I2C Read transfer doesn't happen with ulTaskNotifyTake
I am using nrf_drv_twi_rx to initiate an I2C read transfer but the interrupt isn't fired for the RX transfer when the ulTaskNotifyTake is used, but seems to work without ulTaskNotifyTake() call. When I hooked up to the logic analyzer, it seems the read bytes aren't sent.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    Sensor *obj = static_cast<Sensor*>(p_context);
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
	            vTaskNotifyGiveFromISR(obj->taskHandle, pdFALSE);
    	    else if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX)
    	      NRF_LOG_INFO("TX transfer done...\n");
            m_xfer_done = true;
void Sensor::initiateI2cRead()
    ret_code_t err_code = nrf_drv_twi_rx(&m_twi, ADDR, _buffer, 2);
void MCP9808::write(uint8_t reg, uint8_t *buffer, uint8_t size)
    ret_code_t err_code;
    err_code = nrf_drv_twi_tx(&m_twi, ADDR, &reg, size, false);
    while (m_xfer_done == false);
void Sensor::xferData(uint8_t size)
    write(reg, size);
void Sensor::mainThread()
    xferData(1);
    while(true)
        initiateI2cRead();
        uint32_t taskNotify = ulTaskNotifyTake(pdTRUE, portMAX_DELAY);
        processData();
