nrf connect sdk add custom section(UICR)
Hello
I want to add a UICR section. but I don't know how to add a custom section in ncs(also zephyr).
I have researched about this for days and I've found zephyr code realocation, but I don't want realocate the code. (SRAM, SRAM2, TEXT ...)
All I want is add a UICR section without realocate the other things.
Also I want to know how to change UICR REGOUT0 register value in ncs(also zephyr).
Thanks.
  • I want to add a UICR section. but I don't know how to add a custom section in ncs(also zephyr).
     You need to have a linker script (*.ld for gcc)Where you create a MEMORY section and define that section in SECTIONS of the linker script. Once you have that linker script you can include your custom linker scripts using this define.
     UICR registers are not designed to be edited/changed after writing one value to the register. You need to erase the whole flash to be able to rewrite to UICR registers.
  • Is there an any example?
    I don't know how to write a linker script.
    Also in my research, add a custom linker script should rewrite the whole sections. and I dont want to do that.
    * All I want is change REGOUT0 value to change the gpip reference voltage. and I dont care about the method.
  • If writing to UICR is the thing you are trying to achieve then probably SOC_FLASH_NRF_UICR is your helper feature. You do not need any additional linker scripts when you enable this feature. You can write to this register as a normal flash write.
  • Finally I have wrote this code.
    It works very well.
        // Write UICR's REGOUT0 register to given value
        #if ( CONFIG_NRF52_ENABLE_DCDC == 1 )
            if ( NRF_UICR->REGOUT0 != (uint32_t)CONFIG_NRF52_DCDC_REGOUT_VALUE ) {
                nrfx_err_t err = NRFX_SUCCESS;
                NRF_UICR_Type tmp;
                memcpy( &tmp, NRF_UICR, sizeof(NRF_UICR_Type) );
                tmp.REGOUT0 = (uint32_t)CONFIG_NRF52_DCDC_REGOUT_VALUE;
                err = nrfx_nvmc_uicr_erase( );
                __ASSERT( (err == NRFX_SUCCESS), "NVMC erase UICR failed" );
                nrfx_nvmc_bytes_write( NRF_UICR_BASE, &tmp, sizeof(NRF_UICR_Type) );
                while ( nrfx_nvmc_write_done_check() != true );
                LOG_INF( "REGOUT0 writed to %u", CONFIG_NRF52_DCDC_REGOUT_VALUE );
