nRF52840 DFU issue(ncs1.5.0).
I refer to this guide to add dfu to peripheral_uart. The program runs on nRF52840DK.
1、prj.conf
I added the following macros.
CONFIG_MCUMGR=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_SMP_BT=y
CONFIG_BOOTLOADER_MCUBOOT=y
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is not printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_UART_Serial"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Config logger
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=y
CONFIG_RTT_CONSOLE=y
CONFIG_ASSERT=y
# DFU
CONFIG_MCUMGR=y
2、main.c
 * Copyright (c) 2018 Nordic Semiconductor ASA
/** @file
 *  @brief Nordic UART Bridge Service (NUS) sample
#include <zephyr/types.h>
#include <zephyr.h>
#include <drivers/uart.h>
#include <device.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/hci.h>
#include <bluetooth/services/nus.h>
#include <dk_buttons_and_leds.h>
#include <settings/settings.h>
#include <stdio.h>
#include <logging/log.h>
#define LOG_MODULE_NAME peripheral_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED DK_LED1
#define RUN_LED_BLINK_INTERVAL 1000
#define CON_STATUS_LED DK_LED2
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_conn *current_conn;
static struct bt_conn *auth_conn;
static const struct device *uart;
static struct k_delayed_work uart_work;
struct uart_data_t {
	void *fifo_reserved;
	uint8_t data[UART_BUF_SIZE];
	uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static uint8_t *current_buf;
	static size_t aborted_len;
	static bool buf_release;
	struct uart_data_t *buf;
	static uint8_t *aborted_buf;
	switch (evt->type) {
	case UART_TX_DONE:
		if ((evt->data.tx.len == 0) ||
		    (!evt->data.tx.buf)) {
			return;
		if (aborted_buf) {
			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
					   data);
			aborted_buf = NULL;
			aborted_len = 0;
		} else {
			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
					   data);
		k_free(buf);
		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
		if (!buf) {
			return;
		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
			LOG_WRN("Failed to send data over UART");
	case UART_RX_RDY:
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		buf->len += evt->data.rx.len;
		buf_release = false;
		if (buf->len == UART_BUF_SIZE) {
			k_fifo_put(&fifo_uart_rx_data, buf);
		} else if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
			  (evt->data.rx.buf[buf->len - 1] == '\r')) {
			current_buf = evt->data.rx.buf;
			buf_release = true;
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		buf = k_malloc(sizeof(*buf));
		if (buf) {
			buf->len = 0;
		} else {
			LOG_WRN("Not able to allocate UART receive buffer");
			k_delayed_work_submit(&uart_work,
					      UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf->data, sizeof(buf->data),
			       UART_WAIT_FOR_RX);
	case UART_RX_BUF_REQUEST:
		if (buf) {
			buf->len = 0;
			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
		} else {
	case UART_RX_BUF_RELEASED:
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
				   data);
		if (buf_release && (current_buf != evt->data.rx_buf.buf)) {
			k_free(buf);
			current_buf = NULL;
	case UART_TX_ABORTED:
			if (!aborted_buf) {
				aborted_buf = (uint8_t *)evt->data.tx.buf;
			aborted_len += evt->data.tx.len;
					   data);
			uart_tx(uart, &buf->data[aborted_len],
				buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf) {
		buf->len = 0;
	} else {
		k_delayed_work_submit(&uart_work, UART_WAIT_FOR_BUF_DELAY);
		return;
	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
static int uart_init(void)
	int err;
	struct uart_data_t *rx;
	uart = device_get_binding(DT_LABEL(DT_NODELABEL(uart0)));
	if (!uart) {
		return -ENXIO;
	rx = k_malloc(sizeof(*rx));
	if (rx) {
		rx->len = 0;
	} else {
		return -ENOMEM;
	k_delayed_work_init(&uart_work, uart_work_handler);
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		return err;
	return uart_rx_enable(uart, rx->data, sizeof(rx->data), 50);
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		LOG_ERR("Connection failed (err %u)", err);
		return;
	LOG_INF("Connected %s", log_strdup(addr));
	current_conn = bt_conn_ref(conn);
	dk_set_led_on(CON_STATUS_LED);
	LOG_INF("Disconnected: %s (reason %u)", log_strdup(addr), reason);
	if (auth_conn) {
		bt_conn_unref(auth_conn);
		auth_conn = NULL;
	if (current_conn) {
		bt_conn_unref(current_conn);
		current_conn = NULL;
		dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_NUS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		LOG_INF("Security changed: %s level %u", log_strdup(addr),
			level);
	} else {
		LOG_WRN("Security failed: %s level %u err %d", log_strdup(addr),
			level, err);
static struct bt_conn_cb conn_callbacks = {
	.connected    = connected,
	.disconnected = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	LOG_INF("Passkey for %s: %06u", log_strdup(addr), passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
	auth_conn = bt_conn_ref(conn);
	LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
static void auth_cancel(struct bt_conn *conn)
	LOG_INF("Pairing cancelled: %s", log_strdup(addr));
static void pairing_confirm(struct bt_conn *conn)
	bt_conn_auth_pairing_confirm(conn);
	LOG_INF("Pairing confirmed: %s", log_strdup(addr));
static void pairing_complete(struct bt_conn *conn, bool bonded)
	LOG_INF("Pairing completed: %s, bonded: %d", log_strdup(addr),
		bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	LOG_INF("Pairing failed conn: %s, reason %d", log_strdup(addr),
		reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.passkey_confirm = auth_passkey_confirm,
	.cancel = auth_cancel,
	.pairing_confirm = pairing_confirm,
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
			  uint16_t len)
	int err;
	char addr[BT_ADDR_LE_STR_LEN] = {0};
	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
	LOG_INF("Received data from: %s", log_strdup(addr));
	for (uint16_t pos = 0; pos != len;) {
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx) {
			LOG_WRN("Not able to allocate UART send data buffer");
			return;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx->data) - 1;
		if ((len - pos) > tx_data_size) {
			tx->len = tx_data_size;
		} else {
			tx->len = (len - pos);
		memcpy(tx->data, &data[pos], tx->len);
		pos += tx->len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) && (data[len - 1] == '\r')) {
			tx->data[tx->len] = '\n';
			tx->len++;
		err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
		if (err) {
			k_fifo_put(&fifo_uart_tx_data, tx);
static struct bt_nus_cb nus_cb = {
	.received = bt_receive_cb,
void error(void)
	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
	while (true) {
		/* Spin for ever */
		k_sleep(K_MSEC(1000));
static void num_comp_reply(bool accept)
	if (accept) {
		bt_conn_auth_passkey_confirm(auth_conn);
		LOG_INF("Numeric Match, conn %p", auth_conn);
	} else {
		bt_conn_auth_cancel(auth_conn);
		LOG_INF("Numeric Reject, conn %p", auth_conn);
	auth_conn = NULL;
void button_changed(uint32_t button_state, uint32_t has_changed)
	uint32_t buttons = button_state & has_changed;
	if (auth_conn) {
		if (buttons & KEY_PASSKEY_ACCEPT) {
			num_comp_reply(true);
		if (buttons & KEY_PASSKEY_REJECT) {
			num_comp_reply(false);
static void configure_gpio(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		LOG_ERR("Cannot init buttons (err: %d)", err);
	err = dk_leds_init();
	if (err) {
		LOG_ERR("Cannot init LEDs (err: %d)", err);
#ifdef CONFIG_MCUMGR_CMD_OS_MGMT
#include "os_mgmt/os_mgmt.h"
#ifdef CONFIG_MCUMGR_CMD_IMG_MGMT
#include "img_mgmt/img_mgmt.h"
void main(void)
	int blink_status = 0;
	int err = 0;
	os_mgmt_register_group();
	img_mgmt_register_group();
	configure_gpio();
	err = uart_init();
	if (err) {
		error();
	bt_conn_cb_register(&conn_callbacks);
	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
		bt_conn_auth_cb_register(&conn_auth_callbacks);
	err = bt_enable(NULL);
	if (err) {
		error();
	LOG_INF("Bluetooth initialized");
	k_sem_give(&ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_nus_init(&nus_cb);
	if (err) {
		LOG_ERR("Failed to initialize UART service (err: %d)", err);
		return;
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
			      ARRAY_SIZE(sd));
	if (err) {
		LOG_ERR("Advertising failed to start (err %d)", err);
	printk("Starting Nordic UART service example\n");
        smp_bt_register();
	for (;;) {
		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
void ble_write_thread(void)
	/* Don't go any further until BLE is initialized */
	k_sem_take(&ble_init_ok, K_FOREVER);
	for (;;) {
		/* Wait indefinitely for data to be sent over bluetooth */
		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
						     K_FOREVER);
		if (bt_nus_send(NULL, buf->data, buf->len)) {
			LOG_WRN("Failed to send data over BLE connection");
		k_free(buf);
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
		NULL, PRIORITY, 0, 0);
SMP is successfully displayed after establishing a connection in nRF Connect. When I did DFU, it was not successful. The host exited after receiving a few messages, and no error was reported.
52840 log:
[00:00:00.344,329] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.344,329] <inf> fs_nvs: alloc wra: 0, ff0
[00:00:00.344,329] <inf> fs_nvs: data wra: 0, 0
[00:00:00.344,512] <inf> sdc_hci_driver: SoftDevice Controller build revision:
                                         e5 c7 9c d9 91 00 1d 66  ea fb 6e 7b 98 2f 42 0d |.......f ..n{./B.
                                         f1 60 93 c8                                      |.`..
[00:00:00.348,571] <inf> bt_hci_core: No ID address. App must call settings_load()
[00:00:00.348,571] <inf> peripheral_uart: Bluetooth initialized
[14:54:04.504]收←◆[00:00:04.033,874] <inf> peripheral_uart: Connected 5B:0F:F1:D3:35:DE (random)
[14:54:08.398]收←◆[
[14:54:08.432]收←◆00:00:07.928,497] <inf> peripheral_uart: Passkey for 5B:0F:F1:D3:35:DE (random): 863986
[00:00:07.928,527] <inf> peripheral_uart: Press Button 1 to confirm, Button 2 to reject.
[14:54:14.173]收←◆[00:00
[14:54:14.205]收←◆:13.703,277] <inf> peripheral_uart: button!
[00:00:13.708,068] <inf> peripheral_uart: Numeric Match, conn 0x20002398
[00:00:13.869,720] <inf> peripheral_uart: button!
[00:00:14.047,698] <inf> peripheral_uart: Security changed: 5B:0F:F1:D3:35:DE (random) level 4
[00:00:14.165,527] <inf> peripheral_uart: Pairing completed: 88:46:04:4D:00:E9 (public), bonded: 1
[14:54:46.918]收←◆[00:00
[14:54:46.949]收←◆:46.448,028] <inf> mcuboot_util: Swap type: none
[14:56:59.307]收←◆[00:02:58.837,921] <wrn> bt_att: Unhandled ATT code 0x1d
app log:
nRF Connect, 2021-07-01
Nordic_UART_Serial (CA:2A:D5:51:80:86)
V	14:54:10.870	Connecting to CA:2A:D5:51:80:86...
D	14:54:10.870	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D	14:54:11.258	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D	14:54:11.263	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	14:54:11.263	Connected to CA:2A:D5:51:80:86
V	14:54:11.269	Discovering services...
D	14:54:11.269	gatt.discoverServices()
I	14:54:11.510	PHY updated (TX: LE 2M, RX: LE 2M)
I	14:54:11.961	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
D	14:54:12.192	[Callback] Services discovered with status: 0
I	14:54:12.192	Services discovered
V	14:54:12.200	Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
   Client Characteristic Configuration (0x2902)
- Client Supported Features [R W] (0x2B29)
- Database Hash [R] (0x2B2A)
Generic Access (0x1800)
- Device Name [R] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e)
- TX Characteristic [N] (6e400003-b5a3-f393-e0a9-e50e24dcca9e)
- RX Characteristic [W WNR] (6e400002-b5a3-f393-e0a9-e50e24dcca9e)
SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
- SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
D	14:54:12.200	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
D	14:54:12.201	gatt.setCharacteristicNotification(6e400003-b5a3-f393-e0a9-e50e24dcca9e, true)
I	14:54:12.275	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
V	14:54:14.593	Starting pairing...
D	14:54:14.593	device.createBond()
D	14:54:14.615	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
D	14:54:14.860	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_PASSKEY_CONFIRMATION (2)
I	14:54:16.415	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
D	14:54:20.975	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
I	14:54:20.975	Device bonded
V	14:54:51.358	[McuMgr] Connecting...
D	14:54:51.361	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D	14:54:51.371	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I	14:54:51.375	[McuMgr] Connected to CA:2A:D5:51:80:86
D	14:54:51.382	[McuMgr] wait(1600)
V	14:54:52.986	[McuMgr] Discovering services...
D	14:54:52.992	[McuMgr] gatt.discoverServices()
I	14:54:53.000	[McuMgr] Services discovered
V	14:54:53.005	[McuMgr] Primary service found
V	14:54:53.008	[McuMgr] Requesting new MTU...
D	14:54:53.011	[McuMgr] gatt.requestMtu(515)
I	14:54:53.092	[McuMgr] MTU changed to: 65
D	14:54:53.097	[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V	14:54:53.100	[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D	14:54:53.103	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	14:54:53.271	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I	14:54:53.275	[McuMgr] Notifications enabled
V	14:54:53.281	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D	14:54:53.285	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I	14:54:53.290	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
A	14:54:53.296	[McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Command Id: 0 (STATE)
Message: {}" sent
I	14:54:53.362	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-DA-F3-06-6E-EB-7A-69-B1-7B-1C-25-F2-8E-E3-F3-A2-19
I	14:54:53.367	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 32-15-0B-F7-88-C1-98-E4-E3-F9-8C-AA-99-23-67-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
I	14:54:53.370	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A	14:54:53.382	[McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"2vMGbut6abF7HCXyjuPzohkyFQv3iMGY5OP5jKqZI2c=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
V	14:54:53.388	[McuMgr] Uploading firmware...
Am I missing a step that I didn’t do. I can't find where the problem is.
  • Does anyone answer? Or you can give a demo that can successfully dfu.
    Sorry for the delay. The support staff is reduced during the summer holidays, and you may experience delayed answers.
    I remove my previous answer which was left quickly before my vacation.  I make a peripheral_uart with DFU work for v1.5.0. Hope it can help you.
    prj.conf
    # SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    CONFIG_SERIAL=y
    CONFIG_CONSOLE=y
    CONFIG_GPIO=y
    CONFIG_CONSOLE=y
    CONFIG_BT=y
    CONFIG_BT_DEVICE_NAME="Nordic_UART_Servce"
    # Allow for large Bluetooth data packets.
    CONFIG_BT_L2CAP_TX_MTU=252
    CONFIG_BT_L2CAP_RX_MTU=252
    CONFIG_BT_RX_BUF_LEN=260
    CONFIG_BT_NUS=y
    # Enable bonding
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    CONFIG_DK_LIBRARY=y
    # Config logger
    CONFIG_LOG=y
    CONFIG_ASSERT=y
    # Enable DFU
    CONFIG_MCUMGR=y
    CONFIG_MCUBOOT_IMAGE_VERSION="3.0.0"
    main.c
     * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    /** @file
    #include <zephyr.h>
    #include <mgmt/mcumgr/smp_bt.h>
    #include <device.h>
    #include <soc.h>
    #include <stdio.h>
    #define PRIORITY 7
    	uint16_t len;
    	ARG_UNUSED(dev);
    	case UART_TX_DONE:
    			return;
    		if (aborted_buf) {
    					   data);
    			aborted_buf = NULL;
    			aborted_len = 0;
    		} else {
    					   data);
    		k_free(buf);
    		if (!buf) {
    			return;
    	case UART_RX_RDY:
    			buf_release = true;
    		if (buf) {
    			buf->len = 0;
    		} else {
    			return;
    			       UART_WAIT_FOR_RX);
    		if (buf) {
    			buf->len = 0;
    		} else {
    				   data);
    			k_free(buf);
    			current_buf = NULL;
    			if (!aborted_buf) {
    					   data);
    	if (buf) {
    		buf->len = 0;
    	} else {
    		return;
    	int err;
    	if (!uart) {
    		return -ENXIO;
    	if (rx) {
    		rx->len = 0;
    	} else {
    		return -ENOMEM;
    	if (err) {
    		return err;
    	if (err) {
    		return;
    	if (auth_conn) {
    		auth_conn = NULL;
    	if (current_conn) {
    	if (!err) {
    			level);
    	} else {
    			level, err);
    		bonded);
    		reason);
    #else
    			  uint16_t len)
    	int err;
    		if (!tx) {
    			return;
    		} else {
    		pos += tx->len;
    			tx->len++;
    		if (err) {
    void error(void)
    	while (true) {
    		/* Spin for ever */
    	if (accept) {
    	} else {
    	auth_conn = NULL;
    	if (auth_conn) {
    	int err;
    	if (err) {
    	if (err) {
    void main(void)
    	int err = 0;
    	configure_gpio();
    	err = uart_init();
    	if (err) {
    		error();
        /* Initialize the Bluetooth mcumgr transport. */
    	smp_bt_register();
    	if (err) {
    		error();
    		settings_load();
    	if (err) {
    		return;
    			      ARRAY_SIZE(sd));
    	if (err) {
    	for (;;) {
    	for (;;) {
    						     K_FOREVER);
    		k_free(buf);
    5811.peripheral_uart_DFU_ncs1.5.0.zip
    -Amanda
