Cannot combine BLE UART example with TWI example
Hi ,
I have a problem when I wanted to combine the two examples twi scanner and usbd ble uart together although they work correctly individually
I have a MAX30105 sensor which works with the twi scanner example in a correct way, I wanted to send its data through the uart
when i combine its code with the usbd ble uart example,  the sending data from sensor stops at the moment of port detection of the arduino nano 33 ble card (i am using the arduino nano 33 ble with the card nrf52840 to do external debugging on this card)
there is my main code
this is the first part of my code
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_drv_power.h"
#include "app_error.h"
#include "app_util.h"
#include "app_usbd_core.h"
#include "app_usbd.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_serial_num.h"
/*********************PPG Librairies ***********************/
#include <stdint.h>
#include <stdbool.h>
#include <stdlib.h>
#include "boards.h"
#include "nrf_drv_twi.h"
#include "nrf.h"
#include "nrf_drv_rtc.h"
/*****************************End of PPG Librairies *****************/
/**************************TWI initailisation of PPG ********************/
/* TWI instance ID. */
#if TWI0_ENABLED
#define TWI_INSTANCE_ID     0
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID     1
 /* Number of possible TWI addresses. */
#define TWI_ADDRESSES      127
/************************** End of TWI initailisation of PPG ********************/
#define LED_BLE_NUS_CONN (BSP_BOARD_LED_0)
#define LED_BLE_NUS_RX   (BSP_BOARD_LED_1)
#define LED_CDC_ACM_CONN (BSP_BOARD_LED_2)
#define LED_CDC_ACM_RX   (BSP_BOARD_LED_3)
#define LED_BLINK_INTERVAL 800
APP_TIMER_DEF(m_blink_ble);
APP_TIMER_DEF(m_blink_cdc);
 * @brief App timer handler for blinking the LEDs.
 * @param p_context LED to blink.
void blink_handler(void * p_context)
    bsp_board_led_invert((uint32_t) p_context);
#define ENDLINE_STRING "\r\n"
// USB DEFINES START
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                    app_usbd_cdc_acm_user_event_t event);
#define CDC_ACM_COMM_INTERFACE  0
#define CDC_ACM_COMM_EPIN       NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE  1
#define CDC_ACM_DATA_EPIN       NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT      NRF_DRV_USBD_EPOUT1
static char m_cdc_data_array[BLE_NUS_MAX_DATA_LEN];
/** @brief CDC_ACM class instance */
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                            cdc_acm_user_ev_handler,
                            CDC_ACM_COMM_INTERFACE,
                            CDC_ACM_DATA_INTERFACE,
                            CDC_ACM_COMM_EPIN,
                            CDC_ACM_DATA_EPIN,
                            CDC_ACM_DATA_EPOUT,
                            APP_USBD_CDC_COMM_PROTOCOL_AT_V250);
// USB DEFINES END
// BLE DEFINES START
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
#define DEVICE_NAME                     "Nordic_USBD_BLE_UART"                      /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms). Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms). Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating an event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump. Can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
/*************************Max30105**********************/
/*MX30105*/
//Spo2
#define FreqS 25    //sampling frequency
#define BUFFER_SIZE (FreqS * 4)
#define MA4_SIZE 4 // DONOT CHANGE
#define MX30105_ADDR 0x57
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
static char m_nus_data_array[BLE_NUS_MAX_DATA_LEN];
// BLE DEFINES END
/***********************Define the varibles of PPG ************************/
uint32_t example =   0x00;
int32_t BPM = 0x00;
int32_t HZ = 0x00;
int8_t finger = 0;
int8_t error = 0;
int16_t example1 = 0;
uint32_t examplered;
uint32_t examplegreen;
uint32_t exampleIR;
uint32_t validHeartRate = 0 ;
uint32_t heartRate = 0 ;
uint32_t validSPO2 = 0;
uint32_t spo2 = 0;
/******************************End of definition of varibles PPG *****************/
/* Timer Stuff */
const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(0);
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
    if (int_type == NRF_DRV_RTC_INT_COMPARE0)
         NRF_LOG_INFO("Compare event  ");
    else if (int_type == NRF_DRV_RTC_INT_TICK)
         NRF_LOG_INFO(" Tick Event ");
/** @brief Function starting the internal LFCLK XTAL oscillator.
/*static void lfclk_config(void)
{    ret_code_t err_code = nrf_drv_clock_init();
    NRF_LOG_INFO(" Low Frequency Configuration done ");
/*static void rtc_config(void)
    uint32_t err_code;
    //Initialize RTC instance
    nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
    config.prescaler = 327;
    err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
    nrf_drv_rtc_enable(&rtc);
    NRF_LOG_INFO("RTC Configuration done");
static  int32_t an_x[ BUFFER_SIZE]; //ir
static  int32_t an_y[ BUFFER_SIZE]; //red
const uint8_t uch_spo2_table[184]={ 95, 95, 95, 96, 96, 96, 97, 97, 97, 97, 97, 98, 98, 98, 98, 98, 99, 99, 99, 99,
              99, 99, 99, 99, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100,
              100, 100, 100, 100, 99, 99, 99, 99, 99, 99, 99, 99, 98, 98, 98, 98, 98, 98, 97, 97,
              97, 97, 96, 96, 96, 96, 95, 95, 95, 94, 94, 94, 93, 93, 93, 92, 92, 92, 91, 91,
              90, 90, 89, 89, 89, 88, 88, 87, 87, 86, 86, 85, 85, 84, 84, 83, 82, 82, 81, 81,
              80, 80, 79, 78, 78, 77, 76, 76, 75, 74, 74, 73, 72, 72, 71, 70, 69, 69, 68, 67,
              66, 66, 65, 64, 63, 62, 62, 61, 60, 59, 58, 57, 56, 56, 55, 54, 53, 52, 51, 50,
              49, 48, 47, 46, 45, 44, 43, 42, 41, 40, 39, 38, 37, 36, 35, 34, 33, 31, 30, 29,
              28, 27, 26, 25, 23, 22, 21, 20, 19, 17, 16, 15, 14, 12, 11, 10, 9, 7, 6, 5,
              3, 2, 1 } ;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
 * @brief TWI initialization.
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = true
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    nrf_drv_twi_enable(&m_twi);
 uint32_t redBuffer[100];
 uint32_t irBuffer[100];
 uint32_t greenBuffer[100];
 * @brief Function for assert macro callback.
 *          how your product is supposed to react in case of an assert.
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/** @brief Function for initializing the timer module. */
static void timers_init(void)
    err_code = app_timer_create(&m_blink_ble, APP_TIMER_MODE_REPEATED, blink_handler);
    err_code = app_timer_create(&m_blink_cdc, APP_TIMER_MODE_REPEATED, blink_handler);
 * @brief Function for the GAP initialization.
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
 * @brief Function for handling the data from the Nordic UART Service.
 * @details This function processes the data received from the Nordic UART BLE Service and sends
 *          it to the USBD CDC ACM module.
 * @param[in] p_evt Nordic UART Service event.
        bsp_board_led_invert(LED_BLE_NUS_RX);
        NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on CDC ACM.");
        memcpy(m_nus_data_array, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
        // Add endline characters
        uint16_t length = p_evt->params.rx_data.length;
        if (length + sizeof(ENDLINE_STRING) < BLE_NUS_MAX_DATA_LEN)
            memcpy(m_nus_data_array + length, ENDLINE_STRING, sizeof(ENDLINE_STRING));
            length += sizeof(ENDLINE_STRING);
        // Send data through CDC ACM
        ret_code_t ret = app_usbd_cdc_acm_write(&m_app_cdc_acm,
                                                m_nus_data_array,
                                                length);
        if(ret != NRF_SUCCESS)
            NRF_LOG_INFO("CDC ACM unavailable, data received: %s", m_nus_data_array);
/** @brief Function for initializing services that will be used by the application. */
    uint32_t       err_code;
    ble_nus_init_t nus_init;
 * @brief Function for handling errors from the Connection Parameters module.
    APP_ERROR_HANDLER(nrf_error);
/** @brief Function for initializing the Connection Parameters module. */
    cp_init.disconnect_on_fail             = true;
    cp_init.evt_handler                    = NULL;
 * @brief Function for putting the chip into sleep mode.
 * @note This function does not return.
    // Prepare wakeup buttons.
/** @brief Function for starting advertising. */
 * @brief Function for handling advertising events.
 * @details This function is called for advertising events which are passed to the application.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            err_code = app_timer_start(m_blink_ble,
                                       APP_TIMER_TICKS(LED_BLINK_INTERVAL),
                                       (void *) LED_BLE_NUS_CONN);
        case BLE_ADV_EVT_IDLE:
            NRF_LOG_INFO("Advertising timeout, restarting.")
            advertising_start();
 * @brief Function for handling BLE events.
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("BLE NUS connected");
            err_code = app_timer_stop(m_blink_ble);
            bsp_board_led_on(LED_BLE_NUS_CONN);
            NRF_LOG_INFO("BLE NUS disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported.
        case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
            ble_gap_data_length_params_t dl_params;
            // Clearing the struct will effectively set members to @ref BLE_GAP_DATA_LENGTH_AUTO.
            memset(&dl_params, 0, sizeof(ble_gap_data_length_params_t));
            err_code = sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle, &dl_params, NULL);
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
        case BLE_EVT_USER_MEM_REQUEST:
            err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
        case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
            ble_gatts_evt_rw_authorize_request_t  req;
            ble_gatts_rw_authorize_reply_params_t auth_reply;
            req = p_ble_evt->evt.gatts_evt.params.authorize_request;
            if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                    if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                    auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                    err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                               &auth_reply);
        } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
            // No implementation needed.
 * @brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/** @brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/** @brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, 64);
 * @brief Function for handling events from the BSP module.
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
/** @brief Function for initializing the Advertising functionality. */
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
/** @brief Function for initializing buttons and LEDs. */
static void buttons_leds_init(void)
    uint32_t err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/** @brief Function for initializing the nrf_log module. */
static void log_init(void)
/** @brief Function for placing the application in low power state while waiting for events. */
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
 * @brief Function for handling the idle state (main loop).
    UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    power_manage();
// USB CODE START
static bool m_usb_connected = false;
/** @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t */
    app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
    switch (event)
        case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
            /*Set up the first transfer*/
            ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                                   m_cdc_data_array,
                                                   1);
            UNUSED_VARIABLE(ret);
            ret = app_timer_stop(m_blink_cdc);
            APP_ERROR_CHECK(ret);
            bsp_board_led_on(LED_CDC_ACM_CONN);
            NRF_LOG_INFO("CDC ACM port opened");
        case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
            NRF_LOG_INFO("CDC ACM port closed");
            if (m_usb_connected)
                ret_code_t ret = app_timer_start(m_blink_cdc,
                                                 (void *) LED_CDC_ACM_CONN);
        case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
        case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
            ret_code_t ret;
            static uint8_t index = 0;
            index++;
            do
                if ((m_cdc_data_array[index - 1] == '\n') ||
                    (m_cdc_data_array[index - 1] == '\r') ||
                    (index >= (m_ble_nus_max_data_len)))
                    if (index > 1)
                        bsp_board_led_invert(LED_CDC_ACM_RX);
                        NRF_LOG_HEXDUMP_DEBUG(m_cdc_data_array, index);
                        NRF_LOG_INFO ( "%s" , m_cdc_data_array);
                     //   readuart(m_cdc_data_array,index)
                      //  NRF_LOG_INFO(m_cdc_data_array);
                        do
                                memcpy(m_cdc_data_array + length, ENDLINE_STRING, sizeof(ENDLINE_STRING));
                                                m_cdc_data_array,
                                                index);
                            ret = ble_nus_data_send(&m_nus,
                                                    (uint8_t *) m_cdc_data_array,
                                                    &length,
                                                    m_conn_handle);
                            if (ret == NRF_ERROR_NOT_FOUND)
                                NRF_LOG_INFO("BLE NUS unavailable, data received: %s", m_cdc_data_array);
                            if (ret == NRF_ERROR_RESOURCES)
                                NRF_LOG_ERROR("BLE NUS Too many notifications queued.");
                            if ((ret != NRF_ERROR_INVALID_STATE) && (ret != NRF_ERROR_BUSY))
                        while (ret == NRF_ERROR_BUSY);
                    index = 0;
                /*Get amount of data transferred*/
                size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
                NRF_LOG_DEBUG("RX: size: %lu char: %c", size, m_cdc_data_array[index - 1]);
                /* Fetch data until internal buffer is empty */
                                            &m_cdc_data_array[index],
                                            1);
                if (ret == NRF_SUCCESS)
                    index++;
            while (ret == NRF_SUCCESS);
static void usbd_user_ev_handler(app_usbd_event_type_t event)
    switch (event)
        case APP_USBD_EVT_DRV_SUSPEND:
        case APP_USBD_EVT_DRV_RESUME:
        case APP_USBD_EVT_STARTED:
        case APP_USBD_EVT_STOPPED:
            app_usbd_disable();
        case APP_USBD_EVT_POWER_DETECTED:
            NRF_LOG_INFO("USB power detected");
            if (!nrf_drv_usbd_is_enabled())
                app_usbd_enable();
        case APP_USBD_EVT_POWER_REMOVED:
            NRF_LOG_INFO("USB power removed");
            ret_code_t err_code = app_timer_stop(m_blink_cdc);
            bsp_board_led_off(LED_CDC_ACM_CONN);
            app_usbd_stop();
        case APP_USBD_EVT_POWER_READY:
            NRF_LOG_INFO("USB ready");
            ret_code_t err_code = app_timer_start(m_blink_cdc,
            m_usb_connected = true;
            app_usbd_start();
// USB CODE END
void sendcom(char  c[]){
         uint8_t length;
         length =strlen(c);
                                                c,
                                                length);
            NRF_LOG_INFO("Data not sent,Please Open Com to send data : %s", c);
/** @brief Application main function. */
And this is the second part of my code
/*******************************For PPG ********************/
    uint32_t Max_ADC;
    uint32_t Max_ADC2;
    uint32_t Max_ADC3;
    uint8_t address;
    uint8_t sample_data;
    uint8_t FIFO_Configuration = 0;
    uint8_t Mode_Configuration = 0;
    uint8_t SpO2_Configuration = 0;
    uint8_t RESERVED;
    uint8_t Multi_LED_Mode_Control1= 0;
    uint8_t Multi_LED_Mode_Control2= 0;
    uint8_t FIFO_Write_Pointer= 0;
    uint8_t Over_Flow_Counter= 0;
    uint8_t FIFO_Read_Pointer=0;
    uint8_t FIFO_Data_Register[288];
    uint8_t FIFO_Configuration1 = 0;
    uint8_t Mode_Configuration1 = 0;
    uint8_t SpO2_Configuration1 = 0;
    uint8_t RESERVED1;
    uint8_t Multi_LED_Mode_Control11= 0;
    uint8_t Multi_LED_Mode_Control21= 0;
    uint8_t FIFO_Write_Pointer1= 0;
    uint8_t Over_Flow_Counter1= 0;
    uint8_t FIFO_Read_Pointer1=0;
    uint8_t FIFO_Data_Register1[288];
//configuration :
   const uint8_t FIFO_Write_PointerADD = 0x04;
   const uint8_t Over_Flow_CounterADD = 0x05;
   const uint8_t FIFO_Read_PointerADD = 0x06;
   const uint8_t FIFO_Data_RegisterADD = 0x07;
   const uint8_t FIFO_ConfigurationADD = 0x08;
   const uint8_t Mode_ConfigurationADD = 0x09;
   const uint8_t SpO2_ConfigurationADD = 0x0A;
   const uint8_t RESERVEDADD = 0x0B;
   const uint8_t LED_PulseAmplitude1ADD = 0x0C;
   const uint8_t LED_PulseAmplitude2ADD = 0x0D;
   const uint8_t LED_PulseAmplitude3ADD = 0x0E;
   const uint8_t LED_PulseAmplitude4ADD = 0x0F;
   const uint8_t Multi_LED_Mode_Control1ADD = 0x11;
   const uint8_t Multi_LED_Mode_Control2ADD = 0x12;
   const uint8_t Temp_Integer = 0x1F;
   const uint8_t Temp_Fraction = 0x20; //only last 4 bits
   const uint8_t Die_Temperature_Config = 0x21; //only one bit
    //masks//
    const uint8_t SMP_AVE_MASK          =0x1F;
    const uint8_t FIFO_ROLLOVER_EN_MASK =0xEF;
    const uint8_t FIFO_A_FULL_MASK      =0xF0;
    const uint8_t SHDN_MASK             =0x7F;
    const uint8_t RESET_MASK            =0xBF;
    const uint8_t MODE_MASK             =0xF8;
    const uint8_t SPO2_ADC_RGE_MASK     =0x9F;
    const uint8_t SPO2_SR_MASK          =0xE3;
    const uint8_t LED_PW_MASK           =0xFC;
    const uint8_t SLOT1_MASK            =0xF8;
    const uint8_t SLOT2_MASK            =0x8F;
    const uint8_t SLOT3_MASK            =0xF8;
    const uint8_t SLOT4_MASK            =0x8F;
      // test variables
    uint8_t masked =    0x00; // too
    uint8_t notshifted= 0x01;
    uint8_t shifted =   0x00;
    uint8_t ReadySamples = 0x00;
     //Configuration of MAX30105                         Heart Rate   -------  SPO2
     uint8_t SMP_AVE          =0x00;
     uint8_t FIFO_ROLLOVER_EN =0x00;
     uint8_t FIFO_A_FULL      =0x00 ;
     uint8_t SHDN             =0x00 ;
     uint8_t RESET            =0x00 ;
     uint8_t MODE             =0x00 ;
     uint8_t SPO2_ADC_RGE     =0x00 ;
     uint8_t SPO2_SR          =0x00 ;
     uint8_t LED_PulseAmplitude1 = 0x00;
     uint8_t LED_PulseAmplitude2 = 0x00;
     uint8_t LED_PulseAmplitude3 = 0x00;
     uint8_t LED_PulseAmplitude4 = 0x00;
     uint8_t LED_PW           =0x00;
     uint8_t SLOT1            =0x00 ;
     uint8_t SLOT2            =0x00 ;
     uint8_t SLOT3            =0x00 ;
     uint8_t SLOT4            =0x00 ;
     uint8_t lednumber = 0x00;
    ret_code_t ret;
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler
    // Initialize.
 bool detected_device = false;
    log_init();
   // APP_ERROR_CHECK(NRF_LOG_INIT(NULL));
    //NRF_LOG_DEFAULT_BACKENDS_INIT();
    twi_init();
    for (address = 1; address <= TWI_ADDRESSES; address++)
        err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
        if (err_code == NRF_SUCCESS)
            detected_device = true;
           NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
        NRF_LOG_FLUSH();
        nrf_delay_ms(10);
    if (!detected_device)
        NRF_LOG_INFO("hi there");
                NRF_LOG_INFO("No device was found.");
        NRF_LOG_FLUSH();
    timers_init();
    buttons_leds_init();
    app_usbd_serial_num_generate();
    ret = nrf_drv_clock_init();
    NRF_LOG_INFO("USBD BLE UART example started.");
    ret = app_usbd_init(&usbd_config);
    app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
    ret = app_usbd_class_append(class_cdc_acm);
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    /*********************************************For PPG**************************************/
    /*--------------------------------------READING COMMAND-------------------------------*/
        uint8_t Read(uint8_t address)
        uint8_t temp;
        bsp_board_led_invert(4);
        err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&address, 1, false);
        nrf_delay_ms(10);
        err_code = nrf_drv_twi_rx(&m_twi, MX30105_ADDR, &temp,1);
        nrf_delay_ms(10);
           // NRF_LOG_RAW_INFO(" 0x%x  at 0x%x                          ", temp ,address );
            //NRF_LOG_INFO(" ");
            NRF_LOG_FLUSH();
            return temp;
/*--------------------------------------SENDING COMMAND-------------------------------*/
        void Send(uint8_t address, uint8_t command)
          uint8_t fifoconfig_Reg[2]={address,command} ;
          bsp_board_led_invert(2);
          err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&fifoconfig_Reg, sizeof(fifoconfig_Reg), false);
          nrf_delay_ms(10);
           // NRF_LOG_INFO(" Sent : 0x%x to 0x%x", command,address);
            //NRF_LOG_FLUSH();
        void Softreset()
      //  NRF_LOG_RAW_INFO("Reading Mode_Configuration for Reset : ");
        Mode_Configuration = Read(Mode_ConfigurationADD);
        Mode_Configuration =  (Mode_Configuration & RESET_MASK) | (0x01 << 6) ;
        Send(Mode_ConfigurationADD,Mode_Configuration);
        nrf_delay_ms(250);
       // NRF_LOG_INFO("                      Soft Reset Done                    ");
        void Readall(){
       // NRF_LOG_RAW_INFO("FIFO_Configuration  : ");
        FIFO_Configuration = Read(FIFO_ConfigurationADD);
        //NRF_LOG_RAW_INFO("Mode_Configuration  : ");
        //NRF_LOG_RAW_INFO("SpO2_Configuration  : ");
        SpO2_Configuration = Read(SpO2_ConfigurationADD);
       // NRF_LOG_RAW_INFO("Multi_LED_Mode_Con1 : ");
        Multi_LED_Mode_Control1 = Read(Multi_LED_Mode_Control1ADD);
        //NRF_LOG_RAW_INFO("Multi_LED_Mode_Con2 : ");
        Multi_LED_Mode_Control2 = Read(Multi_LED_Mode_Control2ADD);
        //NRF_LOG_RAW_INFO("LED_PulseAmplitude1 : ");
        LED_PulseAmplitude1 = Read(LED_PulseAmplitude1ADD);
        //NRF_LOG_RAW_INFO("LED_PulseAmplitude2 : ");
        LED_PulseAmplitude2 = Read(LED_PulseAmplitude2ADD);
        //NRF_LOG_RAW_INFO("LED_PulseAmplitude3 : ");
        LED_PulseAmplitude3 = Read(LED_PulseAmplitude3ADD);
        //NRF_LOG_RAW_INFO("LED_PulseAmplitude4 : ");
        LED_PulseAmplitude4 = Read(LED_PulseAmplitude4ADD);
        void ConfigureSampleAverage(uint8_t SampleAverage)
        SampleAverage = SampleAverage << 5;
        //NRF_LOG_RAW_INFO("Reading FIFO_CONFIGURATION for SampleAverage : ");
        FIFO_Configuration =  (FIFO_Configuration & SMP_AVE_MASK) | SampleAverage ;
        Send(FIFO_ConfigurationADD,FIFO_Configuration);
        void Enablefiforollover()
        //NRF_LOG_RAW_INFO("Reading FIFO_CONFIGURATION for Enabling Rollover : ");
        FIFO_Configuration =  (FIFO_Configuration & FIFO_ROLLOVER_EN_MASK) | ( 0x01 << 4 ) ;
       // NRF_LOG_RAW_INFO("comfirm FIFO_CONFIGURATION for Enabling Rollover : ");
        void Disablefiforollover()
        FIFO_Configuration =  (FIFO_Configuration & FIFO_ROLLOVER_EN_MASK) | ( 0x00 << 4 ) ;
        NRF_LOG_RAW_INFO("Comfirm FIFO_CONFIGURATION for Enabling Rollover : ");
        void Setmode(uint8_t mode)
        if (mode == 0x02){
        lednumber =1;
        if (mode == 0x03){
        lednumber =2;
        if (mode == 0x07){
        lednumber =3;
         // NRF_LOG_RAW_INFO("Reading Mode_CONFIGURATION for Enabling Rollover : ");
        Mode_Configuration =  (Mode_Configuration & MODE_MASK) | mode ;
        //NRF_LOG_RAW_INFO("Comfirm Mode_CONFIGURATION for Enabling Rollover : ");
        void Ledpulsewidth(uint8_t LED_PW){
        //NRF_LOG_RAW_INFO("Reading Spo2_CONFIGURATION for Led pulse width : ");
        SpO2_Configuration =  (SpO2_Configuration & LED_PW_MASK) | LED_PW ;
        Send(SpO2_ConfigurationADD,SpO2_Configuration);
        //NRF_LOG_RAW_INFO("comfirm Spo2_CONFIGURATION for Led pulse width : ");
        void Spo2samplerate(uint8_t SPO2_SR)
        SPO2_SR = SPO2_SR << 2;
        //NRF_LOG_RAW_INFO("Reading Spo2_CONFIGURATION for Spo2samplerate : ");
        SpO2_Configuration =  (SpO2_Configuration & SPO2_SR_MASK) | SPO2_SR ;
        void Spo2adcrange(uint8_t SPO2_ADC_RGE ){
        SPO2_ADC_RGE = SPO2_ADC_RGE << 5;
       // NRF_LOG_RAW_INFO("Reading Spo2_CONFIGURATION for Spo2adcrange : ");
        SpO2_Configuration =  (SpO2_Configuration & SPO2_ADC_RGE_MASK) | SPO2_ADC_RGE ;
        //NRF_LOG_RAW_INFO("comfirm Spo2_CONFIGURATION for Spo2adcrange : ");
        void Led1pulseamplitude(uint8_t amplitude){
        Send( LED_PulseAmplitude1ADD,amplitude);
       // NRF_LOG_RAW_INFO("Led1 Pulse Amplitude : ");
        amplitude = Read(LED_PulseAmplitude1ADD);
         void Led2pulseamplitude(uint8_t amplitude){
        Send( LED_PulseAmplitude2ADD,amplitude);
        //NRF_LOG_RAW_INFO("Led2 Pulse Amplitude : ");
        amplitude = Read(LED_PulseAmplitude2ADD);
         void Led3pulseamplitude(uint8_t amplitude){
        Send( LED_PulseAmplitude3ADD,amplitude);
        //NRF_LOG_RAW_INFO("Led3 Pulse Amplitude : ");
        amplitude = Read(LED_PulseAmplitude3ADD);
         void Led4pulseamplitude(uint8_t amplitude){
        Send( LED_PulseAmplitude4ADD,amplitude);
        //NRF_LOG_RAW_INFO("Led4 Pulse Amplitude : ");
        amplitude = Read(LED_PulseAmplitude4ADD);
        void  slot1(uint8_t SLOT1) {
       //NRF_LOG_RAW_INFO("Reading Multi_LED_Mode_Control1 for SLOT1 : ");
       Multi_LED_Mode_Control1 = Read(Multi_LED_Mode_Control1ADD) ;
       Multi_LED_Mode_Control1 =  (Multi_LED_Mode_Control1 & SLOT1_MASK) | SLOT1 ;
       Send( Multi_LED_Mode_Control1ADD,Multi_LED_Mode_Control1);
        //NRF_LOG_RAW_INFO("Comfirm Multi_LED_Mode_Control1 for SLOT1 : ");
        void  slot2(uint8_t SLOT2) {
        SLOT2 =SLOT2 << 4;
       //NRF_LOG_RAW_INFO("Reading Multi_LED_Mode_Control1 for SLOT2 : ");
       Multi_LED_Mode_Control1 =  (Multi_LED_Mode_Control1 & SLOT2_MASK) | SLOT2 ;
        //NRF_LOG_RAW_INFO("Comfirm Multi_LED_Mode_Control1 for SLOT2 : ");
         void  slot3(uint8_t SLOT3) {
       Multi_LED_Mode_Control2 = Read(Multi_LED_Mode_Control2ADD) ;
       Multi_LED_Mode_Control2 =  (Multi_LED_Mode_Control2 & SLOT3_MASK) | SLOT3 ;
       Send( Multi_LED_Mode_Control2ADD,Multi_LED_Mode_Control2);
       void  slot4(uint8_t SLOT4) {
        SLOT4 =SLOT4 << 4;
       //NRF_LOG_RAW_INFO("Reading Multi_LED_Mode_Control2 for SLOT2 : ");
       Multi_LED_Mode_Control2 =  (Multi_LED_Mode_Control2 & SLOT4_MASK) | SLOT4 ;
        //NRF_LOG_RAW_INFO("Comfirm Multi_LED_Mode_Control2 for SLOT2 : ");
        Readall();
        Softreset();
        Readall();
        bsp_board_led_invert(0);
        Enablefiforollover();
        ConfigureSampleAverage(0x02); //Sample Average 4 ; FOR SPO2
        Setmode(0x03); // 2 is red only, 3 is red + IR , 7 is Green + Red + IR ; ledMode = 2;
        Spo2adcrange(0x01); //2048 in arduino.
        Spo2samplerate(0x01);  // 50 in arduino.
        Ledpulsewidth(0x03); // pulse Width is us ms ;
        //if 1 led = > 1 slot and put Red in it, if 2 leds , 2 slots and put IR in second one, if 3 slots , put Red in first, IR in second and green in third.
        //we have red only so: ( RED 0x01, IR 0x02, Green 0x03)
        slot1(0x01);
        slot2(0x02);
        slot3(0x03);
        Led1pulseamplitude(0x1F);
        Led2pulseamplitude(0x1F);
        Led3pulseamplitude(0x1F);
        bsp_board_led_invert(3);
        NRF_LOG_FLUSH();
        //TESTING BEAT STUFF//
 int16_t IR_AC_Max = 20;
int16_t IR_AC_Min = -20;
//int16_t example1 = 0;
int16_t IR_AC_Signal_Previous;
int16_t IR_AC_Signal_min = 0;
int16_t IR_AC_Signal_max = 0;
int16_t IR_Average_Estimated;
int16_t positiveEdge = 0;
int16_t negativeEdge = 0;
int32_t ir_avg_reg = 0;
int16_t cbuf[32];
uint8_t offset = 0;
static const uint16_t FIRCoeffs[12] = {172, 321, 579, 927, 1360, 1858, 2390, 2916, 3391, 3768, 4012, 4096};
//  Average DC Estimator
int16_t averageDCEstimator(int32_t *p, uint16_t x)
  *p += ((((long) x << 15) - *p) >> 4);
  return (*p >> 15);
int32_t mul16(int16_t x, int16_t y)
  return((long)x * (long)y);
//  Low Pass FIR Filter
int16_t lowPassFIRFilter(int16_t din)
  cbuf[offset] = din;
  int32_t z = mul16(FIRCoeffs[11], cbuf[(offset - 11) & 0x1F]);
  for (uint8_t i = 0 ; i < 11 ; i++)
    z += mul16(FIRCoeffs[i], cbuf[(offset - i) & 0x1F] + cbuf[(offset - 22 + i) & 0x1F]);
  offset++;
  offset %= 32; //Wrap condition
  return(z >> 15);
//  Heart Rate Monitor functions takes a sample value and the sample number
//  Returns true if a beat is detected
//  A running average of four samples is recommended for display on the screen.
bool checkForBeat(int32_t sample)
  bool beatDetected = false;
  //  Save current state
  IR_AC_Signal_Previous = example1;
  //This is good to view for debugging
  //Serial.print("Signal_Current: ");
  //Serial.println(example);
  //  Process next data sample
  IR_Average_Estimated = averageDCEstimator(&ir_avg_reg, sample);
  example1 = lowPassFIRFilter(sample - IR_Average_Estimated);
  //  Detect positive zero crossing (rising edge)
  if ((IR_AC_Signal_Previous < 0) & (example1 >= 0))
    IR_AC_Max = IR_AC_Signal_max; //Adjust our AC max and min
    IR_AC_Min = IR_AC_Signal_min;
    positiveEdge = 1;
    negativeEdge = 0;
    //if ((IR_AC_Max - IR_AC_Min) > 100 & (IR_AC_Max - IR_AC_Min) < 1000)
    if ((IR_AC_Max - IR_AC_Min) > 20 & (IR_AC_Max - IR_AC_Min) < 1000)
      //Heart beat!!!
      beatDetected = true;
  //  Detect negative zero crossing (falling edge)
  if ((IR_AC_Signal_Previous > 0) & (example1 <= 0))
    positiveEdge = 0;
    negativeEdge = 1;
  //  Find Maximum value in positive cycle
  if (positiveEdge & (example1 > IR_AC_Signal_Previous))
    IR_AC_Signal_max = example1;
  //  Find Minimum value in negative cycle
  if (negativeEdge & (example1 < IR_AC_Signal_Previous))
    IR_AC_Signal_min = example1;
  return(beatDetected);
//end of Testing beat
//rtc_config();
//lfclk_config();
uint8_t Readysamplesnumber()
uint8_t write;
uint8_t read;
uint8_t error;
error = 0;
err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&FIFO_Read_PointerADD, 1, false);
nrf_delay_ms(5);
err_code = nrf_drv_twi_rx(&m_twi, MX30105_ADDR, &FIFO_Read_Pointer,1);
nrf_delay_ms(5);
        read = FIFO_Read_Pointer;
        if (err_code !=NRF_SUCCESS)
        error = 1 ;
err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&FIFO_Write_PointerADD, 1, false);
nrf_delay_ms(5);
err_code = nrf_drv_twi_rx(&m_twi, MX30105_ADDR, &FIFO_Write_Pointer,1);
nrf_delay_ms(5);
        write = FIFO_Write_Pointer;
        error = 1 ;
if (error = 0 ){
  if ( write > read )
  return write - read ;
  if ( write < read )
  return write+32 -read;
error =0;
/////////////////////////////////////////////////////////////SPO2//////////////////////////////////////////////////////////////
void maxim_sort_indices_descend(  int32_t  *pn_x, int32_t *pn_indx, int32_t n_size)
* \brief        Sort indices
* \par          Details
*               Sort indices according to descending order (insertion sort algorithm)
* \retval       None
  int32_t i, j, n_temp;
  for (i = 1; i < n_size; i++) {
    n_temp = pn_indx[i];
    for (j = i; j > 0 && pn_x[n_temp] > pn_x[pn_indx[j-1]]; j--)
      pn_indx[j] = pn_indx[j-1];
    pn_indx[j] = n_temp;
void maxim_sort_ascend(int32_t  *pn_x, int32_t n_size)
* \brief        Sort array
* \par          Details
*               Sort array in ascending order (insertion sort algorithm)
* \retval       None
    n_temp = pn_x[i];
    for (j = i; j > 0 && n_temp < pn_x[j-1]; j--)
        pn_x[j] = pn_x[j-1];
    pn_x[j] = n_temp;
void maxim_remove_close_peaks(int32_t *pn_locs, int32_t *pn_npks, int32_t *pn_x, int32_t n_min_distance)
* \brief        Remove peaks
* \par          Details
*               Remove peaks separated by less than MIN_DISTANCE
* \retval       None
  int32_t i, j, n_old_npks, n_dist;
  /* Order peaks from large to small */
  maxim_sort_indices_descend( pn_x, pn_locs, *pn_npks );
  for ( i = -1; i < *pn_npks; i++ ){
    n_old_npks = *pn_npks;
    *pn_npks = i+1;
    for ( j = i+1; j < n_old_npks; j++ ){
      n_dist =  pn_locs[j] - ( i == -1 ? -1 : pn_locs[i] ); // lag-zero peak of autocorr is at index -1
      if ( n_dist > n_min_distance || n_dist < -n_min_distance )
        pn_locs[(*pn_npks)++] = pn_locs[j];
  // Resort indices int32_to ascending order
  maxim_sort_ascend( pn_locs, *pn_npks );
void maxim_peaks_above_min_height( int32_t *pn_locs, int32_t *n_npks,  int32_t  *pn_x, int32_t n_size, int32_t n_min_height )
* \brief        Find peaks above n_min_height
* \par          Details
*               Find all peaks above MIN_HEIGHT
* \retval       None
  int32_t i = 1, n_width;
  *n_npks = 0;
  while (i < n_size-1){
    if (pn_x[i] > n_min_height && pn_x[i] > pn_x[i-1]){      // find left edge of potential peaks
      n_width = 1;
      while (i+n_width < n_size && pn_x[i] == pn_x[i+n_width])  // find flat peaks
        n_width++;
      if (pn_x[i] > pn_x[i+n_width] && (*n_npks) < 15 ){      // find right edge of peaks
        pn_locs[(*n_npks)++] = i;
        // for flat peaks, peak location is left edge
        i += n_width+1;
        i += n_width;
      i++;
void maxim_find_peaks( int32_t *pn_locs, int32_t *n_npks,  int32_t  *pn_x, int32_t n_size, int32_t n_min_height, int32_t n_min_distance, int32_t n_max_num )
* \brief        Find peaks
* \par          Details
*               Find at most MAX_NUM peaks above MIN_HEIGHT separated by at least MIN_DISTANCE
* \retval       None
  maxim_peaks_above_min_height( pn_locs, n_npks, pn_x, n_size, n_min_height );
  maxim_remove_close_peaks( pn_locs, n_npks, pn_x, n_min_distance );
  //added a min here, because min doesn't exist
  if (*n_npks > n_max_num){
   *n_npks = n_max_num;
 // *n_npks = min( *n_npks, n_max_num );
  if (*n_npks < n_max_num){
  *n_npks = *n_npks;
void maxim_heart_rate_and_oxygen_saturation(uint32_t *pun_ir_buffer, int32_t n_ir_buffer_length, uint32_t *pun_red_buffer, int32_t *pn_spo2, int8_t *pch_spo2_valid,
                int32_t *pn_heart_rate, int8_t *pch_hr_valid)
* \brief        Calculate the heart rate and SpO2 level
* \par          Details
*               By detecting  peaks of PPG cycle and corresponding AC/DC of red/infra-red signal, the an_ratio for the SPO2 is computed.
*               Since this algorithm is aiming for Arm M0/M3. formaula for SPO2 did not achieve the accuracy due to register overflow.
*               Thus, accurate SPO2 is precalculated and save longo uch_spo2_table[] per each an_ratio.
* \param[in]    *pun_ir_buffer           - IR sensor data buffer
* \param[in]    n_ir_buffer_length      - IR sensor data buffer length
* \param[in]    *pun_red_buffer          - Red sensor data buffer
* \param[out]    *pn_spo2                - Calculated SpO2 value
* \param[out]    *pch_spo2_valid         - 1 if the calculated SpO2 value is valid
* \param[out]    *pn_heart_rate          - Calculated heart rate value
* \param[out]    *pch_hr_valid           - 1 if the calculated heart rate value is valid
* \retval       None
  uint32_t un_ir_mean;
  int32_t k, n_i_ratio_count;
  int32_t i, n_exact_ir_valley_locs_count, n_middle_idx;
  int32_t n_th1, n_npks;
  int32_t an_ir_valley_locs[15] ;
  int32_t n_peak_interval_sum;
  int32_t n_y_ac, n_x_ac;
  int32_t n_spo2_calc;
  int32_t n_y_dc_max, n_x_dc_max;
  int32_t n_y_dc_max_idx = 0;
  int32_t n_x_dc_max_idx = 0;
  int32_t an_ratio[5], n_ratio_average;
  int32_t n_nume, n_denom ;
  // calculates DC mean and subtract DC from ir
  un_ir_mean =0;
  for (k=0 ; k<n_ir_buffer_length ; k++ ) un_ir_mean += pun_ir_buffer[k] ;
  un_ir_mean =un_ir_mean/n_ir_buffer_length ;
  // remove DC and invert signal so that we can use peak detector as valley detector
    an_x[k] = -1*(pun_ir_buffer[k] - un_ir_mean) ;
  // 4 pt Moving Average
  for(k=0; k< BUFFER_SIZE-MA4_SIZE; k++){
    an_x[k]=( an_x[k]+an_x[k+1]+ an_x[k+2]+ an_x[k+3])/(int)4;
  // calculate threshold
  n_th1=0;
  for ( k=0 ; k<BUFFER_SIZE ;k++){
    n_th1 +=  an_x[k];
  n_th1=  n_th1/ ( BUFFER_SIZE);
  if( n_th1<30) n_th1=30; // min allowed
  if( n_th1>60) n_th1=60; // max allowed
  for ( k=0 ; k<15;k++) an_ir_valley_locs[k]=0;
  // since we flipped signal, we use peak detector as valley detector
  maxim_find_peaks( an_ir_valley_locs, &n_npks, an_x, BUFFER_SIZE, n_th1, 4, 15 );//peak_height, peak_distance, max_num_peaks
  n_peak_interval_sum =0;
  if (n_npks>=2){
    for (k=1; k<n_npks; k++) n_peak_interval_sum += (an_ir_valley_locs[k] -an_ir_valley_locs[k -1] ) ;
    n_peak_interval_sum =n_peak_interval_sum/(n_npks-1);
    *pn_heart_rate =(int32_t)( (FreqS*60)/ n_peak_interval_sum );
    *pch_hr_valid  = 1;
  else  {
    *pn_heart_rate = -999; // unable to calculate because # of peaks are too small
    *pch_hr_valid  = 0;
  //  load raw value again for SPO2 calculation : RED(=y) and IR(=X)
  for (k=0 ; k<n_ir_buffer_length ; k++ )  {
      an_x[k] =  pun_ir_buffer[k] ;
      an_y[k] =  pun_red_buffer[k] ;
  // find precise min near an_ir_valley_locs
  n_exact_ir_valley_locs_count =n_npks;
  //using exact_ir_valley_locs , find ir-red DC andir-red AC for SPO2 calibration an_ratio
  //finding AC/DC maximum of raw
  n_ratio_average =0;
  n_i_ratio_count = 0;
  for(k=0; k< 5; k++) an_ratio[k]=0;
  for (k=0; k< n_exact_ir_valley_locs_count; k++){
    if (an_ir_valley_locs[k] > BUFFER_SIZE ){
      *pn_spo2 =  999 ; // do not use SPO2 since valley loc is out of range
      *pch_spo2_valid  = 0;
      return;
  // find max between two valley locations
  // and use an_ratio betwen AC compoent of Ir & Red and DC compoent of Ir & Red for SPO2
  for (k=0; k< n_exact_ir_valley_locs_count-1; k++){
    n_y_dc_max= -16777216 ;
    n_x_dc_max= -16777216;
    if (an_ir_valley_locs[k+1]-an_ir_valley_locs[k] >3){
        for (i=an_ir_valley_locs[k]; i< an_ir_valley_locs[k+1]; i++){
          if (an_x[i]> n_x_dc_max) {n_x_dc_max =an_x[i]; n_x_dc_max_idx=i;}
          if (an_y[i]> n_y_dc_max) {n_y_dc_max =an_y[i]; n_y_dc_max_idx=i;}
      n_y_ac= (an_y[an_ir_valley_locs[k+1]] - an_y[an_ir_valley_locs[k] ] )*(n_y_dc_max_idx -an_ir_valley_locs[k]); //red
      n_y_ac=  an_y[an_ir_valley_locs[k]] + n_y_ac/ (an_ir_valley_locs[k+1] - an_ir_valley_locs[k])  ;
      n_y_ac=  an_y[n_y_dc_max_idx] - n_y_ac;    // subracting linear DC compoenents from raw
      n_x_ac= (an_x[an_ir_valley_locs[k+1]] - an_x[an_ir_valley_locs[k] ] )*(n_x_dc_max_idx -an_ir_valley_locs[k]); // ir
      n_x_ac=  an_x[an_ir_valley_locs[k]] + n_x_ac/ (an_ir_valley_locs[k+1] - an_ir_valley_locs[k]);
      n_x_ac=  an_x[n_y_dc_max_idx] - n_x_ac;      // subracting linear DC compoenents from raw
      n_nume=( n_y_ac *n_x_dc_max)>>7 ; //prepare X100 to preserve floating value
      n_denom= ( n_x_ac *n_y_dc_max)>>7;
      if (n_denom>0  && n_i_ratio_count <5 &&  n_nume != 0)
        an_ratio[n_i_ratio_count]= (n_nume*100)/n_denom ; //formular is ( n_y_ac *n_x_dc_max) / ( n_x_ac *n_y_dc_max) ;
        n_i_ratio_count++;
  // choose median value since PPG signal may varies from beat to beat
  maxim_sort_ascend(an_ratio, n_i_ratio_count);
  n_middle_idx= n_i_ratio_count/2;
  if (n_middle_idx >1)
    n_ratio_average =( an_ratio[n_middle_idx-1] +an_ratio[n_middle_idx])/2; // use median
    n_ratio_average = an_ratio[n_middle_idx ];
  if( n_ratio_average>2 && n_ratio_average <184){
    n_spo2_calc= uch_spo2_table[n_ratio_average] ;
    *pn_spo2 = n_spo2_calc ;
    *pch_spo2_valid  = 1;//  float_SPO2 =  -45.060*n_ratio_average* n_ratio_average/10000 + 30.354 *n_ratio_average/100 + 94.845 ;  // for comparison with table
  else{
    *pn_spo2 = 999 ; // do not use SPO2 since signal an_ratio is out of range
      // while(true)
        uint8_t bufferLength = 100;
        for(uint8_t k =0 ; k <  bufferLength ; k++)
        nrf_delay_ms(5);
        nrf_delay_ms(5);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_INFO(" ERROR IN Write Pointer:  0x%x", FIFO_Write_Pointer);
            NRF_LOG_FLUSH();
            error = 1;
        nrf_delay_ms(5);
        nrf_delay_ms(5);
           NRF_LOG_INFO(" ERROR IN Read Pointer 0x%x", FIFO_Read_Pointer);
           NRF_LOG_FLUSH();
           error = 1;
        err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&Over_Flow_CounterADD, 1, false);
        nrf_delay_ms(5);
        err_code = nrf_drv_twi_rx(&m_twi, MX30105_ADDR, &Over_Flow_Counter,1);
        nrf_delay_ms(5);
           // NRF_LOG_INFO(" Overflowed:  0x%x", Over_Flow_Counter);
        if (FIFO_Write_Pointer >  FIFO_Read_Pointer){ReadySamples = FIFO_Write_Pointer - FIFO_Read_Pointer;}
        if (FIFO_Write_Pointer <  FIFO_Read_Pointer ){ReadySamples = FIFO_Write_Pointer+32 - FIFO_Read_Pointer;}
        if (FIFO_Write_Pointer ==  FIFO_Read_Pointer)
        ReadySamples = 0;
        k--;
        if (error == 1 )
        ReadySamples = 0;
        k--;
        if ( ReadySamples > 0){
                err_code = nrf_drv_twi_tx(&m_twi, MX30105_ADDR,&FIFO_Data_RegisterADD, 1, false);
                err_code = nrf_drv_twi_rx(&m_twi, MX30105_ADDR, &FIFO_Data_Register,3*ReadySamples*lednumber);
                nrf_delay_ms(4);
                  error = 0;
                  uint8_t i=0;
                  if (lednumber == 1)
                        for (i=0;i<ReadySamples*3;i=i+3)
                             Max_ADC = ((uint32_t)FIFO_Data_Register[i] << 16) | ((uint32_t)FIFO_Data_Register[i+1] << 8) | FIFO_Data_Register[i+2];
                             example = (((uint32_t)FIFO_Data_Register[i] << 16) | ((uint32_t)FIFO_Data_Register[i+1] << 8) | FIFO_Data_Register[i+2]);
                              redBuffer[k]=Max_ADC;
                              NRF_LOG_INFO("RED : %d,Samples %d %d %d %d", Max_ADC, ReadySamples, Over_Flow_Counter,FIFO_Read_Pointer,FIFO_Write_Pointer );
                              NRF_LOG_FLUSH();
                  if ( lednumber == 2 )
                             for (i=0;i<ReadySamples*3*2;i=i+6)
                             Max_ADC2 = ((uint32_t)FIFO_Data_Register[i+3] << 16) | ((uint32_t)FIFO_Data_Register[i+4] << 8) | FIFO_Data_Register[i+5];
                            // example = (((uint32_t)FIFO_Data_Register[i] << 16) | ((uint32_t)FIFO_Data_Register[i+1] << 8) | FIFO_Data_Register[i+2]);
                             irBuffer[k]=Max_ADC2;
                             //NRF_LOG_INFO("RED : %d,Samples %d %d %d %d", Max_ADC, ReadySamples, Over_Flow_Counter,FIFO_Read_Pointer,FIFO_Write_Pointer );
                             //NRF_LOG_INFO("IR : %d,Samples %d %d %d %d", Max_ADC2, ReadySamples, Over_Flow_Counter,FIFO_Read_Pointer,FIFO_Write_Pointer );
                             NRF_LOG_FLUSH();
                  if (lednumber == 3 )
                   for (i=0;i<ReadySamples*3*3;i=i+9)
                             Max_ADC3 = ((uint32_t)FIFO_Data_Register[i+6] << 16) | ((uint32_t)FIFO_Data_Register[i+7] << 8) | FIFO_Data_Register[i+8];
                             greenBuffer[k]=Max_ADC3;
                            // NRF_LOG_INFO("IR : %d,Samples %d %d %d %d", Max_ADC2, ReadySamples, Over_Flow_Counter,FIFO_Read_Pointer,FIFO_Write_Pointer );
                            // NRF_LOG_INFO("GREEN : %d,Samples %d %d %d %d", Max_ADC3, ReadySamples, Over_Flow_Counter,FIFO_Read_Pointer,FIFO_Write_Pointer );
                            NRF_LOG_FLUSH();
  //timer=nrfx_rtc_counter_get(&rtc);
  maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
  //Continuously taking samples from MAX30102.  Heart rate and SpO2 are calculated every 1 second
  while (1)
    //dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
    for (uint8_t k = 25; k < 100; k++)
      redBuffer[k - 25] = redBuffer[k];
      irBuffer[k - 25] = irBuffer[k];
    //take 25 sets of samples before calculating the heart rate.
    for (uint8_t k = 75; k < 100; k++)
        nrf_delay_ms(5);
        nrf_delay_ms(5);
            NRF_LOG_FLUSH();
            error = 1;
        nrf_delay_ms(5);
        nrf_delay_ms(5);
           NRF_LOG_FLUSH();
           error = 1;
        nrf_delay_ms(5);
        nrf_delay_ms(5);
        ReadySamples = 0;
        k--;
        if (error == 1 )
        ReadySamples = 0;
        k--;
                nrf_delay_ms(4);
                  error = 0;
                  uint8_t i=0;
                  if (lednumber == 1)
                              NRF_LOG_FLUSH();
                             NRF_LOG_FLUSH();
                            NRF_LOG_FLUSH();
     BPM = (int32_t)60000/(int32_t)heartRate;
     NRF_LOG_INFO(" %d  ", spo2 );
    // Enter main loop
    ret = app_usbd_power_events_enable();
for (;;)
      while (app_usbd_event_queue_process())
 //sendcom("hello");
        idle_state_handle();
