: r0/a1:  0x20000bd0  r1/a2:  0x20000bd0  r2/a3:  0x20000b68
00> [00:00:13.605,865] <err> os: r3/a4:  0x00000401 r12/ip:  0x20000bc0 r14/lr:  0x200001ec
00> [00:00:13.605,865] <err> os:  xpsr:  0x00000000
00> [00:00:13.605,865] <err> os: Faulting instruction address (r15/pc): 0x200001ec
00> [00:00:13.605,865] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
00> [00:00:13.605,895] <err> os: Current thread: 0x200051f0 (unknown)
00> [00:00:13.828,582] <err> os: Halting system
00> [00:00:00.609,588] <inf> sx127x: SX127x version 0x12 found
00> *** Booting Zephyr OS version 2.5.99  ***
After I included
CONFIG_USERSPACE=y
CONFIG_MAIN_STACK_SIZE=4096
into my prj.conf I got a different error:
00> [00:00:17.488,342] <err> os: ***** HARD FAULT *****
00> [00:00:17.488,342] <err> os:   Fault escalation (see below)
00> [00:00:17.488,342] <err> os: ***** MPU FAULT *****
00> [00:00:17.488,372] <err> os:   Stacking error (context area might be not valid)
00> [00:00:17.488,372] <err> os:   Data Access Violation
00> [00:00:17.488,372] <err> os:   MMFAR Address: 0x200099d0
00> [00:00:17.488,372] <err> os: r0/a1:  0x200089d8  r1/a2:  0x0000efed  r2/a3:  0x20001ff4[0m
00> [00:00:17.488,372] <err> os: r3/a4:  0x00000000 r12/ip:  0x00000001 r14/lr:  0x00000000
00> [00:00:17.488,403] <err> os:  xpsr:  0x2001863c
00> [00:00:17.488,403] <err> os: Faulting instruction address (r15/pc): 0x20000fa4
00> [00:00:17.488,403] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
00> [00:00:17.488,403] <err> os: Fault during interrupt handling
The thread creation works perfectly fine when trying it inside main though.
I would greatly appreciate any insights that might help solve this problem.
Thank you!
