nrf9160 nRF cloud doesn't pair, stuck at CLOUD_EVT_PAIR_REQUEST
I have a Thingy91 which was previously successfuly paired to nrf cloud. I deleted the device from nrf cloud and provisioned new certificates from nrf cloud (and uploaded to device). Now the device won't pair.. no error. See part of the log below.
[0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_USER_ASSOCIATION_REQUEST
[0m<inf> asset_tracker: CLOUD_EVT_PAIR_REQUEST
[0m<inf> asset_tracker: Add device to cloud account.
[0m<inf> asset_tracker: Waiting for cloud association...
[0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 1 result = 0
I also tried provisioning certificates with my custom prefix (and changing the NRF_CLOUD_CLIENT_ID_PREFIX), but the result is the same.
I'm currently using LTE-M, but I believe the original pairing was done with NbIOT. That being said.. I'm wondering how is NRFCloud able to support NBIOT (UDP?).
    could you provide me with a full application log? I might have to cross-check this with our nRF Cloud team.
    Thanks and regards,
    Markus
  • Here's the complete log for the version when I use custom prefix:
    *** Booting Zephyr OS build v2.4.99-ncs2  ***
    [00:00:00.237,243] <inf> asset_tracker: Asset tracker started... v1.5a
    [00:00:00.244,812] <dbg> nrf_cloud_transport.nct_client_id_get: client_id = shd-352656101110727
    [00:00:00.245,330] <dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/shd-352656101110727/shadow
    [00:00:00.245,941] <dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: shd-352656101110727/shadow/get/accepted
    [00:00:00.246,520] <dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/shd-352656101110727/shadow/get/rejected
    [00:00:00.247,161] <dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/shd-352656101110727/shadow/update/delta
    [00:00:00.247,802] <dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/shd-352656101110727/shadow/update
    [00:00:00.248,413] <dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/sh[00:00:19.974,334] <inf> nrf_cloud_transport: Using socket send timeout of 60 seconds
    [00:00:19.974,853] <dbg> nrf_cloud.nrf_cloud_run: Cloud connection request sent.
    [00:00:20.546,417] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_CONNACK: result 0
    [00:00:20.546,905] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 2
    [00:00:20.547,363] <dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED
    [00:00:20.547,821] <inf> asset_tracker: CLOUD_EVT_CONNECTED
    [00:00:20.548,217] <inf> asset_tracker: Persistent Sessions = 0
    [00:00:20.548,614] <dbg> nrf_cloud_transport.nct_cc_connect: nct_cc_connect
    [00:00:20.550,079] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 3
    [00:00:21.123,413] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 1234 result = 0
    [00:00:21.123,992] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 4
    [00:00:21.124,450] <dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 5678 opcode = 0 len = 0
    [00:00:21.126,007] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5
    [00:00:21.646,423] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 5678 result = 0
    [00:00:21.646,972] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5
    [00:00:21.891,510] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 37916 len = 50
    [00:00:21.894,165] <dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 1 opcode = 1 len = 168
    [00:00:21.896,392] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 6
    [00:00:21.896,850] <dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_USER_ASSOCIATION_REQUEST
    [00:00:21.897,338] <inf> asset_tracker: CLOUD_EVT_PAIR_REQUEST
    [00:00:21.897,705] <inf> asset_tracker: Add device to cloud account.
    [00:00:21.898,101] <inf> asset_tracker: Waiting for cloud association...
    [00:00:22.830,444] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 1 result = 0
    [00:00:29.303,680] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:29.304,199] <inf> asset_tracker: RRC mode: Idle
    [00:02:22.373,748] <dbg> lte_lc.at_handler: +CSCON notification
    [00:02:22.374,267] <inf> asset_tracker: RRC mode: Connected
    Here's later log:
    [00:05:21.898,559] <inf> asset_tracker: Disconnecting from cloud...
    [00:05:21.898,956] <dbg> nrf_cloud_transport.nct_disconnect: nct_disconnect
    [00:05:21.907,653] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_DISCONNECT: result = 0
    [00:05:21.908,172] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 1
    [00:05:21.908,630] <dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED
    [00:05:21.909,118] <inf> asset_tracker: CLOUD_EVT_DISCONNECTED: 0
    [00:05:21.909,515] <inf> asset_tracker: Attempting reconnect in 10 seconds...
    [00:05:21.910,095] <dbg> nrf_cloud.nrf_cloud_run: Socket error: POLLNVAL
    [00:05:21.910,522] <dbg> nrf_cloud.nrf_cloud_run: The cloud socket was unexpectedly closed.
    [00:05:22.216,918] <dbg> lte_lc.at_handler: +CSCON notification
    [00:05:22.217,437] <inf> asset_tracker: RRC mode: Connected
    [00:05:28.225,555] <dbg> lte_lc.at_handler: +CSCON notification
    [00:05:28.226,074] <inf> asset_tracker: RRC mode: Idle
    [00:05:28.577,880] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 1,"2775","0003F321",9,,,"11100000","11100000"
    [00:05:28.578,735] <dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    [00:05:28.579,315] <inf> asset_tracker: cell changed ID: 258849, area: 10101
    [00:05:31.910,034] <inf> asset_tracker: Connecting to cloud, attempt 1 of 8
    [00:05:31.910,522] <inf> asset_tracker: Cloud connection request sent.
    [00:05:31.910,919] <inf> asset_tracker: Connection response timeout is set to 30 seconds.
    [00:05:31.911,437] <dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTING
    [00:05:31.911,926] <inf> asset_tracker: CLOUD_EVT_CONNECTING
    [00:05:32.507,720] <dbg> lte_lc.at_handler: +CSCON notification
    [00:05:32.508,239] <inf> asset_tracker: RRC mode: Connected
    [00:05:32.956,329] <dbg> nrf_cloud_transport.nct_connect: IPv4 address: 52.71.225.111
    [00:05:50.885,803] <inf> nrf_cloud_transport: Using socket send timeout of 60 seconds
    [00:05:50.886,291] <dbg> nrf_cloud.nrf_cloud_run: Cloud connection request sent.
    [00:05:51.419,830] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_CONNACK: result 0
    [00:05:51.420,349] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 2
    [00:05:51.420,806] <dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED
    [00:05:51.421,264] <inf> asset_tracker: CLOUD_EVT_CONNECTED
    [00:05:51.421,630] <inf> asset_tracker: Persistent Sessions = 0
    [00:05:51.422,058] <dbg> nrf_cloud_transport.nct_cc_connect: nct_cc_connect
    [00:05:51.423,522] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 3
    [00:05:52.059,844] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 1234 result = 0
    [00:05:52.060,424] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 4
    [00:05:52.060,882] <dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 5678 opcode = 0 len = 0
    [00:05:52.062,408] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5
    [00:05:52.607,849] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 5678 result = 0
    [00:05:52.608,428] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5
    [00:05:52.827,850] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 37916 len = 50
    [00:05:52.830,505] <dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 1 opcode = 1 len = 168
    [00:05:52.832,702] <dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 6
    [00:05:52.833,160] <dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_USER_ASSOCIATION_REQUEST
    [00:05:52.833,648] <inf> asset_tracker: CLOUD_EVT_PAIR_REQUEST
    [00:05:52.834,014] <inf> asset_tracker: Add device to cloud account.
    [00:05:52.834,411] <inf> asset_tracker: Waiting for cloud association...
    [00:05:53.761,901] <dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 1 result = 0
    [00:05:59.922,729] <dbg> lte_lc.at_handler: +CSCON notification
    [00:05:59.923,248] <inf> asset_tracker: RRC mode: Idle
    [00:06:00.181,274] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 1,"2775","00075E21",9,,,"11100000","11100000"
    [00:06:00.182,128] <dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    [00:06:00.182,708] <inf> asset_tracker: cell changed ID: 482849, area: 10101
  • Thanks a lot!
    Could you fire the AT command AT%CMNG=1 and double-check your certificates? It might be useful to delete them all and add the nRF Cloud certificate one more time.
    Markus
  • I started deleting the certificates. I succesfully deleted all certificates in slot 16842753, but I have two certificates left from previous testing in slot 4294967293.. and these two refuse to be deleted. Now, when I look at them.. it seems that the two certificates have wrong type.
    AT%CMNG=1
    %CMNG: 4294967293,10,"0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A"
    %CMNG: 4294967292,11,"0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B"
    OK
    AT%CMNG=3,4294967293,10
    ERROR
    AT%CMNG=3,4294967293,11
    ERROR
    After this, the modem started to behave weirdly: I'm using default at_client and now there's always timout when querying the modem.
    And if I try with asset_tracker, I get the expected:
    asset_tracker: Failed to connect to cloud, error -8
    asset_tracker: Ensure device has a valid CA and client certificate
    Modem fw version is: 1.3.0
    Is there a way to return modem to known good state? Answering my own question:
    I uploaded nordic hex file for at_client and still didn't get any reply from modem; then I reapplied the 1.3.0 fw update and again uploaded at_clinet.. now I get response, but I still can't delete the two remaining certificates.
  • I’m not quite sure what 4294967293 and 4294967292 are, but given the type:
    10 – Nordic identity root CA. Root CA for Nordic identity server.
    11 – Nordic base public key. Used for ownership key provisioning message signature verification.
    one might assume that they are necessary and thus non-erasable.
    I have them on my DK with mfw 1.3.0 as well, which I successfully can connect to the nRF Cloud with.
    Could you try to create a new certificate and connect to the nRF Cloud one more time now?
    Thanks and regards,
    Markus
