flash_manager works properly only after a reset
Hello, I have a issue about flash_manager module.
When I load a program on processor (that has been previously erased) there is a problem with initialization (flash_manager_add return NRF_ERROR_NO_MEM ) and then with writing data. But when I restart progam everithing works fine (even writing and reading data)
I use:
  • nRF52840
  • SDK version: 17.0.0
  • SDK for Mesh version: 4.2.0
I just want the flash_manager to work properly from the beginning.
Thanks in advance for any help or tip!
    Do you use a custom board or nRF52840DK? How do you erase the board and restart progam?
    Could you step into flash_manager_add to see which function or code returns NRF_ERROR_NO_MEM?
    Amanda
  • Yes, I use custom board. I erase / restart program using Segger Embedded Studio debugger. The code look like this:
    void flashStorage_init(){
        flash_manager_t flashManager;
        flash_manager_page_t * p_area;
        p_area = (flash_manager_page_t *)(((const uint8_t *) flash_manager_recovery_page_get())
                                               - (15 * PAGE_SIZE));
        const flash_manager_config_t config =
            .write_complete_cb =      writeCb,
            .invalidate_complete_cb = invalidateCb,
            .remove_complete_cb =     removeCb,
            .min_available_space =    WORD_SIZE,
            .p_area =                 p_area,
            .page_count =             1
        uint32_t ret = flash_manager_add(&flashManager, &config);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Return code from flash manager %d \n", ret);
    The problem appear in flash_manager_add -> flash_area_build -> reserve_action_buffer and that return NULL pointer which leads to an error NRF_ERROR_NO_MEM. After a restart program this method works as it should - there is no problem with initialization and then with writing or reading process.
    Sorry for the delay. The support staff is reduced during the summer holidays, and you may experience delayed answers.
    Can you try the nRF-Command-Line-Tools to run nrfjprog -e before you load the image? Please let me know it can help or not.
    -Amanda H.
