NRF52840 Fstorage
I would like to store 180 000 bytes on the flash with fstorage. By using the example after some trouble it works. When I try to apply this example on my own program, it is limited to 1000 bytes. I think that it is due to a parameter on sdk_config.h ! any idea ?
regards
    There is a maximum if you use the SoftDevice, which is configurable with NRF_FSTORAGE_SD_MAX_WRITE_SIZE. That does not change the SoftDevice implementation though, and fstorage will handle it by splitting the write in smaller parts. Other then that, the only limitation is that you must write to a page aligned address, and that the length must be a multiple of 4.
    What do you do, and how does it fail?
  • yes i use a softdevice
    NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
        /* Set a handler for fstorage events. */
        .evt_handler = fstorage_evt_handler,
        /* These below are the boundaries of the flash space assigned to this instance of fstorage.
         * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
         * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
         * last page of flash available to write data. */
        .start_addr = 0x40000,
        .end_addr   = 0x6Dfff,
    NRF_FSTORAGE_SD_MAX_WRITE_SIZE = 4096 as on the example
    actually, there is no fail, no error, but i have data only between 0x40000 and 0x41000
    it works on the example but not in my program :-(
    regards
  • 0x1000 is equal to 4096 bytes, do you confirme that in case I try to write more than 4096 bytes, it will be done in further part automatically or do I perform further write with only 4096 bytes ?
     Yes, that is correct (so this is 1024 words, which is a full flash page).
     Yes, if you try to write more than NRF_FSTORAGE_SD_MAX_WRITE_SIZE, it will be split in several writes. You should get an error if something goes wrong. Do you not? Do you get the event indicating that write completed? You could also try to reduce NRF_FSTORAGE_SD_MAX_WRITE_SIZE to half, though if that was the problem you should have got a SoftDevice assert.
  • hi Thank you for your answer
    I tried too with smaller table, even below 4096 bytes and perform the same write on an other adress 0x42000 for example, the second write never occurs, so seems that the flash is not ready. Seems to be my problem !!
    if I use the function wait_for_flash_ready(), I stay in the loop. it explains the behaviour.
    i already met this problem and I understood that priority must be changed on sdk_config.h
    do you confirm that only this parameter (see below) must be lower priority ? because even by changing priority, I have the same behaviour !
    / <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef APP_TIMER_CONFIG_IRQ_PRIORITY
    #define APP_TIMER_CONFIG_IRQ_PRIORITY 4  //6
    regards
    seb
