PWM failed to work with SoftDevice 8.0 in nRF51822
I may be missing something. I am trying to generate a square wave from a GPIO pin in a BLE application (SoftDevice 8.0). I tried libraries (nrf_pwm.c and nrf_pwm.h) in this post and also in this repo. I created two functions as follows:
#define V_CLK 5
static void pwm_init(void)
	  nrf_pwm_config_t pwm_config = PWM_DEFAULT_CONFIG;
    pwm_config.mode             = PWM_MODE_LED_255;
    pwm_config.num_channels     = 1;
    pwm_config.gpio_num[0]      = V_CLK;
    // Initialize the PWM library
    nrf_pwm_init(&pwm_config);
static void v_clock_start(void)
	nrf_pwm_set_value(0, 127);
I have tested they worked without SoftDevice, as I could see a square wave between 0V and VCC in GPIO pin 5.
After that I went ahead with SoftDevice. I used "ble_app_beacon" from SDK 8.0.0 as the starting point, and removed BSP code since I was using a standalone nRF51822 module. I set USE_WITH_SOFTDEVICE to 1 in nrf_pwm.h. Also, I called pwm_init() before ble_stack_init() in main() function:
    pwm_init();
    ble_stack_init();
    advertising_init();
    advertising_start();
    v_clock_start();
    for (;; )
        power_manage();
While BLE started successfully as I could see the iBeacon in my Master Control Panel Android app, I saw a flat 0V output from GPIO pin 5 in my oscilloscope. I tried to do the same thing to other working BLE apps of mine and they showed the same behavior. What was I missing?
    If you're using the code from this repo, pwm_init() should be called after the soft device has been initialized. Hopefully this solves your problem.
    Øyvind
  • I don't know why your code is not working, but if you are really only looking to produce a square wave, i.e constant 50% duty cycle(or any other constant duty cycle, which would more accurately be described as a rectangular wave), and at a constant frequency, I would write the thing myself, using a counter timer and GPIOTE.
    If you are hoping to vary either the duty or the frequency on the fly, then good luck with that.
    It is, in my humble opinion, a weakness of the nRF51822, in that the compare registers are not double buffered, and you can not have a SET and a CLEAR task directed to a single I/O pin, but have to rely on a TOGGLE instead. I say this as someone who has fought with this in a quest to reliably produce DTMF tones WITHOUT the SD running!
    However, I suppose the designers have tough choices to make about the best use of silicon...
  • Hi Øyvind, your advice works. I also found that the libraries in this post just don't work, no matter I call pwm_init() before or after ble_stack_init(). For this repo, it only works if calling pwm_init() after ble_stack_init(). Why is the calling sequence reversed here?
  • Hi
    The SoftDevice API's (sd_ppi_... for instance) will only work after the SD is enabled, which is why you have to initialize PWM after the SD when setting USE_SOFTDEVICE = 1 in the PWM library.
    When USE_SOFTDEVICE = 0 the PWM driver will access peripherals such as NRF_PPI directly, and if you try to do this when the SD is enabled you will get a hard fault. That is why the advice earlier was to initialize the PWM driver before the SD, so that the PPI configuration would work.
    Now that the USE_SOFTDEVICE define is added you should just use this when using PWM with the SD.
    Regards Torbjørn
