Mqtt connection timeout setting
We have observed that in areas of poor lte connectivity, the client_inti() works well but the mqtt_connect() takes a couple of minutes and times out.
I need to change the mqtt connection timeout duration make it 20-30 seconds, since if it does not connect in this duration, for our use-case, it wont connect after either and the firmware can move on.
In decent lte connectivity regions, mqtt_connect returns within a second or less.
Thanks
Noaman
  • Hi Haken,
    I am currently using sdk 1.4.2. should this work on it?
    It does not seem to be working for me. here is the console log
    RRC mode: Connected
    getaddrInfo errno: 0
    fcntl nonblocking set: 0. fd : 0, flags: 16384, rflags: 16384
    In http timer. http state: 3, currentState: 0, httpQuit: 0
    In http timer. http state: 3, currentState: 3, httpQuit: 0
    http waiting to connect
    http: Connected
    "in http timer" is printed every 5 second by a timer callback. "http waiting to connect" is printed from within the do while loop as per code below:
    flags = fcntl(fd, F_GETFL, 0);
    ret = fcntl(fd, F_SETFL, flags | O_NONBLOCK);
    rflags = fcntl(fd, F_GETFL, 0);
    printk("fcntl nonblocking set: %d. fd : %d, flags: %d, rflags: %d\n", ret, fd, flags, rflags);
    fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TLS_1_2);
    if (fd == -1)
    	if (DEBUG_PRINT_HTTP) printk("Failed to open socket!\n");
    	errorReason = ERROR_HTTP_SOCKET_FAILED;
    	goto clean_up;
    httpState = 2;
    /* Setup TLS socket options */
    err = httpTlsSetup(fd);
    if (err)
    	errorReason = ERROR_HTTP_SECURECLIENT_INIT_FAIL;
    	goto clean_up;
    httpState = 3;
    //Connect
    	waitingToConnect = 0;
    	do
    		err = connect(fd, res->ai_addr , sizeof(struct sockaddr_in));
    		k_sleep(100);
    		waitingToConnect++;
    		printk("http waiting to connect\n");
    	} while ((err == EINPROGRESS) && (waitingToConnect <300));
    	if (err || waitingToConnect >=300)
    		if (DEBUG_PRINT_HTTP) printk("connect() failed, time: %d, err: %d\n", waitingToConnect, errno);
    		if (errno == 23)
    			sys_reboot(0);
    		errorReason = ERROR_HTTP_CONNECT_FAILED;
    		goto clean_up;
    	if (DEBUG_PRINT_HTTP) printk("http: Connected\n");
    "http waiting to connect" should be printed every 100ms if connect() is non-blocking. so it seems that connect() is still using a blocking call.
    My apologies for the late reply.
    This functionality was not added until more recent. Is it technically possible for you to use a newer ncs version?
    Håkon
