Is it possible to dynamically detect presence of low frequency crystal for Soft Device?
Is it possible to detect the presence of a Low Frequency Crystal and configure softdevice to use if present, otherwise use the internal RC oscillator?
A proposal would be to probe presence of the crystal prior to sd_enable() and change the LFCLKSRC definition to use the crystal or RC depending on the result. Would this pattern work?
  • It looks like this is related (though for nrf51) https://devzone.nordicsemi.com/f/nordic-q-a/56844/in-our-product-we-would-like-to-select-lfclk-from-the-following-choices-instead-of-external-xtal-however-we-have-some-manufacturing-issues-with-the-xtal-chosen-and-so-we-muct-use-the-lf_src-to-be-the-rc/231321#231321
    Code posted there is:
    NRF_CLOCK->LFCLKSRC = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos);
    NRF_CLOCK->TASKS_LFCLKSTART = 1;
    // Wait for the low frequency clock to start
    nrf_delay_ms(1000);
    if(NRF_CLOCK->EVENTS_LFCLKSTARTED == 1)
    // hurray there is an external LFCLK present.
    // you can set external LFCLK when enable softdevice
    // no external lfclk present, you can use internal LFCK when enable softdevice
    Yes, the approach above should work. Also, if it makes sense for your application, you may consider making this a one-time check by storing the detected clock source to flash for subsequent startups. This will allow you to reduce the startup time and power consumption a bit.
    Something like this (code is untested)
    #include "nrf_delay.h"
    /* Make sure selected UICR CUSTOMER[n] register is not used elsewhere
     * in Application or Bootloader code.
    #define UICR_CLOCK_SETTING_ADDRESS NRF_UICR->CUSTOMER[0]
    #define UICR_CLOCK_SRC_XTAL        0x1
    #define UICR_CLOCK_SRC_RC          0x2
    static bool lfclk_is_xtal_available(void)
        bool has_xtal = false;
        /* Check if we need to update the UICR register. True on first boot */
        if (UICR_CLOCK_SETTING_ADDRESS == 0xFFFFFFFF)
            nrf_delay_ms(1000);
            if (NRF_CLOCK->EVENTS_LFCLKSTARTED == 1)
                has_xtal = true;
            /* Use NVMC to update the UICR register with out LF clk source setting */
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;
            while (NRF_NVMC->READY == NVMC_READY_READY_Busy)
            UICR_CLOCK_SETTING_ADDRESS = (has_xtal == true) ? UICR_CLOCK_SRC_XTAL : UICR_CLOCK_SRC_RC;
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
            has_xtal = (UICR_CLOCK_SETTING_ADDRESS == UICR_CLOCK_SRC_XTAL) ? true : false;
        return has_xtal;
