Hello World Hard Fault When Executed from mcuboot
I am trying to have mcuboot in Zephyr to execute the hello world sample (mcuboot\samples\zephyr\hello-world).
I generated the bin for hello world and signed it as shown below:
python.exe .\imgtool.py sign --key <my_path>\bootloader\mcuboot\root-rsa-2048.pem --header-size 0x200 --align 8 --version 1.2 --slot-size 0x60000 --pad-header <my_path>\bootloader\mcuboot\samples\zephyr\hello-world\build_nrf5340dk_nrf5340_cpuapp\zephyr\zephyr.bin <my_path>\bootloader\mcuboot\samples\zephyr\hello-world\build_nrf5340dk_nrf5340_cpuapp\zephyr\signed-hello.bin
I then program the signed bin to the slot0 partition which starts at address 0x10000. So far so good.
Then, I run mcuboot in Segger, it appears to validate the signed image correctly, but when it jumps to it a hard fault is generated, see below:
*** Booting Zephyr OS version 2.4.99 ***
[00:00:02.678,649] [0m<inf> mcuboot: Starting bootloader[0m
[00:00:02.679,382] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[0m
[00:00:02.679,901] [0m<inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[0m
[00:00:02.680,328] [0m<inf> mcuboot: Boot source: none[0m
[00:00:02.680,725] [0m<inf> mcuboot: Swap type: none[0m
[00:00:02.773,071] [0m<inf> mcuboot: Bootloader chainload address offset: 0x10000[0m
[00:00:02.773,437] [0m<inf> mcuboot: Jumping to the first image slot[0m
[00:00:06.367,126] [1;31m<err> os: ***** HARD FAULT *****[0m
[00:00:06.367,401] [1;31m<err> os: Fault escalation (see below)[0m
[00:00:06.367,675] [1;31m<err> os: ***** BUS FAULT *****[0m
[00:00:06.367,950] [1;31m<err> os: Precise data bus error[0m
[00:00:06.368,225] [1;31m<err> os: BFAR Address: 0xc[0m
[00:00:06.368,499] [1;31m<err> os: r0/a1: 0x24822bd9 r1/a2: 0x0eef9269 r2/a3: 0xbf1a8b0a[0m
[00:00:06.368,957] [1;31m<err> os: r3/a4: 0x8e883ccf r12/ip: 0xec0c134d r14/lr: 0xb818b317[0m
[00:00:06.369,415] [1;31m<err> os: xpsr: 0xf9e12b51[0m
[00:00:06.369,689] [1;31m<err> os: Faulting instruction address (r15/pc): 0xc5ce9894[0m
[00:00:06.370,056] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0[0m
[00:00:06.370,422] [1;31m<err> os: Fault during interrupt handling
[00:00:06.370,697] [1;31m<err> os: Current thread: (nil) (unknown)[0m
[00:00:06.376,007] [1;31m<err> os: Halting system[0m
So I think I need to better understand how the signing and addition of the header to the signed image affects the resulting binary. As mentioned, the partition for the image starts at 0x10000, so the code is linked having that as the start address. But if the header is added to the image prior to where it starts, to which address should the signed binary be flashed to? I don't think it should be flashed to 0xFF80 so the header starts there and the application at 0x10000, because that would be overlapping to the mcuboot partition. On the other hand, flashing the image to start at 0x10000 is what I'm currently doing; I think the cause of fault may be because of the shift of addresses due the addition of the header.
Thoughts?
Thanks in advance!!
  • What version of NCS are you using? I just tested this with NCS v1.5.0 opened through the Toolchain Manager:
    • To get the hello-world, I clicked on the three dots left of the "Projects" field and chose C:\Users\<user name>\ncs\v1.5.0\bootloader\mcuboot\samples\zephyr\hello-world
    • Notice that I change the build name to "build" instead of "build_nrf5340dk_nrf5340_cpuapp" due to Windows Path length issues
    • I also checked "Clean Build Directory"
    • Then I clicked on "Build Solution"
    These files were then generated, including "app_update.bin"
    Can you follow the exact same steps and see if you get the same result?
    uhrm said:
    We use SES to build our applications. We don't use West so I'm not too familiar with it; still I tried but it is not recognizing the 'build' argument, see below:
     Check out 1.3.2 Build and flash to see how to build using west
    Simon
  • Hi Simon,
    I use NCS v1.5.1. So, I moved ncs to make the overall path shorter, and also shortened the build folder as you did. Followed the same steps than you and now I get the signed files! There seems to be a strong dependency on the path length though.
    Anyway, I will keep an eye on this, but for now seems to work. Thanks for the help.
  • Hi Simon,
    I have now a board programmed with the mcuboot and the smp_svr sample, and I can see the device in the nRF Connect app in an Android phone. I have signed another application that I use to test the DFU (note that this application does not currently have BLE support).
    So, I start the DFU process and in the app I am prompted to select a mode:
    - Test and Confirm
    - Test only
    - Confirm only
    When I either select 'Test and Confirm' or 'Test only' I see the download starts followed by a validation. Then after a reboot the application runs, but I see from mcuboot that the swap type is 'test'. As expected, after another reboot the device reverts and runs the smp_svr sample. If I reconnect with the phone app and do the DFU again selecting 'Confirm only', then this time the swap type will be 'permanent'. The latter is the scenario I would like to have.
    My question is, shouldn't 'Test and Confirm' download the image and make the swap permanent? If not, what is the difference between 'Test and Confirm' and 'Test', because from an outside perspective they appear to do the same thing, and only after 'Confirm only' the application is permanently swapped.
    Is there any documentation for the modes that one can select in nRF Connect?
    Thanks in advance.
    I agree with you that this seems reasonable, but I'm actually not sure about this. Could you open a new ticket and ask about this? Since the original issue "Hello World Hard Fault When Executed from mcuboot" is resolved. In addition I'll go on vacation the next week, so I won't be able to provide any answers anyway.
