Mqtt connection timeout setting
We have observed that in areas of poor lte connectivity, the client_inti() works well but the mqtt_connect() takes a couple of minutes and times out.
I need to change the mqtt connection timeout duration make it 20-30 seconds, since if it does not connect in this duration, for our use-case, it wont connect after either and the firmware can move on.
In decent lte connectivity regions, mqtt_connect returns within a second or less.
Thanks
Noaman
    Unfortunately, there is no option to set the timeout at this time, but I will add this as a feature request internally.
    Håkon
  • thank you Haken.
    Can you help me add a timeout for http connection requests?
    Regards
    Noaman
    If you enable non-blocking socket operations, the connect() call will return EINPROGRESS until its done.
    That can be done like this:
    #include <fcntl.h>
    	printk("enable non-blocking connect\n");
    	printk("Will return EINPROGRESS (%d) when in progress\n", EINPROGRESS);
    	int flags = fcntl(fd, F_GETFL, 0);
    	int ret = fcntl(fd, F_SETFL, flags | O_NONBLOCK);
    	int rflags = fcntl(fd, F_GETFL, 0);
    	printk("connect time: %lld\n", k_uptime_get());
    	ret = connect(...)
    I added the logic to the https_client sample in ncs v1.6.0 just so that you can see that the call returns almost immediately when you enable nonblocking socket operation.
    diff --git a/samples/nrf9160/https_client/src/main.c b/samples/nrf9160/https_client/src/main.c
    index 509aacb96..18f01a410 100644
    --- a/samples/nrf9160/https_client/src/main.c
    +++ b/samples/nrf9160/https_client/src/main.c
    @@ -5,6 +5,7 @@
     #include <string.h>
    +#include <fcntl.h>
     #include <zephyr.h>
     #include <stdlib.h>
     #include <net/socket.h>
    @@ -202,7 +203,25 @@ void main(void)
     	printk("Connecting to %s\n", "example.com");
    +	#if 1
    +	printk("enable non-blocking connect\n");
    +	printk("Will return EINPROGRESS (%d) when in progress\n", EINPROGRESS);
    +	int flags = fcntl(fd, F_GETFL, 0);
    +	int ret = fcntl(fd, F_SETFL, flags | O_NONBLOCK);
    +	int rflags = fcntl(fd, F_GETFL, 0);
    +	#endif
    +	printk("connect time: %lld\n", k_uptime_get());
    +	/* define this to handle EINPROGRESS scenario */
    +	#if ENABLE_NONBLOCK
    +	do {
    +	#endif
     	err = connect(fd, res->ai_addr, sizeof(struct sockaddr_in));
    +	} while (err == EINPROGRESS);
    +	#endif
     	if (err) {
     		printk("connect() failed, err: %d\n", errno);
     		goto clean_up;
    Håkon
  • Thank you so much Haken.
    Will test this out and let you know.\
    so basically, the do-while loop will keep calling connect repetitively until EINPROGRESS is being returned.
    If I wanted to exit, say after 20 seconds, i can just break out of the while loop and go to clean up? Will that crash anything when the connect request finally returns a few minutes later but the socket has been closed?
    That is up to you how you time out, you can do it this way by breaking out of the loop (and handling the closing scenario), but if the connect() succeeds; you need to handle the scenario of having non-blocking socket operations going on forward (or go back to blocking)
    Håkon
  • Hi Haken,
    I am currently using sdk 1.4.2. should this work on it?
    It does not seem to be working for me. here is the console log
    RRC mode: Connected
    getaddrInfo errno: 0
    fcntl nonblocking set: 0. fd : 0, flags: 16384, rflags: 16384
    In http timer. http state: 3, currentState: 0, httpQuit: 0
    In http timer. http state: 3, currentState: 3, httpQuit: 0
    http waiting to connect
    http: Connected
    "in http timer" is printed every 5 second by a timer callback. "http waiting to connect" is printed from within the do while loop as per code below:
    printk("fcntl nonblocking set: %d. fd : %d, flags: %d, rflags: %d\n", ret, fd, flags, rflags);
    fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TLS_1_2);
    if (fd == -1)
    	if (DEBUG_PRINT_HTTP) printk("Failed to open socket!\n");
    	errorReason = ERROR_HTTP_SOCKET_FAILED;
    	goto clean_up;
    httpState = 2;
    /* Setup TLS socket options */
    err = httpTlsSetup(fd);
    if (err)
    	errorReason = ERROR_HTTP_SECURECLIENT_INIT_FAIL;
    	goto clean_up;
    httpState = 3;
    //Connect
    	waitingToConnect = 0;
    	do
    		err = connect(fd, res->ai_addr , sizeof(struct sockaddr_in));
    		k_sleep(100);
    		waitingToConnect++;
    		printk("http waiting to connect\n");
    	} while ((err == EINPROGRESS) && (waitingToConnect <300));
    	if (err || waitingToConnect >=300)
    		if (DEBUG_PRINT_HTTP) printk("connect() failed, time: %d, err: %d\n", waitingToConnect, errno);
    		if (errno == 23)
    			sys_reboot(0);
    		errorReason = ERROR_HTTP_CONNECT_FAILED;
    		goto clean_up;
    	if (DEBUG_PRINT_HTTP) printk("http: Connected\n");
    "http waiting to connect" should be printed every 100ms if connect() is non-blocking. so it seems that connect() is still using a blocking call.
    My apologies for the late reply.
    This functionality was not added until more recent. Is it technically possible for you to use a newer ncs version?
    Håkon
