How does the Watchdog work?
Hi, i need to use a watchdog in my application. I read that i can use the build in one, but i thing my configuration or the usage of the watchdog is wrong. here is my config:
void WatchDogInit															(void)
	NRF_WDT->CONFIG =  	(WDT_CONFIG_SLEEP_Run << WDT_CONFIG_SLEEP_Pos);
	NRF_WDT->CRV = (32768 * 1);
	NRF_WDT->RREN = WDT_RREN_RR0_Msk;
    NRF_WDT->INTENSET=WDT_INTENSET_TIMEOUT_Msk;
                                sd_nvic_ClearPendingIRQ(WDT_IRQn);
	sd_nvic_SetPriority				(WDT_IRQn, APP_IRQ_PRIORITY_HIGH);
	sd_nvic_EnableIRQ	 (WDT_IRQn);
	NRF_WDT->TASKS_START = 1; // Watchdog start
when do i have to call this init method? Is tehre anything to lookfor, do i have to run it befor enabling the SD or something like that?
here is my example loop for testing it
					while (true)
						NRF_WDT->RR[0] = WDT_RR_RR_Reload; ;//WDT_RR_RR_Reload;
						switch_stat_g(1);
						nrf_delay_ms(2000);
						switch_stat_g(0);
						nrf_delay_ms(2000);
Do i use it in a wrong way?
Thank you for help and best regards, Nils :)
  • Hi Hakon, Thank you for your answer and your example. I tried out what you told me and i think it doesn't work. If I run your example, the LED flashes up after init but nothing more the is no reset of the WD the LED only blinks one Time, doesn't matter if i do Relaod or not.
    Here is my example i don#t understand why the is no reset. The WD Counter set to 32768 that means a reset after 1 Second, is that right? And i do not reload RR[0] but after One Second is no reset.
    It should be Start->LED on 1 Sek->Reset and don't start while loop. But it starts the while loop.
    Here is my Code:
    #include "nrf51.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include <stdint.h>
    #include <string.h>
    #include <stdbool.h>
    // Counter is in 32kHz ticks. (NRF_WDT->CRV + 1)/32768 seconds
    #define WATCHDOG_COUNTER        32768
    #define MY_LED                  19
    void init_watchdog(void)
        NRF_WDT->CRV = WATCHDOG_COUNTER;
        NRF_WDT->RREN = WDT_RREN_RR0_Enabled << WDT_RREN_RR0_Pos;
    			nrf_gpio_cfg_output(MY_LED);
    			nrf_gpio_pin_set(MY_LED);
    			nrf_delay_ms(1000);
    			init_watchdog ( );
    			nrf_gpio_pin_clear(MY_LED);
    			while (true)
    				//NRF_WDT->RR[0] = WDT_RR_RR_Reload;  //Reload watchdog register 0
    				nrf_delay_ms(600);
    				nrf_gpio_pin_clear(MY_LED),
    				nrf_delay_ms(500);
    I realy don't understand why there is no reset. I think i do a mistake but where?
    Thank you and best regards Nils.
  • Hi Hakon,
    Thank you this was the mistake why the WD did not work as expected. Thank you :)
