Hello everyone,
Yesterday I found a strange behavior with the NRF9160 GPS on NCS v1.5.1:
When configuring the GPS to run in Single Fix mode, running on MFW v1.2.3, I noticed it does not ever trigger a timeout after the specified try-time. We have multiple units on MFW 1.2.3 and the behavior is consistent for all we've tested so far. This does not occur with none of the units running MFW 1.3.0, and I confirmed that the issue is solved by updating to the latter mfw version.
To replicate the behavior, it suffices to run ncs/nrf/samples/nrf9160/gps on NCS v1.5.1, and setting the fix_retry = 10 and fix_interval = 0: the GPS data stops updating after 10 seconds for MFW v1.3.0 whereas it keeps searching/updating satellite msgs for MFW v1.2.3. Here's the main.c for copy-pasting in the gps sample with the described configuration.
* Copyright (c) 2019 Nordic Semiconductor ASA
#include <zephyr.h>
#include <nrf_socket.h>
#include <net/socket.h>
#include <stdio.h>
#include <modem/at_cmd.h>
#include <modem/at_notif.h>
#ifdef CONFIG_SUPL_CLIENT_LIB
#include <supl_os_client.h>
#include <supl_session.h>
#include "supl_support.h"
#define AT_XSYSTEMMODE "AT\%XSYSTEMMODE=1,0,1,0"
#define AT_ACTIVATE_GPS "AT+CFUN=31"
#define AT_ACTIVATE_LTE "AT+CFUN=21"
#define AT_DEACTIVATE_LTE "AT+CFUN=20"
#define GNSS_INIT_AND_START 1
#define GNSS_STOP 2
#define GNSS_RESTART 3
#define AT_CMD_SIZE(x) (sizeof(x) - 1)
#ifdef CONFIG_BOARD_NRF9160DK_NRF9160NS
#define AT_MAGPIO "AT\%XMAGPIO=1,0,0,1,1,1574,1577"
#ifdef CONFIG_GPS_SAMPLE_ANTENNA_ONBOARD
#define AT_COEX0 "AT\%XCOEX0=1,1,1565,1586"
#elif CONFIG_GPS_SAMPLE_ANTENNA_EXTERNAL
#define AT_COEX0 "AT\%XCOEX0"
#endif /* CONFIG_BOARD_NRF9160DK_NRF9160NS */
#ifdef CONFIG_BOARD_THINGY91_NRF9160NS
#define AT_MAGPIO "AT\%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200," \
"3,824,894,4,880,960,5,791,849,7,1565,1586"
#endif /* CONFIG_BOARD_THINGY91_NRF9160NS */
static const char update_indicator[] = {'\\', '|', '/', '-'};
static const char *const at_commands[] = {
AT_XSYSTEMMODE,
#if defined(CONFIG_BOARD_NRF9160DK_NRF9160NS) || \
defined(CONFIG_BOARD_THINGY91_NRF9160NS)
AT_MAGPIO,
AT_COEX0,
AT_ACTIVATE_GPS
static int gnss_fd;
static char nmea_strings[10][NRF_GNSS_NMEA_MAX_LEN];
static uint32_t nmea_string_cnt;
static bool got_fix;
static uint64_t fix_timestamp;
static nrf_gnss_data_frame_t last_pvt;
K_SEM_DEFINE(lte_ready, 0, 1);
void nrf_modem_recoverable_error_handler(uint32_t error)
printf("Err: %lu\n", (unsigned long)error);
static int setup_modem(void)
for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
if (at_cmd_write(at_commands[i], NULL, 0, NULL) != 0) {
return -1;
return 0;
/* Accepted network statuses read from modem */
static const char status1[] = "+CEREG: 1";
static const char status2[] = "+CEREG:1";
static const char status3[] = "+CEREG: 5";
static const char status4[] = "+CEREG:5";
static void wait_for_lte(void *context, const char *response)
if (!memcmp(status1, response, AT_CMD_SIZE(status1)) ||
!memcmp(status2, response, AT_CMD_SIZE(status2)) ||
!memcmp(status3, response, AT_CMD_SIZE(status3)) ||
!memcmp(status4, response, AT_CMD_SIZE(status4))) {
k_sem_give(<e_ready);
static int activate_lte(bool activate)
if (activate) {
if (at_cmd_write(AT_ACTIVATE_LTE, NULL, 0, NULL) != 0) {
return -1;
at_notif_register_handler(NULL, wait_for_lte);
if (at_cmd_write("AT+CEREG=2", NULL, 0, NULL) != 0) {
return -1;
k_sem_take(<e_ready, K_FOREVER);
at_notif_deregister_handler(NULL, wait_for_lte);
if (at_cmd_write("AT+CEREG=0", NULL, 0, NULL) != 0) {
return -1;
} else {
if (at_cmd_write(AT_DEACTIVATE_LTE, NULL, 0, NULL) != 0) {
return -1;
return 0;
static int gnss_ctrl(uint32_t ctrl)
int retval;
nrf_gnss_fix_retry_t fix_retry = 10;
nrf_gnss_fix_interval_t fix_interval = 0;
nrf_gnss_delete_mask_t delete_mask = 0;
nrf_gnss_nmea_mask_t nmea_mask = NRF_GNSS_NMEA_GSV_MASK |
NRF_GNSS_NMEA_GSA_MASK |
NRF_GNSS_NMEA_GLL_MASK |
NRF_GNSS_NMEA_GGA_MASK |
NRF_GNSS_NMEA_RMC_MASK;
if (ctrl == GNSS_INIT_AND_START) {
gnss_fd = nrf_socket(NRF_AF_LOCAL,
NRF_SOCK_DGRAM,
NRF_PROTO_GNSS);
if (gnss_fd >= 0) {
printk("GPS Socket created\n");
} else {
printk("Could not init socket (err: %d)\n", gnss_fd);
return -1;
retval = nrf_setsockopt(gnss_fd,
NRF_SOL_GNSS,
NRF_SO_GNSS_FIX_RETRY,
&fix_retry,
sizeof(fix_retry));
if (retval != 0) {
printk("Failed to set fix retry value\n");
return -1;
NRF_SOL_GNSS,
NRF_SO_GNSS_FIX_INTERVAL,
&fix_interval,
sizeof(fix_interval));
if (retval != 0) {
printk("Failed to set fix interval value\n");
return -1;
NRF_SOL_GNSS,
NRF_SO_GNSS_NMEA_MASK,
&nmea_mask,
sizeof(nmea_mask));
if (retval != 0) {
printk("Failed to set nmea mask\n");
return -1;
if ((ctrl == GNSS_INIT_AND_START) ||
(ctrl == GNSS_RESTART)) {
NRF_SOL_GNSS,
NRF_SO_GNSS_START,
&delete_mask,
sizeof(delete_mask));
if (retval != 0) {
printk("Failed to start GPS\n");
return -1;
if (ctrl == GNSS_STOP) {
NRF_SOL_GNSS,
NRF_SO_GNSS_STOP,
&delete_mask,
if (retval != 0) {
printk("Failed to stop GPS\n");
return -1;
return 0;
static int init_app(void)
int retval;
if (setup_modem() != 0) {
printk("Failed to initialize modem\n");
return -1;
retval = gnss_ctrl(GNSS_INIT_AND_START);
return retval;
static void print_satellite_stats(nrf_gnss_data_frame_t *pvt_data)
uint8_t tracked = 0;
uint8_t in_fix = 0;
uint8_t unhealthy = 0;
for (int i = 0; i < NRF_GNSS_MAX_SATELLITES; ++i) {
if ((pvt_data->pvt.sv[i].sv > 0) &&
(pvt_data->pvt.sv[i].sv < 33)) {
tracked++;
if (pvt_data->pvt.sv[i].flags &
NRF_GNSS_SV_FLAG_USED_IN_FIX) {
in_fix++;
NRF_GNSS_SV_FLAG_UNHEALTHY) {
unhealthy++;
printk("Tracking: %d Using: %d Unhealthy: %d\n", tracked,
in_fix,
unhealthy);
static void print_gnss_stats(nrf_gnss_data_frame_t *pvt_data)
if (pvt_data->pvt.flags & NRF_GNSS_PVT_FLAG_DEADLINE_MISSED) {
printk("GNSS notification deadline missed\n");
if (pvt_data->pvt.flags & NRF_GNSS_PVT_FLAG_NOT_ENOUGH_WINDOW_TIME) {
printk("GNSS operation blocked by insufficient time windows\n");
static void print_fix_data(nrf_gnss_data_frame_t *pvt_data)
printf("Longitude: %f\n", pvt_data->pvt.longitude);
printf("Latitude: %f\n", pvt_data->pvt.latitude);
printf("Altitude: %f\n", pvt_data->pvt.altitude);
printf("Speed: %f\n", pvt_data->pvt.speed);
printf("Heading: %f\n", pvt_data->pvt.heading);
printk("Date: %02u-%02u-%02u\n", pvt_data->pvt.datetime.year,
pvt_data->pvt.datetime.month,
pvt_data->pvt.datetime.day);
printk("Time (UTC): %02u:%02u:%02u\n", pvt_data->pvt.datetime.hour,
pvt_data->pvt.datetime.minute,
pvt_data->pvt.datetime.seconds);
static void print_nmea_data(void)
for (int i = 0; i < nmea_string_cnt; ++i) {
printk("%s", nmea_strings[i]);
int process_gps_data(nrf_gnss_data_frame_t *gps_data)
int retval;
retval = nrf_recv(gnss_fd,
gps_data,
sizeof(nrf_gnss_data_frame_t),
NRF_MSG_DONTWAIT);
if (retval > 0) {
switch (gps_data->data_id) {
case NRF_GNSS_PVT_DATA_ID:
memcpy(&last_pvt,
gps_data,
sizeof(nrf_gnss_data_frame_t));
nmea_string_cnt = 0;
got_fix = false;
if (gps_data->pvt.flags
& NRF_GNSS_PVT_FLAG_FIX_VALID_BIT) {
got_fix = true;
fix_timestamp = k_uptime_get();
case NRF_GNSS_NMEA_DATA_ID:
if (nmea_string_cnt < 10) {
memcpy(nmea_strings[nmea_string_cnt++],
gps_data->nmea,
retval);
case NRF_GNSS_AGPS_DATA_ID:
printk("\033[1;1H");
printk("\033[2J");
printk("New AGPS data requested, contacting SUPL server, flags %d\n",
gps_data->agps.data_flags);
gnss_ctrl(GNSS_STOP);
activate_lte(true);
printk("Established LTE link\n");
if (open_supl_socket() == 0) {
printf("Starting SUPL session\n");
supl_session(&gps_data->agps);
printk("Done\n");
close_supl_socket();
activate_lte(false);
gnss_ctrl(GNSS_RESTART);
k_msleep(2000);
return retval;
int inject_agps_type(void *agps,
size_t agps_size,
nrf_gnss_agps_data_type_t type,
void *user_data)
ARG_UNUSED(user_data);
int retval = nrf_sendto(gnss_fd,
agps,
agps_size,
0,
&type,
sizeof(type));
if (retval != 0) {
printk("Failed to send AGNSS data, type: %d (err: %d)\n",
type,
errno);
return -1;
printk("Injected AGPS data, flags: %d, size: %d\n", type, agps_size);
return 0;
nrf_gnss_data_frame_t gps_data;
uint8_t cnt = 0;
static struct supl_api supl_api = {
.read = supl_read,
.write = supl_write,
.handler = inject_agps_type,
.logger = supl_logger,
.counter_ms = k_uptime_get
printk("Starting GPS application\n");
if (init_app() != 0) {
return -1;
int rc = supl_init(&supl_api);
if (rc != 0) {
return rc;
printk("Getting GPS data...\n");
while (1) {
do {
/* Loop until we don't have more
* data to read
} while (process_gps_data(&gps_data) > 0);
if (IS_ENABLED(CONFIG_GPS_SAMPLE_NMEA_ONLY)) {
print_nmea_data();
} else {
printk("\033[2J");
print_satellite_stats(&last_pvt);
print_gnss_stats(&last_pvt);
printk("---------------------------------\n");
if (!got_fix) {
printk("Seconds since last fix: %lld\n",
(k_uptime_get() - fix_timestamp) / 1000);
cnt++;
printk("Searching [%c]\n",
update_indicator[cnt%4]);
} else {
print_fix_data(&last_pvt);
printk("\nNMEA strings:\n\n");
print_nmea_data();
printk("---------------------------------");
k_msleep(500);
return 0;
Clearly there are some ways to get around it but I wanted to share it and ask the following:
- Is this behavior expected (e.g, support for MFW1.2.3 is not recommended on this/subsequent SDK release(s) )?
- If we are developing code on v1.5.1, would you suggest us to update mfw of the 9160-rev1 units to v1.3.0 or stay in v1.2.3?
We aware that once jumping onto MFW v1.3.0 it isn't recommended to go back.
Thanks in advance,
Luis.
