Hi, this overlay file added the node you wanted into the device tree.
res: res_ {
gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
label = "reset epaper";
};Hi,
where I put the overlay file? and how configure SES for use these file?
My file is SmartBug.overlay.
Thanks in avance
Put the overlay file in the same place as the Kconfig and CMakeLists.txt file and name it the same name as the board name you are building for and it will be included in the build (<board_name>.overlay).
I created the file nrf52dk_nrf52832.overlay inside I put the following code:
ereset: reset_ {
gpios = <& gpio0 17 GPIO_ACTIVE_LOW>;
the file is in the same directory as the Kconfig and CMakeList.txt files
Now how do I access the pin defined ereset, without using the alias as I did before.
with the following code:
#define ERESET_NODE DT_ALIAS (ereset)
#if DT_NODE_HAS_STATUS (ERESET_NODE, okay)
#define ERESET DT_GPIO_LABEL (ERESET_NODE, gpios)
#define ERESET_PIN DT_GPIO_PIN (ERESET_NODE, gpios)
#define ERESET_FLAGS DT_GPIO_FLAGS (ERESET_NODE, gpios)
#else / * A build error here means your board isn't set up to blink an LED. * /
#error "Unsupported board: ereset devicetree alias is not defined"
const struct device *deReset;
void Init_gpio () {
deReset = device_get_binding (ERESET);
ret = gpio_pin_configure (deReset, ERESET_PIN, GPIO_OUTPUT_ACTIVE | ERESET_FLAGS);
Thanks in avance
Fausto
Hi, was there a question in there?
Is the code not working? If so, what error are you getting?
