Constant TX power without DTM
Hi!
We're working on a testing Jig which should test our units in production.
One of the tests I'd like to make, is measure the current draw on TX at max (8dBm). I would like to do this without flashing my devices with a different firmware than the one I plan to be using for testing, so flashing them with the DTM example will not work.
What I'm looking for is a way to tell me SD- transmit as if you are in TX, with 8dBm power, until I tell you to stop. It does not even have to be BT packages, as long as the power draw simulates a TX event which follows BT protocol well.
Is there a sequence of register values (or SD commands) I can write which will perform the action I've described? If so, what are the values I need to write to stop the TX?
We're using an nrf52833 based device, with SD S113.
Thanks!
