Currently I am trying to add uart functionality to the dimming client from the mesh dimming example, but I just can never seem to get it to compile. I can confirm my uart code works and compiled as I have used it in the nrf5sdk and compiles fine there. I put the code from my project in the nrf5sdk into the files uarte_link.h and uarte_link.c and add it to the dimming client in the nrf5sdk for mesh example and suddenly I just cannot get it to compile no matter what I try
Here are the exact steps that I have done:
1. Added my own file uarte_link.c file to the project
2. Then I tried compiling and get "app_uart.h not found error". To solve this I added the folder that contains this file in my user include directories
3. Tried compiling again, this time i get errors: "undefined reference to app_uart_init" and "undefined reference to "app_uart_get"
4. I realized i needed to add the corresponding source files, so I added the following to my project: "app_fifo.c, app_uart.c, app_uart_fifo.c, nrf_drv_uart.c, nrfx_uarte.c, retarget.c"
5. Compiling after this gives me these errors in nrf_drv_uart.h:
error: unknown type name ‘nrf_uarte_baudrate_t’
error: unknown type name ‘nrf_uarte_error_mask_t’
error: unknown type name ‘nrf_uarte_hwfc_t’
error: unknown type name ‘nrf_uarte_parity_t’
error: unknown type name ‘nrf_uarte_task_t’
error: unknown type name ‘nrf_uarte_event_t’
6. I figured the problem might be in my sdk_config.h file. I set NRFX_UART_ENABLED and NRFX_UARTE_ENABLED. I also add APP_FIFO_ENABLED and APP_UART_ENABLED and set them to 1 in app_config.h since I noticed those settings were set in my original uart code from the other SDK but were not defined in the sdk_config.h. I try compiling again, and I get the same error as above
7. Then at this point I try a bunch of other random stuff including anything I would think would be dependent and screwing around with a lot of settings in general, but to no luck. This is when I got extremely frustrated with the sdk after spending hours on this
I hope someone can help, since I have grown too frustrated at hunting through the SDK to find the files I need. This has overall given me a negative opinion Nordic's SDK organization which is a shame since I found actual programming itself to be relatively straightforward
