I'm having a bit trouble here getting migrated to LPUART on a working nRF9160 <> HCI BLE on nRF52 (On the Thingy91). As far as I can tell my .conf and .overlay files are what they should be. Are there any other gotchas that I may be missing here? I get an HCI timeout when initializing bluetooth:
[00:00:07.104,858] <inf> beacon_scanner: Initializing beacon scanner...
ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:333
k_sem_take failed with err -11
[00:00:17.125,946] <err> os: r0/a1: 0x00000003 r1/a2: 0x20023427 r2/a3: 0x00000000
[00:00:17.126,464] <err> os: r3/a4: 0x20019830 r12/ip: 0x0000a000 r14/lr: 0x00029eb1
[00:00:17.126,983] <err> os: xpsr: 0x61000000
[00:00:17.127,319] <err> os: s[ 0]: 0x00000000 s[ 1]: 0x00000000 s[ 2]: 0x00000000 s[ 3]: 0x00000000
[00:00:17.127,960] <err> os: s[ 4]: 0x00000000 s[ 5]: 0x00000000 s[ 6]: 0x00000000 s[ 7]: 0x00000000
[00:00:17.128,601] <err> os: s[ 8]: 0x00000000 s[ 9]: 0x00000000 s[10]: 0x00000000 s[11]: 0x00000000
[00:00:17.129,211] <err> os: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000000 s[15]: 0x00000000
[00:00:17.129,852] <err> os: fpscr: 0x20014500
[00:00:17.130,218] <err> os: Faulting instruction address (r15/pc): 0x00029ebc
[00:00:17.130,645] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:17.131,103] <err> os: Current thread: 0x20019148 (unknown)
Here are some of the pertinent files.
thingy91_nrf52840.overlay
chosen {
zephyr,bt-c2h-uart=&lpuart;
reset_input: gpio-reset {
compatible = "nordic,thingy91-nrf52840-reset";
status = "okay";
gpios = <&gpio0 20
(GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
&uart0 {
/delete-property/ rts-pin;
/delete-property/ cts-pin;
/delete-property/ rx-pin;
&uart1 {
status = "okay";
current-speed = <1000000>;
tx-pin = <25>;
rx-pin = <32>;
/delete-property/ hw-flow-control;
lpuart: nrf-sw-lpuart {
compatible = "nordic,nrf-sw-lpuart";
status = "okay";
label = "LPUART";
req-pin = <19>;
rdy-pin = <22>;
/delete-node/ &usbd;
thingy91_nrf52840.conf
# General
CONFIG_GPIO=y
CONFIG_SERIAL=y
# Stack
CONFIG_MAIN_STACK_SIZE=1024
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
# Bluetooth
CONFIG_BT=y
CONFIG_BT_CTLR=y
CONFIG_BT_HCI_RAW=y
CONFIG_BT_HCI_RAW_H4=y
CONFIG_BT_HCI_RAW_H4_ENABLE=y
CONFIG_BT_TINYCRYPT_ECC=n
CONFIG_BT_CTLR_DTM_HCI=y
CONFIG_BT_CTLR_ASSERT_HANDLER=y
CONFIG_BT_WAIT_NOP=y
# UART
# CONFIG_UART_INTERRUPT_DRIVEN=y
# CONFIG_UART_LINE_CTRL=y
# Enable reset pin
CONFIG_GPIO_AS_PINRESET=y
# Stack
CONFIG_HEAP_MEM_POOL_SIZE=16384
# USB
# CONFIG_USB=y
# CONFIG_USB_DEVICE_STACK=y
# CONFIG_USB_DEVICE_MANUFACTURER="React Mobile"
# CONFIG_USB_DEVICE_PRODUCT="Thingy:91 UART"
# CONFIG_USB_DEVICE_VID=0x1915
# CONFIG_USB_DEVICE_PID=0x520F
# CONFIG_USB_COMPOSITE_DEVICE=y
# CONFIG_USB_CDC_ACM=y
# CONFIG_USB_CDC_ACM_RINGBUF_SIZE=16384
# CONFIG_USB_CDC_ACM_DEVICE_COUNT=1
# LPUART config
CONFIG_UART_1_ASYNC=y
CONFIG_UART_1_INTERRUPT_DRIVEN=n
CONFIG_UART_1_NRF_HW_ASYNC=y
CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
CONFIG_NRF_SW_LPUART=y
CONFIG_NRF_SW_LPUART_INT_DRIVEN=y
thingy91_nrf9160ns.overlay
chosen {
zephyr,bt-uart=&lpuart;
/* Reset control */
nrf52840_reset: gpio-reset {
status = "okay";
gpios = <&gpio0 20 GPIO_ACTIVE_LOW>;
&uart0 {
&uart1 {
status = "okay";
tx-pin = <22>;
rx-pin = <23>;
status = "okay";
label = "LPUART";
req-pin = <25>;
rdy-pin = <24>;
thingy91_nrf9160ns.conf
# General config CONFIG_NEWLIB_LIBC=y CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y CONFIG_ASSERT=y CONFIG_REBOOT=y # Network CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_NET_SOCKETS_SOCKOPT_TLS=y # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y CONFIG_LTE_AUTO_INIT_AND_CONNECT=n CONFIG_LTE_NETWORK_MODE_NBIOT=n CONFIG_LTE_LEGACY_PCO_MODE=n CONFIG_LTE_EDRX_REQ_VALUE="1101" # 43.6 minutes CONFIG_LTE_LOCK_BANDS=y # AT host # CONFIG_AT_HOST_LIBRARY=y # Non-Volatile Storage (NVS) CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_NVS=y CONFIG_MPU_ALLOW_FLASH_WRITE=y # Modem info CONFIG_MODEM_INFO=y CONFIG_CJSON_LIB=y # GPS CONFIG_SUPL_CLIENT_LIB=y # Modem library CONFIG_NRF_MODEM_LIB=y # Disable Modem traces, since we need UART1 for HCI CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=n # Enable Bluetooth stack and libraries CONFIG_BT=y CONFIG_BT_H4=y CONFIG_BT_WAIT_NOP=y CONFIG_BT_CENTRAL=y CONFIG_BT_SCAN=y # CONFIG_UART_INTERRUPT_DRIVEN=y # Watchdog CONFIG_WATCHDOG=y # Heap and stacks CONFIG_HEAP_MEM_POOL_SIZE=24576 CONFIG_MAIN_STACK_SIZE=1024 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 CONFIG_HW_STACK_PROTECTION=y # Image manager CONFIG_IMG_MANAGER=y CONFIG_IMG_ERASE_PROGRESSIVELY=y # FOTA library CONFIG_DOWNLOAD_CLIENT=y CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096 CONFIG_DOWNLOAD_CLIENT_TCP_SOCK_TIMEO_MS=15000 CONFIG_DOWNLOAD_CLIENT_UDP_SOCK_TIMEO_MS=15000 CONFIG_DFU_TARGET=y CONFIG_DFU_TARGET_MCUBOOT=y CONFIG_FOTA_DOWNLOAD=y # Application Upgrade support CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_APPLICATION_VERSION=27 CONFIG_APPLICATION_VERSION_STRING="1.4.x" # Fatal error CONFIG_RESET_ON_FATAL_ERROR=n CONFIG_NRF_SW_LPUART=y CONFIG_NRF_SW_LPUART_INT_DRIVEN=y CONFIG_UART_1_ASYNC=y CONFIG_UART_1_INTERRUPT_DRIVEN=n CONFIG_UART_1_NRF_HW_ASYNC=y CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
I'm probably doing something stupid here but any insight would be extremely appreciated!
In the meantime I'll keep chugging on it here.
Thanks!
