ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:307 k_sem_take failed with err -11
I'm working on developing a device using the nrf52832. Currently using the nrf52 PCA10040 dev kit. I'm extending the zephyr/samples/basic/peripheral_dis sample in order to add my own custom services following this tutorial:
https://devzone.nordicsemi.com/nordic/nrf-connect-sdk-guides/b/getting-started/posts/ncs-ble-tutorial-part-1-custom-service-in-peripheral-role#h91sk6jev0m61soqa11se592hnbntfb
However, I'm getting a hard fail on boot up when I add the custom service to the perhiperal_dis sample. The program compiles and flashes just fine, but when my device boots up it hangs for a bit, then resets with the following error:
I've tried emptying out my main function completely, removing any Bluetooth configurations, and I'm still getting the same failure.
My suspicion is that it has to do with an improper config. Below is my prj.conf. Can I get feedback on if this is the correct configuration for adding multiple services, including the device information service?
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_MAX_CONN=1
CONFIG_BT_L2CAP_TX_BUF_COUNT=5
CONFIG_BT_DEVICE_APPEARANCE=962
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT_DIS=y
CONFIG_BT_DIS_PNP=n
CONFIG_BT_DIS_MODEL="STEEL"
CONFIG_BT_DIS_MANUF="HidrateSpark"
CONFIG_BT_DIS_SERIAL_NUMBER=n
CONFIG_BT_DIS_FW_REV=y
CONFIG_BT_DIS_HW_REV=y
CONFIG_BT_DIS_SW_REV=n
CONFIG_BT_DIS_FW_REV_STR="80.0"
CONFIG_BT_DIS_HW_REV_STR="1.0"
CONFIG_BT_DEVICE_NAME="h2o12345"
# Below is setup to let DIS information be read from settings
CONFIG_BT_SETTINGS=y
CONFIG_SETTINGS_RUNTIME=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NONE=y
CONFIG_BT_DIS_SETTINGS=y
CONFIG_BT_DIS_STR_MAX=21
