[Zigbee] Multiple Temperature Clusters in the same device
How can I have two or more temperature probes reporting using the ZCL library?
Imagine that I want to have a device that measures for instance two temperatures at two different locations (Inside/Outside a fridge). How can I report these two temperatures? I learned that each application can have a set of clusters, but can I have duplicated clusters in the same application? If so, how can I do that?
The cluster that I want to use is the temperature measurement (0x0402).
Thanks in advance,
Fernando
  • Hi Marjeris,
    Thank you for the reply.
    All that you said makes sense. However, my application requires some specific measurements not covered by the ZCL specification. So, I already went for that road and after some fight, I have already created my own customized cluster.
    I'm a bit new to Zigbee and I have some questions that maybe you can help me with.
    I have two development kits, one running an end-device (with my customized cluster) and another one running the CLI configured as a coordinator.
    How can I discover the device source address and the containing endpoints without knowing in advance the profile ID and the implemented clusters? I know the existence of the zdo match_desc command but that requires me to fill the profile ID and also the implemented clusters....
    Another thing is, after running zdo simple_desc_req 0xF700 20 I get src_addr=0xF700 ep=20 profile_id=0x0104 app_dev_id=0xFFF2 app_dev_ver=0x0 in_clusters=0x0000,0x0003,0x0402,0x1234 out_clusters=0x0003, being the 0x1234 cluster-ID the one that I have customized. Well, my first question is, should I change the profile ID from the home automation to the manufacturer-specific profile? Or it's fine keeping the HA? My second question is if there is any command to request the attributes that a given cluster contains? Or this should be known in advance by looking at the ZCL specification? And what about the attribute type?
    Fernando Fontes
    You only need to fill the profile id for 'zdo match_desc', which usually is either Zigbee Light Link (0xc05e) or the Home Automation profile (0x0104) at least for lighting devices. The number of input cluster or output clusters argument is just so you can sort it in case you need to find a device with at least one of n_input clusters. All devices should have at least the basic cluster, so you could send a match descriptor request requiring for devices with at least the Basic cluster implementation if you want a list of all devices.
    The other way would be to use a zigbee sniffer and look at the devices available on the network.
     I think manufacturer-specific profiles will need to be register with the Zigbee Alliance. You can create a custom cluster inside the HA profile. If you need a custom profile is up to you and your implementation. Please refer to the Zigbee Alliance for more information on this. From what I read private profiles are usually implemented for applications that do not need to interact with other vendors' products.
     The closer thing we have is 'zcl attr read', but this is for reading the values of a given attributes. I cannot see to find anything about attribute discovery in the specification, but you could check for yourself as well, to see if this is even possible. For cluster on the ZCL specification each attribute is documented on the specification, also with the attribute type. For custom cluster you will need to document this yourself I suppose.
    Marjeris
  • Hi Marjeris,
    Thank you for the help.
    One last question though: What about the clusters IDs? Is there any rule to choose a cluster ID for my own cluster implementation?
    Best regards.
     No, I don't think so :) just don't use one of the IDs already used in the ZCL specification.
