I want to recover control provisoned device, when I reopen the PyACI script and reset the 52840 DK
Dear friends,
When I reset 52840 DK and reopen the PyACI script , then, reloading the DB(database/example_database.json), I found the provsioned device can't be controled again.
I refrence this case ,however,  we can't get any data from the provsioned device, attach my test code:
db = MeshDB("database/example_database.json")
p = Provisioner(device, db)
device.send(cmd.DevkeyAdd(db.nodes[0].unicast_address, 0, db.nodes[0].device_key))
device.send(cmd.AddrPublicationAdd(db.nodes[0].unicast_address))
cc = ConfigurationClient(db)
device.model_add(cc)
cc.publish_set(8, 0)
cc.composition_data_get()
and the test log:
E:\bluemesh\fortest\nrf5_SDK_for_Mesh_v2.2.0_src\scripts\interactive_pyaci> C:\Users\admin\AppData\Local\Programs\Python\Python38\python.exe interactive_pyaci.py -d COM4
    To control your device, use d[x], where x is the device index.
    Devices are indexed based on the order of the COM ports specified by the -d option.
    The first device, d[0], can also be accessed using device.
    Type d[x]. and hit tab to see the available methods.
Python 3.8.6 (tags/v3.8.6:db45529, Sep 23 2020, 15:52:53) [MSC v.1927 64 bit (AMD64)]
Type 'copyright', 'credits' or 'license' for more information
IPython 7.23.1 -- An enhanced Interactive Python. Type '?' for help.
In [1]:
In [2]: db = MeshDB("database/example_database.json")
   ...: p = Provisioner(device, db)
In [3]: 2021-07-02 17:32:31,468 - INFO - COM4: Success
2021-07-02 17:32:31,469 - INFO - COM4: Success
2021-07-02 17:32:31,473 - INFO - COM4: SubnetAdd: {'subnet_handle': 0}
2021-07-02 17:32:31,481 - INFO - COM4: AppkeyAdd: {'appkey_handle': 0}
2021-07-02 17:32:31,482 - INFO - COM4: AppkeyAdd: {'appkey_handle': 1}
In [3]:
In [3]: db.nodes[0].unicast_address
Out[3]: 0010
In [4]: device.send(cmd.DevkeyAdd(db.nodes[0].unicast_address, 0, db.nodes[0].device_key))
   ...: device.send(cmd.AddrPublicationAdd(db.nodes[0].unicast_address))
2021-07-02 17:32:46,728 - INFO - COM4: DevkeyAdd: {'devkey_handle': 8}
2021-07-02 17:32:46,729 - INFO - COM4: AddrPublicationAdd: {'address_handle': 0}In [5]:
In [5]:
In [5]: cc = ConfigurationClient(db)
   ...: device.model_add(cc)
   ...: cc.publish_set(8, 0)
   ...: cc.composition_data_get()
2021-07-02 17:32:56,990 - INFO - COM4: Success
In [6]:
In [6]:
In [6]:
In [6]: cc.composition_data_get()
In [7]: 2021-07-02 17:33:17,492 - INFO - COM4: Success
In [7]:
In [7]:
Could you give me some advice for realize this functionality?
Thank you in advance.
    I am afraid the IV Index Recovery procedure can only be used if the difference in IV Index is 42 or less. According to Mesh Profile specification section 3.10.5 IV Update procedure:
    "If a node in Normal Operation receives a Secure Network beacon with an IV index less than the last known IV Index or greater than the last known IV Index + 42, the Secure Network beacon shall be ignored."
    In other words, if the indexes are 0 and 287454020, then according to specification the node is instructed to ignore the beacon and not do IV Index Recovery.
    If the difference is 42 or less, then on average the procedure should start in 5 seconds (as the average time between Secure Network beacons is 10 seconds.)
    In other words: You need to find and set an appropriate IV Index manually, e.g. through Bluetooth Mesh Net State Set and Bluetooth Mesh Net State Get. I suggest looking at the implementation for those, if needing to retrieve or set the same information through other means.
    Terje
  • Hi tesc,
    Thanks for your reply.
    If we set IV index manually, the provisioner should scan Secure Network beacons and then get the newest IV index value, so, which serial API can I use to scan it?
    Oplinux
  • Hi Oplinux,
    The scanning of the Secure Network Beacon is automatically and transparently (a mesh node always scans). You don't need to call a function to scan.
    As Terje mentioned, the issue here is that the IV Index gap between local IV Index and network IV Index can't be more than 42. If it's more than 42 the node need to be reprovisioned. In this case it's a provisioner so we can think of updating it manually.
    The question is how you can catch the current network IV Index. What you need to do is to have a look at the incoming_data_received() in net_state.c. This is where the IV Index difference is checked. You can see the check for :
                if (iv_index <= (m_net_state.iv_index + NETWORK_IV_RECOVERY_LIMIT) &&
                    !m_net_state.iv_update.locked)
    where NETWORK_IV_RECOVERY_LIMIT = 42.
    So you can either remove this check for difference <42 or you can just read the network iv_index out and send it to PC. After that from the PC you can send the IV Index back to the node using SERIAL_OPCODE_CMD_MESH_NET_STATE_SET .
    Note that if you remove the check for the difference <42, you may break the qualification for Bluetooth Mesh as an end product. But for testing/developing purpose it should be fine.
  • Hung and Terje, many thanks for your detailed replies.
    I get it now, I'll try this way which you mention above.ThumbsupThumbsup
    Thanks again.
