High Idle Current Consumption nRF52833 DK
Hi, using the Nordic power profiler 2 (PP2) kit to measure the current draw of my nRF52833 DK. I have followed the instructions to setup/prepare/wire the PP2 to my DK and current measurement appears to be working correctly.
My issue is that my idle current is around 450 uA when running a simple hello world program which should just let the CPU idle once it has run. I'll include my code and files. My question is, what am I doing wrong that I see such a high system idle current?
This is how it is wired up:
nRF Power Source Switch = VDD (button/coin battery is installed)
USB is connected to DK (as seen above) for UART debug/output
Using nRF Connect SDK v1.5.1 with Zephyr.
Do I need to set "CONFIG_SERIAL=n" in the prf.conf to see accurate power readings? I realize I won't be able to see my output via UART console but I believe this is what is causing the high current consumption.
Ideally I would like to be able to see my power output and my console output at the same time but if this isn't possible I can work around it.
Best,
Sam
