This is somewhat open ended question, but I wanted to know the implications of modifying the default bootloader (one that comes with SDK v6.1.0) upfront, so that the implementation would be easier for me.
Environment:
- nRF51822QFAA (256kB flash)
- SDK v6.1.0
- SoftDevice v7.1.0
- Application size (app.hex file about 84kB, app.bin about 31kB)
- KEIL uVision 5 development environment
- Current bootloader size: 14kB
- DFU OTA mode: Dual
- Custom Board with nRF51822QFAA
1: The default memory layout configuration (0x3C000, 0x40000) of Bootloader reserves 16kB of memory, however with intended modifications, I think bootloader size would reach upto 24kB or so. As of now, the intentions is to program application f/w from the stored f/w in on-board external flash memory connected over SPI. I think it should be straight forward to do appropriate changes in bootloader to pick up the application f/w from the external flash memory and program nRF5182QFAA. This would lead to increase in bootloaer size (may cross 16kB current barrier). Since there is no headroom (0x40000 is the last accessible address), I need to snatch some memory from application and update the bootloader start address accordingly. Please let me know if I should take into consideration some more things.
2: Can I use .bin file instead (generated using fromelf.exe) for application firmware upgrade by using the technique as mentioned in item 1 above.( I know that the DFU-OTA applications such as Nordic nRFToolbox and MCP for Android cellphone require a .hex file and In past I've been able to successfully update the application f/w with .hex file).
Thanks.
