Custom SPM dependencies
We need to add secure services to our application, and I followed the guide in https://devzone.nordicsemi.com/nordic/nrf-connect-sdk-guides/b/software/posts/using-a-custom-secure-partition-manager-wtih-your-application
However the build fails because:
C:/Nordic/v1.5.0/nrf/subsys/nonsecure/secure_services_ns.c:26: undefined reference to `spm_request_random_number_nse'
collect2.exe: error: ld returned 1 exit status
It seems that it is expecting a function that generates secure random numbers (which we do not need this in our project). Searching for
this function call, it is defined in nrf/subsys/spm\secure_services.c and available if CONFIG_SPM_SERVICE_RNG is set.
I explicitly disable this config option (CONFIG_SPM_SERVICE_RNG=n) in the prj.conf off both the application and the custom SPM,
but it still appears to be set somewhere else. Where is CONFIG_SPM_SERVICE_RNG set and how can I disable it ?
Or is it best to also copy the files in nrf\subsys\smp and add them to my custom SPM project ?
Parents Reply
  • I found the cause this morning, while trying to figure out the reason behind this issue.
    Because I am using crypto functions in my non-secure app, the crypto library needs an entropy source from the secure side. This is implemented as a secure service, in function "`spm_request_random_number_nse".
    I need to explicitly set CONFIG_SPM_SERVICE_RNG=y in the custom SPM prj.conf, so that it gets build in the SPM image and can latter be used by the non-secure application.
    Because I do not use an entropy source, I believed it was not needed. But it turns out it is required by the crypto library. Hence the confusion.
