Radio lock-up
Using 52833 it seems that sometimes the radio quits responding, ie, it is in NRF_RADIO_STATE_DISABLED state and there is
no obvious way to get it out of that state except for NVIC_SystemReset() call.
It usually happens when the radio is under stress, lots of interference and dropped packets.  In general it is a relatively rare occurrence,
somewhat hard to reproduce.  I can sometimes get it to happen in a debug setting if I take the development board and physically pinch the antenna with
my fingers firmly, and place the 2nd communicating development board a little distance away.
But it also happens from time to time in the field with our boards inside a protective casing.
We are using esb with some of our own modifications to the esb library - could we be writing a radio register at the wrong moment
or some other illegal operation that could cause the radio to lock up ?
Can the radio hardware lock up independently of software behavior, if the radio is bombarded with enough interference or errant packets ?
Thank You
Tommy
    As long as you follow the state diagram of the radio, you should not get into such a mode:
    https://infocenter.nordicsemi.com/topic/ps_nrf52833/radio.html?cp=4_1_0_5_17_4#concept_rnf_nml_4r
    You could try catching this scenario, then enter debug state to see if all the radio registers are in order, as well as the PPI channels / timers are enabled.
    If power cycling the peripheral itself (NRF_RADIO->POWER =0; wait; NRF_RADIO->POWER=1; init_radio()) does not work, it is a indication that the problem is outside of the scope of the radio itself (ie. timers or ppi channels)
    Which version of the SDK are you using?
    Håkon
  • We are using SDK 17.0.2 .
    Thank you your answer was very helpful.
    Tommy
  • Hi Tommy,
    I'm glad to hear this.
    Did you find the root cause of your issue?
    Håkon
  • Hi Håkon,
    Thank you for asking.
    Not entirely resolved.
    We actually have 2 contexts where this issue presents itself:
    1) Master transmits a packet with 1-byte payload to Slave on a periodic basis.  Slave does not respond, only receives.  Eventually the Slave's radio locks up.
    If instead the Master sends packet with 2-byte payload then the Slave's radio does not ever lock up.
    So this problem seems to be solved, though we don't know why 2-byte payload solves it.  Probably something more subtle in our handling of the radio that we have not uncovered.
    2) Master and Slave are continuously sending packets back and forth, with somewhat tight timing constraints.  Master always initiates with a small request packet, then Slave sends a larger data packet.  Our connection interval is 1.5 milliseconds.
    If there is too much interference for too long, the Master's radio will lock up.  The only thing unusual that we do is that sometimes the Master is receiving a lengthy data packet which unexpectedly spills over into the subsequent connection interval, and so we push the Master's radio from active receiving state "RX" to "RXDISABLE" to cut off the errant run-away packet.  This appears to be legal from the radio state machine diagram.
    So we are otherwise still investigating the cause of this lock-up.   Have not found anything out of the ordinary yet with regard to timers / ppi / pertinent radio registers, but we could certainly be missing something.
    How long should we wait between powering off and powering on the radio, if we resort to that measure ?
    Tommy
     One 16M cycle (62.5 ns). You can generate such a wait condition by reading any events register, (void)NRF_TIMER3->EVENTS_COMPARE[0];.
    This sound like a timing issue, do you allow the slave to process the request?
    Do you dynamically upload a ACK-payload when the slave receives a payload? If so, there's a very small window of opportunity where the ACK will actually go out on-air.
    I would strongly recommend that you always send a payload to let the slave prepare for ACK payload, then a new dummy-payload to fetch it.
     Does your buffers allow for such spills?
    Håkon
