NRFX SAADC does not output expected values
I'm working the nrfx saadc legacy driver, and despite changing whether I measure Vdd(on the dk) or GND, the saadc output(p_event->data.done.p_buffer[0]) oscillates between 300ish and 60,000ish, and the conversion is stuck around 830ish.
My current setup:
Board: nRF52840dk
OS: Windows
SDK: nRF SDK 17.0
IDE: Segger Embedded Studio
Attached is code that runs in the saadc example folder from the SDK. I tested my code by hooking a jumper from P(0,4) to Vdd and GND. Please let me know if there's anything I can do!
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup nrf_adc_example main.c
 * @ingroup nrf_adc_example
 * @brief ADC Example Application main file.
 * This file contains the source code for a sample application using ADC.
 * @image html example_board_setup_a.jpg "Use board setup A for this example."
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "app_error.h"
#include <nrfx_saadc.h>
#include <nrf_gpio.h>
#define BUFFER_SIZE 1
#define LED3 NRF_GPIO_PIN_MAP(0, 16)
#define LED4 NRF_GPIO_PIN_MAP(0, 15)
#define A0          NRF_GPIO_PIN_MAP(1, 12)
#define A8          NRF_GPIO_PIN_MAP(0, 4)
static nrf_saadc_value_t adcSampleBuffer[BUFFER_SIZE];
int counter = 0;
int counter1 = 0;
volatile int voltFlag = 0;
volatile nrfx_err_t err = 0;
volatile int calibrationFlag = 0;
nrfx_saadc_config_t saadc_config = NRFX_SAADC_DEFAULT_CONFIG;
nrf_saadc_channel_config_t saadc_channel_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(A8);
void nrfx_saadc_event_handler(nrfx_saadc_evt_t const* p_event){
    if (p_event->type == NRFX_SAADC_EVT_CALIBRATEDONE)
       counter = nrfx_saadc_buffer_convert(adcSampleBuffer, BUFFER_SIZE);
       calibrationFlag = 1;
    }else
      voltFlag = 1;
    nrf_gpio_cfg_output(LED3);
    nrf_gpio_cfg_output(LED4);
    counter = nrfx_saadc_init(&saadc_config, nrfx_saadc_event_handler) + 1;
    counter = nrfx_saadc_channel_init(0, &saadc_channel_config) + 1;
    counter = nrfx_saadc_calibrate_offset();
    while(calibrationFlag == 0){
    int durdle = 0;
    while(1){
        counter = nrfx_saadc_sample();
        nrf_gpio_pin_toggle(LED4);
        while(voltFlag == 0){
            err++;
            err %= 19;
            durdle ++;
            durdle %=19;
        counter1 = (counter1 + 1)%1000;
        if(counter1 == 0){
            nrf_gpio_pin_toggle(LED3);
        voltFlag = 0;
    return 0;
