nRF52840 SPIM cannot get input data, while oscilloscope signals are right.
Hi everybody! My application is based on SDK 17.02. I try to communicate with an spi device using spim driver and the code is basically based on the nrfx-spim example.
After some effort, now I managed to get the right signals on a oscilloscope. But I just cannot get the input in my application. Any suggestion is largely appreciated
Below are my code.
 * Copyright (c) 2017 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
#include "nrfx_spim.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "SEGGER_RTT.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define NRFX_SPIM_SCK_PIN  NRF_GPIO_PIN_MAP(1,9)
#define NRFX_SPIM_MOSI_PIN NRF_GPIO_PIN_MAP(0,6)
#define NRFX_SPIM_MISO_PIN NRF_GPIO_PIN_MAP(0,5)
#define NRFX_SPIM_SS_PIN   NRF_GPIO_PIN_MAP(0,8)
//#define NRFX_SPIM_DCX_PIN  30
#define SPI_INSTANCE  3                                           /**< SPI instance index. */
static const nrfx_spim_t spi = NRFX_SPIM_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
#define BUF_LEN 128
static uint8_t       m_tx_buf[BUF_LEN] ;           /**< TX buffer. */
static uint8_t       m_rx_buf[BUF_LEN] ;  /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
void spim_event_handler(nrfx_spim_evt_t const * p_event,
                       void *                  p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    NRF_LOG_INFO("RX buf:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
//    if (m_rx_buf[0] != 0)
//        NRF_LOG_INFO(" Received:");
//        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
	m_tx_buf[0] = 0x93;
	m_tx_buf[1] = 0xff;
    nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TRX(m_tx_buf, 2, m_rx_buf, 2);
    nrfx_spim_config_t spi_config = NRFX_SPIM_DEFAULT_CONFIG;
    spi_config.frequency      = NRF_SPIM_FREQ_500K;
    spi_config.ss_pin         = NRFX_SPIM_SS_PIN;
    spi_config.miso_pin       = NRFX_SPIM_MISO_PIN;
    spi_config.mosi_pin       = NRFX_SPIM_MOSI_PIN;
    spi_config.sck_pin        = NRFX_SPIM_SCK_PIN;
	spi_config.mode 		  = NRF_SPIM_MODE_3;
    spi_config.use_hw_ss      = false;
    spi_config.ss_active_high = false;
//	  spi_config.rx_delay     = 0x02;
//    spi_config.ss_duration  = 0x02;
    APP_ERROR_CHECK(nrfx_spim_init(&spi, &spi_config, spim_event_handler, NULL));
    while (1)
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0, m_length);
        spi_xfer_done = false;
		APP_ERROR_CHECK(nrfx_spim_xfer(&spi, &xfer_desc, 0));
        while (!spi_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
        bsp_board_led_invert(BSP_BOARD_LED_0);
        nrf_delay_ms(200);
    I am not sure I understand your issue correctly; could you confirm for me whether this means that you are able to see the right output signals by your device (but not receiving a reply from your SPIS device), or if you mean that you are seeing correct outbound and inbound communication on the bus, but it is not showing up in your application?
    Are you entering into the callback handler every time a transfer is complete?
    Is this part of an application that uses BLE in addition to the SPIM communication (i.e is there a SoftDevice present and enabled)?
    Looking forward to resolving this issue together!
    Karl
  • Thanks for reply. I have just solved the problem. just look at
    When the fisrt byte received by the spim driver is 0x00, strlen((const char *)m_rx_buf)) will return 0. Thus the callback will print nothing for ever. So I tried to print m_rx_buf[1] and finally I got the device ID. Maybe the sdk examples should fix this emmm...bug?
    Best regards
