Hello.
I need to add an output gpio to the dts file, I modified the board.dts file, inserting these lines in the leds section
res: res_ {
gpios = <& gpio0 17 GPIO_ACTIVE_LOW>;
label = "reset epaper";
but when I try to compile the application I get the report that the file has been modified externally and after reloading the project, I have an error.
Is there an editor to correctly edit the dts file?
what is the correct procedure to add a gpio in output or in input?
Thank you
