Hello guys,
I try to implement a pdm sensor on the nrf 52 dk which sends the audio data to a central device.
My setup is two nrf 52 dk one acting with the modified ble app uart example on it (peripheral), the other one with the ble app uart c on it. I checked that my peripheral device sends the data properly and my central device receives it properly. When i try to send the data to the serial port via uarte it always skips a buffer to send to the serial port.
The BLE_NUS_C_EVT_NUS_TX_EVT triggers the sending but before the uarte instance completes the transmission a new transmission event gets triggered. i tried to implement a fifo to handle this issue but this gave me some softdevice assertion error i cant deal with. Is there another way to make the uarte work properly?
Is the atomic fifo maybe a solution ?
or is there a completely different way to implement that?
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrfx_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_gpio.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO 3 /**< BLE observer priority of the application. There is no need to modify this value. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define PIN NRF_GPIO_PIN_MAP(0, 17)
#define ECHOBACK_BLE_UART_DATA 0 /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
#define TX_PIN NRF_GPIO_PIN_MAP(0, 6)
#define RX_PIN NRF_GPIO_PIN_MAP(0, 8)
#define RTS_PIN NRF_GPIO_PIN_MAP(0, 5)
#define CTS_PIN NRF_GPIO_PIN_MAP(0, 7)
bool status=false;
bool write=true;
static const nrfx_uarte_t UARTE_instance = NRFX_UARTE_INSTANCE(0);
volatile int count_buffer=0;
uint32_t buff_len=244;
BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE Nordic UART Service (NUS) client instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
NRF_SDH_BLE_CENTRAL_LINK_COUNT,
NRF_BLE_GQ_QUEUE_SIZE);
static ble_gap_phys_t phys={
.tx_phys=BLE_GAP_PHY_2MBPS,
.rx_phys=BLE_GAP_PHY_2MBPS,
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief NUS UUID. */
static ble_uuid_t const m_nus_uuid =
.uuid = BLE_UUID_NUS_SERVICE,
.type = NUS_SERVICE_UUID_TYPE
//#include "app_fifo.h"
uint8_t send_data_buff[4096] = {0};
//app_fifo_t user_fifo;
//static void ble_nus_chars_received_uart_print(void);
/*void user_app_fifo_init(void)
uint32_t err_code;
err_code = app_fifo_init(&user_fifo,send_data_buff,sizeof(send_data_buff));
/**@brief Function for handling asserts in the SoftDevice.
* @details This function is called in case of an assert in the SoftDevice.
* @warning This handler is only an example and is not meant for the final product. You need to analyze
* how your product is supposed to react in case of assert.
* @param[in] line_num Line number of the failing assert call.
* @param[in] p_file_name File name of the failing assert call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
//UARTE handler - keep it as short as possibile
static void drv_uarte_handler(const nrfx_uarte_event_t *p_event, void *p_context)
if (p_event->type == NRFX_UARTE_EVT_RX_DONE)
status = true;
/**@brief Function for handling the Nordic UART Service Client errors.
* @param[in] nrf_error Error code containing information about what went wrong.
static void nus_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function to start scanning. */
static void scan_start(void)
ret_code_t ret;
ret = nrf_ble_scan_start(&m_scan);
APP_ERROR_CHECK(ret);
ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
ret_code_t err_code;
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
case NRF_BLE_SCAN_EVT_CONNECTED:
ble_gap_evt_connected_t const * p_connected =
p_scan_evt->params.connected.p_connected;
// Scan is automatically stopped by the connection.
NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
p_connected->peer_addr.addr[0],
p_connected->peer_addr.addr[1],
p_connected->peer_addr.addr[2],
p_connected->peer_addr.addr[3],
p_connected->peer_addr.addr[4],
p_connected->peer_addr.addr[5]
} break;
case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
NRF_LOG_INFO("Scan timed out.");
scan_start();
} break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
/**@brief Function for handling database discovery events.
* @details This function is a callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function forwards the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
* @details This function takes a list of characters of length data_len and prints the characters out on UART.
* If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t *pdata ,uint16_t len)
uint8_t check_val=0;
uint32_t err_code = 0xff;
do{
//app_fifo_read(&user_fifo,buf,&buff_len);
err_code =nrfx_uarte_tx(&UARTE_instance,pdata,len);
(err_code != NRF_ERROR_BUSY) &&
}while(err_code==NRF_ERROR_BUSY);//&&(user_fifo.write_pos-user_fifo.read_pos)%244==0);
if(err_code == NRF_SUCCESS)
write=false;
check_val=*(pdata+200);
NRF_LOG_INFO("value at 200 is:%d",check_val);
count_buffer++;
NRF_LOG_INFO("uarte sent length %d",buff_len)// NRF_LOG_HEXDUMP_INFO(pdata,send_len);
//if(count_buffer%2==0)
//NRF_LOG_HEXDUMP_INFO(p_data,data_len);
//__BKPT();
/*void pullin_data(uint8_t *pdata ,uint16_t len)
uint32_t pull_size = len;
uint32_t err_code = 0;
err_code = app_fifo_write(&user_fifo,pdata,&pull_size);
if(err_code == NRF_ERROR_NO_MEM || pull_size != len)
//no memory
NRF_LOG_INFO("pull_size=%d",pull_size);
NRF_LOG_FLUSH();
//ble_nus_chars_received_uart_print();
/**@brief Function for handling app_uart events.
* @details This function receives a single character from the app_uart module and appends it to
* a string. The string is sent over BLE when the last character received is a
* 'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
static uint16_t index = 0;
uint32_t ret_val;
switch (p_event->evt_type)
/**@snippet [Handling data from UART] */
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= (m_ble_nus_max_data_len)))
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
APP_ERROR_CHECK(ret_val);
} while (ret_val == NRF_ERROR_RESOURCES);
index = 0;
NRF_LOG_ERROR("Communication error occurred while handling UART.");
case APP_UART_FIFO_ERROR:
NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
* @details This function is called to notify the application of NUS client events.
* @param[in] p_ble_nus_c NUS client handle. This identifies the NUS client.
* @param[in] p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("Discovery complete.");
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
case BLE_NUS_C_EVT_NUS_TX_EVT:
//pullin_data(p_ble_nus_evt->p_data,p_ble_nus_evt->data_len);
ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data,p_ble_nus_evt->data_len);
NRF_LOG_INFO("data_received")
case BLE_NUS_C_EVT_DISCONNECTED:
NRF_LOG_INFO("Disconnected.");
scan_start();
* @brief Function for handling shutdown events.
* @param[in] event Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
// Prepare wakeup buttons.
return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_CONNECTED:
err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
// start discovery of services. The NUS Client waits for a discovery result
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
//err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys);
//APP_ERROR_CHECK(err_code);
NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
p_gap_evt->conn_handle,
p_gap_evt->params.disconnected.reason);
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
// Pairing not supported.
err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_2MBPS,
.tx_phys = BLE_GAP_PHY_2MBPS,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
case BLE_GAP_EVT_PHY_UPDATE:
ble_gap_evt_phy_update_t const * p_phy_evt = &p_ble_evt->evt.gap_evt.params.phy_update;
if (p_phy_evt->status == BLE_HCI_STATUS_CODE_LMP_ERROR_TRANSACTION_COLLISION)
// Ignore LL collisions.
NRF_LOG_DEBUG("LL transaction collision during PHY update.");
ble_gap_phys_t phys = {0};
phys.tx_phys = p_phy_evt->tx_phy;
phys.rx_phys = p_phy_evt->rx_phy;
if(p_phy_evt->status == BLE_HCI_STATUS_CODE_SUCCESS) {
NRF_LOG_INFO("PHY update accepted");
} break;
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("ATT MTU exchange completed.");
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART. */
static void uart_init(void)
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
//UARTE initialization
static void uarte_init(void)
nrfx_err_t err_code;
nrfx_uarte_config_t uarte_config = {
.pseltxd = TX_PIN,
.pselrxd = RX_PIN,
.pselcts = CTS_PIN,
.pselrts = RTS_PIN,
.p_context = NULL,
.hwfc = NRF_UARTE_HWFC_DISABLED,
.parity = NRF_UARTE_PARITY_EXCLUDED,
.baudrate = NRF_UARTE_BAUDRATE_1000000,
.interrupt_priority=3,
err_code = nrfx_uarte_init(&UARTE_instance, &uarte_config, drv_uarte_handler);
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
ble_nus_c_init_t init;
init.evt_handler = ble_nus_c_evt_handler;
init.error_handler = nus_error_handler;
init.p_gatt_queue = &m_ble_gatt_queue;
err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
ble_db_discovery_init_t db_init;
memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
db_init.evt_handler = db_disc_handler;
db_init.p_gatt_queue = &m_ble_gatt_queue;
ret_code_t err_code = ble_db_discovery_init(&db_init);
* @details Handles any pending log operations, then sleeps until the next event occurs.
nrf_pwr_mgmt_run();
// Initialize.
log_init();
timer_init();
//uart_init();
uarte_init();
//user_app_fifo_init();
buttons_leds_init();
db_discovery_init();
power_management_init();
ble_stack_init();
gatt_init();
nus_c_init();
scan_init();
// Start execution.
NRF_LOG_INFO("BLE UART central example started.");
scan_start();
// Enter main loop.
for (;;)
idle_state_handle();
