Can I use two RTC in nRF5340?
In nRF5340 I use one RTC and it works. Here is my code:
1) in prj.conf:
CONFIG_NRFX_RTC=y
CONFIG_NRFX_RTC0=y
2) in the code:
a) define:
nrfx_rtc_t sti_period_rtc_0 = NRFX_RTC_INSTANCE(0);
b):
IRQ_CONNECT(DT_IRQN(DT_NODELABEL(rtc0)),
DT_IRQ(DT_NODELABEL(rtc0), priority),
nrfx_isr, nrfx_rtc_0_irq_handler, 0);
nrfx_rtc_config_t period_rtc_0_config = NRFX_RTC_DEFAULT_CONFIG;
period_rtc_0_config.prescaler = 0;
nrfx_rtc_init( &sti_period_rtc_0, &period_rtc_0_config, period_rtc_0_handler );
Now I want to use two RTC, so I add :
1) in prj.conf:
CONFIG_NRFX_RTC=y
CONFIG_NRFX_RTC0=y
CONFIG_NRFX_RTC1=y
2) in the code:
a) define:
nrfx_rtc_t sti_period_rtc_1 = NRFX_RTC_INSTANCE(1);
b)
IRQ_CONNECT(DT_IRQN(DT_NODELABEL(rtc1)),
DT_IRQ(DT_NODELABEL(rtc1), priority),
nrfx_isr, nrfx_rtc_1_irq_handler, 0);
nrfx_rtc_config_t period_rtc_1_config = NRFX_RTC_DEFAULT_CONFIG;
period_rtc_1_config.prescaler = 0;
nrfx_rtc_init( &sti_period_rtc_1, &period_rtc_1_config, period_rtc_1_handler );
then I run Project->run CMake in SEGGER EMbedded studio
and I got this error:
1> Combining ‘zephyr/isr_tables.c’
1> gen_isr_tables.py: error: multiple registrations at table_index 21 for irq 21 (0x15)
1> Existing handler 0x16d05, new handler 0x57e5
1> Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?
Can you help to solve this problem? how can I use two RTC in nRF5340?
Thanks.
Carl
Parents Reply
  • Hi    ,
    I am facing similar issue here, not able to use RTC, i tried all you suggestions and attached same code as well, getting below error-
    error: NRFX_RTC (defined at C:/ncs/v2.9.0/zephyr/modules/hal_nordic\nrfx/Kconfig:443,
    modules\hal_nordic\nrfx/Kconfig:443) is assigned in a configuration file, but is not directly user-
    configurable (has no prompt). It gets its value indirectly from other symbols. See
    docs.zephyrproject.org/.../kconfig.html and/or look up NRFX_RTC in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    Please support!
    Thank you!
