I've tried to drop in all non-main code from the spi 5W example into my program and I keep getting the following errors:
.\_build\nrf51422_xxac_s110.axf: Error: L6218E: Undefined symbol ble_gattc_evt_rel_disc_rsp_enc (referred from ble_event.o).
.\_build\nrf51422_xxac_s110.axf: Error: L6218E: Undefined symbol ble_enable_req_dec (referred from conn_mw_ble.o).
.\_build\nrf51422_xxac_s110.axf: Error: L6218E: Undefined symbol ble_enable_rsp_enc (referred from conn_mw_ble.o).
For the case of ble_gattc_evt_rel_disc_rsp_enc, if I go to the reference in ble_events (line 120) and ask the IDE to show me the definition of ble_gattc_evt_rel_disc_rsp_enc it throws up an error message that it can't resolve the reference. When I ask the IDE to show me the reference then it properly brings up the declaration in ble_gattc_evt_conn.h
When I look in the map file it show the linker removing ble_gattc_evt_rel_disc_rsp.o. I'm using the s110 soft device. The ble_gattc_evt_rel_disc_rsp.o file is indeed being generated during builds.
I've looked very carefully in the project options (and project files) to make sure I have all of the same files included as the example project. The file ble_gattc_evt_desc_disc_rsp.c is indeed included in the project as shown in the Manage Project Items/Project Items dialog. I have duplicated the Groups structure used in the SPI 5W example
Is there a reasonable way to do a diff on the configuration files? Any suggestions on how to track down this issue?
Additional info.
This is from the .dep file:
I (..........\components\drivers_nrf\hal\compiler_abstraction.h)(0x54B7F1BA) F (..........\components\serialization\application\codecs\s110\serializers\ble_gattc_evt_rel_disc_rsp.c)(0x54B7F1B0)(-c --cpu Cortex-M0 -D_EVAL -D_MICROLIB -g -O3 --apcs=interwork --split_sections -I..........\components\toolchain -I..........\components\softdevice\s110\headers -I..........\components\ble\common -I..........\components\drivers_nrf\simple_uart -I..........\components\libraries\button -I........\bsp -I..........\components\softdevice\common\softdevice_handler -I..........\components\libraries\timer -I..........\components\libraries\gpiote -I..........\components\drivers_nrf\hal -I..........\components\libraries\scheduler -I..........\components\libraries\util -I..........\components\toolchain\gcc -I......\Foo-Bar -I..........\components\drivers_ext\nrf6350 -I..........\components\drivers_nrf\twi_master -I..........\components\serialization\common\transport\ser_phy -I..........\components\serialization\common\transport -I..........\components\serialization\connectivity -I..........\components\serialization\application\transport -I..........\components\libraries\crc16 -I..........\components\serialization\common -I..........\components\serialization\connectivity\codecs\s110\serializers -I..........\components\serialization\common\struct_ser\s110 -I..........\components\serialization\connectivity\codecs\common -I..........\components\serialization\connectivity\hal -I..........\components\drivers_nrf\uart -I..........\components\serialization\common\transport\ser_phy\config -I..........\components\drivers_nrf\spi_slave -I..........\components\drivers_nrf\spi_master -I..........\components\serialization\connectivity\codecs\s110\middleware -I..........\components\ble\ble_dtm --c99
-I "C:\Nordic Semiconductor\nRF51_SDK_7.2.0_cf547b5\examples\ble_peripheral\foobar-nrf51\pca10028\arm\RTE"
-I C:\Keil_v5\ARM\PACK\NordicSemiconductor\nRF_DeviceFamilyPack\7.2.1\Device\Include
-I C:\Keil_v5\ARM\CMSIS\Include
-D__UVISION_VERSION="514" -DNRF51 -DBOARD_PCA10001 -DNRF51 -DBLE_STACK_SUPPORT_REQD -DS110 -DSOFTDEVICE_PRESENT -DDEBUG -DSER_CONNECTIVITY -DAPP_SCHEDULER_WITH_PAUSE -DBLE_STACK_SUPPORT_REQD
-o ._build\ble_gattc_evt_rel_disc_rsp.o --omf_browse ._build\ble_gattc_evt_rel_disc_rsp.crf --depend ._build\ble_gattc_evt_rel_disc_rsp.d)
And this is from the MAP file:
Component: ARM Compiler 5.05 update 1 (build 106) Tool: armlink [4d0efa]
Section Cross References ... ble_gattc_evt_rel_disc_rsp.o(i.ble_gattc_evt_rel_disc_rsp_dec) refers to ble_serialization.o(i.uint16_t_dec) for uint16_t_dec ble_gattc_evt_rel_disc_rsp.o(i.ble_gattc_evt_rel_disc_rsp_dec) refers to ble_gattc_struct_serialization.o(i.ble_gattc_evt_rel_disc_rsp_t_dec) for ble_gattc_evt_rel_disc_rsp_t_dec ... ble_gattc_struct_serialization.o(i.ble_gattc_evt_rel_disc_rsp_t_dec) refers to ble_serialization.o(i.uint16_t_dec) for uint16_t_dec ble_gattc_struct_serialization.o(i.ble_gattc_evt_rel_disc_rsp_t_dec) refers to ble_gattc_struct_serialization.o(i.ble_gattc_include_t_dec) for ble_gattc_include_t_dec ble_gattc_struct_serialization.o(i.ble_gattc_evt_rel_disc_rsp_t_enc) refers to ble_serialization.o(i.uint16_t_enc) for uint16_t_enc ble_gattc_struct_serialization.o(i.ble_gattc_evt_rel_disc_rsp_t_enc) refers to ble_gattc_struct_serialization.o(i.ble_gattc_include_t_enc) for ble_gattc_include_t_enc
Removing Unused input sections from the image.
... Removing ble_gattc_evt_rel_disc_rsp.o(i.ble_gattc_evt_rel_disc_rsp_dec), (242 bytes). .... Removing ble_gattc_struct_serialization.o(i.ble_gattc_evt_rel_disc_rsp_t_dec), (92 bytes). Removing ble_gattc_struct_serialization.o(i.ble_gattc_evt_rel_disc_rsp_t_enc), (78 bytes).
