Dear friends,
When I reset 52840 DK and reopen the PyACI script , then, reloading the DB(database/example_database.json), I found the provsioned device can't be controled again.
I refrence this case ,however, we can't get any data from the provsioned device, attach my test code:
db = MeshDB("database/example_database.json")
p = Provisioner(device, db)
device.send(cmd.DevkeyAdd(db.nodes[0].unicast_address, 0, db.nodes[0].device_key))
device.send(cmd.AddrPublicationAdd(db.nodes[0].unicast_address))
cc = ConfigurationClient(db)
device.model_add(cc)
cc.publish_set(8, 0)
cc.composition_data_get()
and the test log:
E:\bluemesh\fortest\nrf5_SDK_for_Mesh_v2.2.0_src\scripts\interactive_pyaci> C:\Users\admin\AppData\Local\Programs\Python\Python38\python.exe interactive_pyaci.py -d COM4
To control your device, use d[x], where x is the device index.
Devices are indexed based on the order of the COM ports specified by the -d option.
The first device, d[0], can also be accessed using device.
Type d[x]. and hit tab to see the available methods.
Python 3.8.6 (tags/v3.8.6:db45529, Sep 23 2020, 15:52:53) [MSC v.1927 64 bit (AMD64)]
Type 'copyright', 'credits' or 'license' for more information
IPython 7.23.1 -- An enhanced Interactive Python. Type '?' for help.
In [1]:
In [2]: db = MeshDB("database/example_database.json")
...: p = Provisioner(device, db)
In [3]: 2021-07-02 17:32:31,468 - INFO - COM4: Success
2021-07-02 17:32:31,469 - INFO - COM4: Success
2021-07-02 17:32:31,473 - INFO - COM4: SubnetAdd: {'subnet_handle': 0}
2021-07-02 17:32:31,481 - INFO - COM4: AppkeyAdd: {'appkey_handle': 0}
2021-07-02 17:32:31,482 - INFO - COM4: AppkeyAdd: {'appkey_handle': 1}
In [3]:
In [3]: db.nodes[0].unicast_address
Out[3]: 0010
In [4]: device.send(cmd.DevkeyAdd(db.nodes[0].unicast_address, 0, db.nodes[0].device_key))
...: device.send(cmd.AddrPublicationAdd(db.nodes[0].unicast_address))
2021-07-02 17:32:46,728 - INFO - COM4: DevkeyAdd: {'devkey_handle': 8}
2021-07-02 17:32:46,729 - INFO - COM4: AddrPublicationAdd: {'address_handle': 0}In [5]:
In [5]:
In [5]: cc = ConfigurationClient(db)
...: device.model_add(cc)
...: cc.publish_set(8, 0)
...: cc.composition_data_get()
2021-07-02 17:32:56,990 - INFO - COM4: Success
In [6]:
In [6]:
In [6]:
In [6]: cc.composition_data_get()
In [7]: 2021-07-02 17:33:17,492 - INFO - COM4: Success
In [7]:
In [7]:
Could you give me some advice for realize this functionality?
Thank you in advance.
