nRF9160 SIBA unable to connect to NB-IoT network and resets every ~10 seconds.
nRF9160 SIBA on custom board is unable to connect to NB-IOT and resets after about 10 seconds of operation.
Without a call to lte_lc_init_and_connect the reset does not happen.
The power, as suggested in other topics is at 2.6V from dc power supply with limit set to 1A.
Side note: this setting is the only one allowing for the programmer to reach the SiP. At planned 3.3V the programmer is not able to connect to the chip. For now just a missing power IC -> power supply is used.
Parents Reply
  • Ok, everything turns out to be modem firmware. Matching network from antenna supplier is just fine. Soldering is ok also. But fw v.1.3.0 DOES NOT WORK IN RUSSIAN CELLULAR NETWORKS (NB-IoT way). The two newly assembled boards were upgraded to version 1.2.3 and are doing just fine. Connection and data flow - check!
    To all my russian collegues: do use modem firmware version 1.2.3 and stay well.
