Hello!
I need little help in setting up mBed TLS 1.3 socket.. I am using the https_client, how do I configure the project
Regards
Hello!
Regards
The networking api in zephyr does not have support for tls v1.3:
https://github.com/nrfconnect/sdk-zephyr/blob/master/include/net/net_ip.h#L75-L81
However, if you use the nrf_* socket api directly, you can setup a socket with tls v1.3:
https://github.com/nrfconnect/sdk-nrfxlib/blob/v1.5.1/nrf_modem/include/nrf_socket.h#L120
Is there anything specific you want to do?
Håkon
Thanks, I saw the net_ip.h header file, however there is mention of I can use mbedtls, when I configure mbedtls, I get undefined reference to `mbedtls_net_connect'
I need to interface to an API that has CA based on TLS 1.3(GlobalSign-RootCA-R3); I tried using the TLS1.2 https_client sample, with GlobaSign-RootCA -R2 but no luck
I have 3 options
1) mbedtls
2)wolfSSL
3) nrf_ *socket api
Please can you help me with mbedtls
Regards
Yash
My apologies, the nrf socket api will return not supported if you try to passthrough a tls v1.3 prototype.
Please also note that mbedtls does not support tls1v3:
https://tls.mbed.org/tech-updates/blog/working-towards-mbed-tls-3
yashchabria said:I need to interface to an API that has CA based on TLS 1.3(GlobalSign-RootCA-R3); I tried using the TLS1.2 https_client sample, with GlobaSign-RootCA -R2 but no luck
I have 3 options
1) mbedtls
2)wolfSSL
3) nrf_ *socket api
You sure you need TLS v1.3 to finish this request? It sounds like there's a problem with the Root CA, and not the tls version.
If you try setting this specific variable to "NONE", which will disable hostname verification?
(note: disable this purely for testing purposes)
https://github.com/nrfconnect/sdk-nrf/blob/master/samples/nrf9160/https_client/src/main.c#L122
Håkon
You are correct , my root CA was incorrect setup your example seems to work
Thanks
Glad to hear that the issue was solved!
Cheers,
Håkon
Cheers,
Håkon
