I am using nRF52840 on custom board. I am trying to configure SPI pins, but I am not getting anything on the clock pin. I can see the chip select pin going low and high which is good. But there is no clock on the pin. Following is the code snippet from my project.
#define MEM_CS NRF_GPIO_PIN_MAP(0,4)
#define MEM_SI NRF_GPIO_PIN_MAP(0,7)
#define MEM_SO NRF_GPIO_PIN_MAP(1,8)
#define MEM_SCK NRF_GPIO_PIN_MAP(0,13)
void memInit(void)
//GPIO configuration
nrf_gpio_cfg_output(MEM_CS);
nrf_gpio_cfg_output(MEM_SI);
nrf_gpio_cfg_output(MEM_SCK);
nrf_gpio_cfg_input(MEM_SO, GPIO_PIN_CNF_PULL_Pulldown);
//SPI configuration
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = MEM_CS;
spi_config.miso_pin = MEM_SO;
spi_config.mosi_pin = MEM_SI;
spi_config.sck_pin = MEM_SCK;
spi_config.bit_order = NRF_SPI_BIT_ORDER_MSB_FIRST;
spi_config.frequency = NRF_SPI_FREQ_250K;
spi_config.mode = NRF_SPI_MODE_2;
nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL);
uint32_t memId()
__disable_irq();
nrf_gpio_pin_clear(MEM_CS); //Pin goes low now
err = nrf_drv_spi_transfer(&spi, p_tx_buffer, sizeof(tx_buffer), NULL, 0);
nrf_delay_ms(100);
nrf_gpio_pin_set(MEM_CS); //Pin goes high now
__enable_irq();
return err;
For my custom board configuration I have set Preprocessor definitions to BOARD_CUSTOM. But for simplicity, I have defined the pins in the source code file. I am thinking to test it first and then I can define the pins for SPI in custom_board.h. On the custom board I have checked for the pins they are not connected to any other peripheral.
For development, I am using SES with nRF SDK15.0.0 and Softdevice S140.
Any insight would be appreciated.
Thanks!
