Hello everyone,
is there an example that demonstrates how to turn off and on the Bluetooth completely multiple times in the application?
I need really low consumption (tens of microamperes) and the only way I can do that is to invoke the sd_softdevice_disable() API. However, at a later time I cannot init the Bluetooth correctly.
Here is my code (based on the ble_peripheral_uart example from nRF5_SDK_17.0.2_d674dde, s132, nRF52832-CIAA(build code: E1) 512kB Flash, 64kB RAM):
/**@brief Function for the SoftDevice initialization. * * @details This function initializes the SoftDevice and the BLE event interrupt. */ static void ble_stack_init(uint32_t enable_request) { ret_code_t err_code; if(enable_request){ err_code = nrf_sdh_enable_request(); APP_ERROR_CHECK(err_code); } // Configure the BLE stack using the default settings. // Fetch the start address of the application RAM. uint32_t ram_start = 0; err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start); APP_ERROR_CHECK(err_code); // Enable BLE stack. err_code = nrf_sdh_ble_enable(&ram_start); APP_ERROR_CHECK(err_code); // Register a handler for BLE events. NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL); } void user_bluetooth_init(void){ ret_code_t err; const nrf_clock_lf_cfg_t sd_lf_config = { .source = NRF_SDH_CLOCK_LF_SRC, .rc_ctiv = NRF_SDH_CLOCK_LF_RC_CTIV, .rc_temp_ctiv = NRF_SDH_CLOCK_LF_RC_TEMP_CTIV, .accuracy = NRF_SDH_CLOCK_LF_ACCURACY }; static uint32_t first_time = 1; if(!ble_enabled){ ble_enabled = 1; central_connected = 0; if(first_time){ timers_init(); ble_stack_init(first_time); gap_params_init(); gatt_init(); services_init(); advertising_init(); conn_params_init(); first_time = 0; } else{ err = sd_softdevice_enable(&sd_lf_config, fault_handler); APP_ERROR_CHECK(err); // Configure the BLE stack using the default settings. // Fetch the start address of the application RAM. uint32_t ram_start = 0; err = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start); APP_ERROR_CHECK(err); // Enable BLE stack. err = nrf_sdh_ble_enable(&ram_start); APP_ERROR_CHECK(err); } user_bluetooth_advertising_start(); } } void user_bluetooth_deinit(void){ if(ble_enabled){ ble_enabled = 0; sd_softdevice_disable(); nrf_delay_ms(1000); } } int main(void){ DEBUGOUT("on\n"); user_bluetooth_init(); nrf_delay_ms(5000); DEBUGOUT("off\n"); user_bluetooth_deinit(); nrf_delay_ms(5000); DEBUGOUT("on\n"); user_bluetooth_init(); nrf_delay_ms(5000); while(1){ } }
If I try to connect with nRF Toolbox on the second turn on (I can see that the device is advertising correctly), the nRF Toolbox displays an error: "The device does not have required services."
Thank you in advance for your time!
L. B.
