Please tell me how to connect one nRF51822 and another as Central and Peripheral. In the future, I would like to connect one Central and multiple Peripheral.
I am new to BLE.
My question is similar to the one below.
https://devzone.nordicsemi.com/f/nordic-q-a/22596/nrf51822-central-connect-and-communicate-with-2-peripherals
But the link to the answer was broken and I couldn't find it, so I'll ask.
I am using two nRF51822 and SDK12.3.0. I want to run them as Central on one side and Peripheral on the other.
Probably by a method called GATT communication.(It means communication in a connected state.)
My goal is to record  RSSI and receiving time in Central when it receives an empty packet from Peripheral.
I would like to receive packets at intervals of 1msec to 10msec,
so advertising with long transmission intervals and randomly staggered transmission times would not achieve my goal.
In the future, I would like to receive packets from about 6 peripherals and record the RSSI of the packets.
Please let me know if there is a sample program or code that fits my purpose.
I'm not very good at English, so I use translation software to create my texts. I'm sorry if I don't make sense in some parts.
  • I can't remember how you get it when connected
    But a quick forum search for "RSSI while connected" finds:
    devzone.nordicsemi.com/.../308793
  • I'll try to find some of the links you gave me.
  • I looked up how to get RSSI after your advice.
    https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v12.0.0%2Fble_sdk_app_multilink.html&cp=4_0_0_4_2_0_1
    I tried to check the connection by referring to the links "ble_app_multilink_central" and "ble_app_blinky", but due to the different specifications of the evaluation board, I could not see the LED blinking and could not check the connection state.
    So I tried to check the connection state by using "ble_app_multilink_central" and "ble_app_hrs", referring to the following links.
    https://devzone.nordicsemi.com/f/nordic-q-a/48256/how-to-get-rssi-of-peripheral-during-connection
    I used "sd_ble_gap_rssi_get()", but it didn't show anything on teraterm.
    I added "sd_ble_gap_rssi_start()" etc. to "on_ble_evt" in line 372.
    Please point out how I can improve it?
     * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief BLE LED Button Service central and client application main file.
     * This example can be a central for up to 8 peripherals.
     * The peripheral is called ble_app_blinky and can be found in the ble_peripheral
     * folder.
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "softdevice_handler.h"
    #include "app_timer.h"
    #include "boards.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "app_uart.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_db_discovery.h"
    #include "ble_lbs_c.h"
    #include "ble_conn_state.h"
    #define NRF_LOG_MODULE_NAME "APP"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #if (NRF_SD_BLE_API_VERSION == 3)
    #define NRF_BLE_MAX_MTU_SIZE      GATT_MTU_SIZE_DEFAULT                      /**< MTU size used in the softdevice enabling and to reply to a BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event. */
    #define CENTRAL_LINK_COUNT        8                                          /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT     0                                          /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
    #define TOTAL_LINK_COUNT          CENTRAL_LINK_COUNT + PERIPHERAL_LINK_COUNT /**< Total number of links used by the application. */
    #define CENTRAL_SCANNING_LED      BSP_BOARD_LED_0
    #define CENTRAL_CONNECTED_LED     BSP_BOARD_LED_1
    #define APP_TIMER_PRESCALER       0                                          /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_MAX_TIMERS      (2 + BSP_APP_TIMERS_NUMBER)                  /**< Maximum number of timers used by the application. */
    #define APP_TIMER_OP_QUEUE_SIZE   2                                          /**< Size of timer operation queues. */
    #define SCAN_INTERVAL             0x00A0                                     /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW               0x0050                                     /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_TIMEOUT              0x0000                                     /**< Timout when scanning. 0x0000 disables timeout. */
    #define MIN_CONNECTION_INTERVAL   MSEC_TO_UNITS(7.5, UNIT_1_25_MS)           /**< Determines minimum connection interval in milliseconds. */
    #define MAX_CONNECTION_INTERVAL   MSEC_TO_UNITS(30, UNIT_1_25_MS)            /**< Determines maximum connection interval in milliseconds. */
    #define SLAVE_LATENCY             0                                          /**< Determines slave latency in terms of connection events. */
    #define SUPERVISION_TIMEOUT       MSEC_TO_UNITS(4000, UNIT_10_MS)            /**< Determines supervision time-out in units of 10 milliseconds. */
    #define UUID16_SIZE               2                                          /**< Size of a UUID, in bytes. */
    #define LEDBUTTON_LED             BSP_BOARD_LED_2                            /**< LED to indicate a change of state of the the Button characteristic on the peer. */
    #define LEDBUTTON_BUTTON_PIN      BSP_BUTTON_0                               /**< Button that will write to the LED characteristic of the peer */
    #define BUTTON_DETECTION_DELAY    APP_TIMER_TICKS(50, APP_TIMER_PRESCALER)   /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    static const char m_target_periph_name[] = "Nordic_HRM";                  /**< Name of the device we try to connect to. This name is searched for in the scan report data*/
    /** @brief Scan parameters requested for scanning and connection. */
    static const ble_gap_scan_params_t m_scan_params =
        .active   = 0,
        .interval = SCAN_INTERVAL,
        .window   = SCAN_WINDOW,
        .timeout  = SCAN_TIMEOUT,
        #if (NRF_SD_BLE_API_VERSION == 2)
            .selective   = 0,
            .p_whitelist = NULL,
            .use_whitelist  = 0,
            .adv_dir_report = 0,
    /**@brief Connection parameters requested for connection. */
    static const ble_gap_conn_params_t m_connection_param =
        (uint16_t)MIN_CONNECTION_INTERVAL,
        (uint16_t)MAX_CONNECTION_INTERVAL,
        (uint16_t)SLAVE_LATENCY,
        (uint16_t)SUPERVISION_TIMEOUT
    static ble_lbs_c_t        m_ble_lbs_c[TOTAL_LINK_COUNT];           /**< Main structures used by the LED Button client module. */
    static uint8_t            m_ble_lbs_c_count;                       /**< Keeps track of how many instances of LED Button client module have been initialized. >*/
    static ble_db_discovery_t m_ble_db_discovery[TOTAL_LINK_COUNT];    /**< list of DB structures used by the database discovery module. */
    /**@brief Function to handle asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
        bsp_board_leds_init();
     * @brief Parses advertisement data, providing length and location of the field in case
     *        matching data is found.
     * @param[in]  type       Type of data to be looked for in advertisement data.
     * @param[in]  p_advdata  Advertisement report length and pointer to report.
     * @param[out] p_typedata If data type requested is found in the data report, type data length and
     *                        pointer to data will be populated here.
     * @retval NRF_SUCCESS if the data type is found in the report.
     * @retval NRF_ERROR_NOT_FOUND if the data type could not be found.
    static uint32_t adv_report_parse(uint8_t type, uint8_array_t * p_advdata, uint8_array_t * p_typedata)
        uint32_t  index = 0;
        uint8_t * p_data;
        p_data = p_advdata->p_data;
        while (index < p_advdata->size)
            uint8_t field_length = p_data[index];
            uint8_t field_type   = p_data[index + 1];
            if (field_type == type)
                p_typedata->p_data = &p_data[index + 2];
                p_typedata->size   = field_length - 1;
                return NRF_SUCCESS;
            index += field_length + 1;
        return NRF_ERROR_NOT_FOUND;
    /**@brief Function to start scanning.
    static void scan_start(void)
        ret_code_t ret;
        (void) sd_ble_gap_scan_stop();
        NRF_LOG_INFO("Start scanning for device name %s.\r\n", (uint32_t)m_target_periph_name);
        ret = sd_ble_gap_scan_start(&m_scan_params);
        APP_ERROR_CHECK(ret);
        ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Handles events coming from the LED Button central module.
     * @param[in] p_lbs_c     The instance of LBS_C that triggered the event.
     * @param[in] p_lbs_c_evt The LBS_C event.
    static void lbs_c_evt_handler(ble_lbs_c_t * p_lbs_c, ble_lbs_c_evt_t * p_lbs_c_evt)
        switch (p_lbs_c_evt->evt_type)
            case BLE_LBS_C_EVT_DISCOVERY_COMPLETE:
                ret_code_t err_code;
                NRF_LOG_INFO("LED Button service discovered on conn_handle 0x%x\r\n",
                        p_lbs_c_evt->conn_handle);
                err_code = app_button_enable();
                // LED Button service discovered. Enable notification of Button.
                err_code = ble_lbs_c_button_notif_enable(p_lbs_c);
            } break; // BLE_LBS_C_EVT_DISCOVERY_COMPLETE
            case BLE_LBS_C_EVT_BUTTON_NOTIFICATION:
                NRF_LOG_INFO("Link 0x%x, Button state changed on peer to 0x%x\r\n",
                               p_lbs_c_evt->conn_handle,
                               p_lbs_c_evt->params.button.button_state);
                if (p_lbs_c_evt->params.button.button_state)
                    bsp_board_led_on(LEDBUTTON_LED);
                    bsp_board_led_off(LEDBUTTON_LED);
            } break; // BLE_LBS_C_EVT_BUTTON_NOTIFICATION
                // No implementation needed.
    																																											APP_TIMER_DEF(my_timer_id1);
        #define BATTERY_LEVEL_MEAS_INTERVAL      APP_TIMER_TICKS(10, APP_TIMER_PRESCALER)  /**< Battery level measurement interval (ticks). */
        #include "nrf_drv_clock.h"
        #include "nrf.h"
        #include "nrf_delay.h"
        #define 	APP_TIMER_CLOCK_FREQ   32768
        static void repeated_timer_handler(void * p_context)
        uint32_t 	nrf_drv_gpiote_out_toggle();
        //nrf_drv_gpiote_out_toggle(LED_1);
        //cnt++;
        static void timers_init(void)
        uint32_t              err_code;
        // Create timers.
        err_code = app_timer_create(&my_timer_id1,APP_TIMER_MODE_REPEATED, repeated_timer_handler);
        // Start application timers.
        err_code = app_timer_start(my_timer_id1, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    /**@brief Function for handling the advertising report BLE event.
     * @param[in] p_ble_evt  Bluetooth stack event.
    static void on_adv_report(const ble_evt_t * const p_ble_evt)
        uint32_t      err_code;
        uint8_array_t adv_data;
        uint8_array_t dev_name;
        bool          do_connect = false;
        // For readibility.
        const ble_gap_evt_t * const p_gap_evt    = &p_ble_evt->evt.gap_evt;
        const ble_gap_addr_t  * const peer_addr  = &p_gap_evt->params.adv_report.peer_addr;
        // Initialize advertisement report for parsing
        adv_data.p_data = (uint8_t *)p_gap_evt->params.adv_report.data;
        adv_data.size   = p_gap_evt->params.adv_report.dlen;
        //search for advertising names
        bool found_name = false;
        err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME,
                                    &adv_data,
                                    &dev_name);
        if (err_code != NRF_SUCCESS)
            // Look for the short local name if it was not found as complete
            err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME, &adv_data, &dev_name);
                // If we can't parse the data, then exit
                return;
                found_name = true;
            found_name = true;
        if (found_name)
            if (strlen(m_target_periph_name) != 0)
                if (memcmp(m_target_periph_name, dev_name.p_data, dev_name.size) == 0)
                    do_connect = true;
        if (do_connect)
            // Initiate connection.
            err_code = sd_ble_gap_connect(peer_addr, &m_scan_params, &m_connection_param);
                NRF_LOG_ERROR("Connection Request Failed, reason %d\r\n", err_code);
    /**@brief Function for handling BLE Stack events concerning central applications.
     * @details This function keeps the connection handles of central applications up-to-date. It
     *          parses scanning reports, initiating a connection attempt to peripherals when a
     *          target UUID is found, and manages connection parameter update requests. Additionally,
     *          it updates the status of LEDs used to report central applications activity.
     * @note Since this function updates connection handles, @ref BLE_GAP_EVT_DISCONNECTED events
     *       should be dispatched to the target application before invoking this function.
    static void on_ble_evt(const ble_evt_t * const p_ble_evt)
        // For readability.
    																																																											int8_t p_rssi;
    																																																										 int8_t rssi = p_ble_evt->evt.gap_evt.params.adv_report.rssi;
    																																																											sd_ble_gap_rssi_start(p_ble_evt->evt.gap_evt.conn_handle, 0 , 0);
    																																																											//uint16_t ch_index = p_ble_evt->evt.gap_evt.params.rssi_changed.ch_index;
    																			//sd_ble_gap_rssi_get(p_ble_evt->evt.gap_evt.conn_handle,&p_ble_evt->evt.gap_evt.params.rssi_changed.rssi,*p_ch_index);
        // On the connection event
        uint32_t m_conn_handle  = p_ble_evt->evt.gap_evt.conn_handle;
        err_code = sd_ble_gap_rssi_start(m_conn_handle, 10, 0);
            // Upon connection, check which peripheral has connected, initiate DB
            // discovery, update LEDs status and resume scanning if necessary.
            case BLE_GAP_EVT_CONNECTED:
    					//On the RSSI_CHANGED event
        err_code = sd_ble_gap_rssi_get(m_conn_handle, &rssi);
     //NRF_LOG_INFO("RSSI: %d", p_ble_evt->evt.gap_evt.params.adv_report.rssi);
    																																																										 printf("%d,", rssi);//RSSi
    																																																										 double timenow = app_timer_cnt_get();
    																																																										 printf("%f,\r\n", (double) timenow); //nowtime
               // NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.\r\n",
               //              p_gap_evt->conn_handle);
               // APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < TOTAL_LINK_COUNT);
                err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c[p_gap_evt->conn_handle],
                                                    p_gap_evt->conn_handle,
                                                    NULL);
                err_code = ble_db_discovery_start(&m_ble_db_discovery[p_gap_evt->conn_handle],
               // if (err_code != NRF_ERROR_BUSY)
                 //   APP_ERROR_CHECK(err_code);
                // Update LEDs status, and check if we should be looking for more
                // peripherals to connect to.
                bsp_board_led_on(CENTRAL_CONNECTED_LED);
                //if (ble_conn_state_n_centrals() == CENTRAL_LINK_COUNT)
                 bsp_board_led_off(CENTRAL_SCANNING_LED);
                //else
                    // Resume scanning.
                 //   bsp_board_led_on(CENTRAL_SCANNING_LED);
               //     scan_start();
            } break; // BLE_GAP_EVT_CONNECTED
            // Upon disconnection, reset the connection handle of the peer which disconnected, update
            // the LEDs status and start scanning again.
                uint32_t central_link_cnt; // Number of central links.
                NRF_LOG_INFO("LBS central link 0x%x disconnected (reason: 0x%x)\r\n",
                             p_gap_evt->params.disconnected.reason);
                err_code = app_button_disable();
                // Start scanning
                scan_start();
                // Update LEDs status.
                central_link_cnt = ble_conn_state_n_centrals();
                if (central_link_cnt == 0)
                    bsp_board_led_off(CENTRAL_CONNECTED_LED);
            } break;
            case BLE_GAP_EVT_ADV_REPORT:
                on_adv_report(p_ble_evt);
            case BLE_GAP_EVT_TIMEOUT:
                // We have not specified a timeout for scanning, so only connection attemps can timeout.
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_DEBUG("Connection request timed out.\r\n");
            } break;
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accept parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                            &p_gap_evt->params.conn_param_update_request.conn_params);
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
                NRF_LOG_DEBUG("GATT Client Timeout.\r\n");
            } break;
            case BLE_GATTS_EVT_TIMEOUT:
                NRF_LOG_DEBUG("GATT Server Timeout.\r\n");
            } break;
            case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
                err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                           NRF_BLE_MAX_MTU_SIZE);
                break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
    /**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
     * @details This function is called from the scheduler in the main loop after a BLE stack event has
     * been received.
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
        uint16_t conn_handle;
        ble_conn_state_on_ble_evt(p_ble_evt);
        // Make sure taht an invalid connection handle are not passed since
        // our array of modules is bound to TOTAL_LINK_COUNT.
        if (conn_handle < TOTAL_LINK_COUNT)
            ble_db_discovery_on_ble_evt(&m_ble_db_discovery[conn_handle], p_ble_evt);
            ble_lbs_c_on_ble_evt(&m_ble_lbs_c[conn_handle], p_ble_evt);
    /**@brief LED Button collector initialization.
    static void lbs_c_init(void)
        uint32_t         err_code;
        ble_lbs_c_init_t lbs_c_init_obj;
        lbs_c_init_obj.evt_handler = lbs_c_evt_handler;
        for (m_ble_lbs_c_count = 0; m_ble_lbs_c_count < TOTAL_LINK_COUNT; m_ble_lbs_c_count++)
            err_code = ble_lbs_c_init(&m_ble_lbs_c[m_ble_lbs_c_count], &lbs_c_init_obj);
     * @details Initializes the SoftDevice and the BLE event interrupts.
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        // Use the max config: 8 central, 0 periph, 10 VS UUID
        ble_enable_params.common_enable_params.vs_uuid_count = 10;
        // Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
        err_code = softdevice_enable(&ble_enable_params);
        // Register with the SoftDevice handler module for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    /**@brief Function to write to the LED characterestic of all connected clients.
     * @details Based on if the button is pressed or released, we write a high or low LED status to
     *          the server.
     * @param[in] button_action The button action (press/release).
     *            Determines if the LEDs of the servers will be ON or OFF.
     * @return NRF_SUCCESS on success, else the error code from ble_lbs_led_status_send.
    static uint32_t led_status_send_to_all(uint8_t button_action)
        uint32_t err_code;
        for (uint32_t i = 0; i< CENTRAL_LINK_COUNT; i++)
            err_code = ble_lbs_led_status_send(&m_ble_lbs_c[i], button_action);
            if (err_code != NRF_SUCCESS &&
                err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                err_code != NRF_ERROR_INVALID_STATE)
                return err_code;
            return NRF_SUCCESS;
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        uint32_t err_code;
        switch (pin_no)
            case LEDBUTTON_BUTTON_PIN:
                err_code = led_status_send_to_all(button_action);
                if (err_code == NRF_SUCCESS)
                    NRF_LOG_INFO("LBS write LED state %d\r\n", button_action);
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        uint32_t err_code;
       //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, sizeof(buttons) / sizeof(buttons[0]),
                                   BUTTON_DETECTION_DELAY);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        NRF_LOG_INFO("call to ble_lbs_on_db_disc_evt for instance %d and link 0x%x!\r\n",
                        p_evt->conn_handle,
        ble_lbs_on_db_disc_evt(&m_ble_lbs_c[p_evt->conn_handle], p_evt);
    /** @brief Database discovery initialization.
    static void db_discovery_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    /** @brief Function to sleep until a BLE event is received by the application.
    static void power_manage(void)
        ret_code_t err_code = sd_app_evt_wait();
        err_code = NRF_LOG_INIT(NULL);
        NRF_LOG_INFO("Multilink Example\r\n");
        leds_init();
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL);
        buttons_init();
        ble_stack_init();
        db_discovery_init();
        lbs_c_init();
        // Start scanning for peripherals and initiate connection to devices which
        // advertise.
        scan_start();
        // Turn on the LED to signal scanning.
        for (;;)
                // Wait for BLE events.
                power_manage();
    Nothing at all? You don't see e.g. "Multilink Example" printed either?
    Also, I see you have
    Try using NRF_LOG_INFO instead
    NRF_LOG_INFO("RSSI: %d",rssi);
  • Thanks for your response.
    Yes. Perhaps my "central" and "peripheral" have not moved to the connected state.
    I tried "NRF_LOG_INFO", but the result was the same.
    My project's "Perpheral", "ble_app_hrs", is still the default in SDK12.3.0, is there any inconvenience?
