bootloader_secure related
I am using nrf51822 / SDK v12.3 / SD 130.
I want to change the FW of the sold product to a new FW.
The bootloader address / length of the two are the same, and the secure key (*.pem) is different.
I’m trying the process(FW 1 -> FW 2-> FW 3).
 - FW 1 : FW of the sold product
 - FW 2 : hw / fw / some signature information ignore in dfu_req_handling.c  and FW 3 secure key add
 - FW 3 : FW to be changed
DFU  to FW 2 works, but it seems to show a secure key related error in the DFU to FW 3 process.
Here, I ask if there is any way to pass without referring to the secure key information.
 Thnaks.
    What is the error? Please provide the log.
    You should use the same pair of the key for the boolader and updated package.
    -Amanda H.
  • Sure, I used same pair. I'll get log and provide them.
  • I'm trying to get the log, but there's a problem with the debug mode bootloader size, etc.
    If I ask the question again, it is how to move to FW3(from FW1) through DFU.
    FW1 and FW3 differ only in *.pem / dfu_public_key.c files.
    Of course *.pem / dfu_public_key.c and package(SD+appl+bootloader) are created using nrfutil.
    Do you use nRFConnect to update with DFU? If so, is it possible to provide the log of nRFConnect?
    Are you able to update FW3 without key encryption (*.pem / dfu_public_key.c)? To make sure the issue is in key encryption.
    What is the version of nrfutil? Could you use the latest version v6.1.0? Let me know this can help or not.
    -Amanda
  • I tried to DFU from FW1 to new FW1 with different key.
    I changed *.pem / dfu_public_key.c in FW1 and made package(SD + appl + bootloader).
    I attach the log file.
    nRF Connect, 2021-07-07
    CHDL_Dfu (C9:7E:87:9F:8C:E5)
    V    16:39:05.045    Connecting to C9:7E:87:9F:8C:E5...
    D    16:39:05.045    gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D    16:39:05.231    [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I    16:39:05.231    Connected to C9:7E:87:9F:8C:E5
    D    16:39:05.237    [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    V    16:39:05.259    Discovering services...
    D    16:39:05.259    gatt.discoverServices()
    I    16:39:05.674    Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D    16:39:05.768    [Callback] Services discovered with status: 0
    I    16:39:05.768    Services discovered
    V    16:39:05.784    Generic Access (0x1800)
    - Device Name [R W] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    Generic Attribute (0x1801)
    Secure DFU Service (0xFE59)
    - DFU Packet [WNR] (8ec90002-f315-4f60-9fb8-838830daea50)
    - DFU Control Point [N W] (8ec90001-f315-4f60-9fb8-838830daea50)
       Client Characteristic Configuration (0x2902)
    I    16:39:05.850    Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
    I    16:39:06.452    Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
    V    16:39:29.247    Reading descriptor 00002902-0000-1000-8000-00805f9b34fb
    D    16:39:29.247    gatt.readDescriptor(00002902-0000-1000-8000-00805f9b34fb)
    I    16:39:29.317    Read Response received from descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 00-00
    A    16:39:29.317    "Notifications and indications disabled" received
    V    16:40:07.883    [DFU] DFU service started
    V    16:40:07.883    [DFU] Opening file...
    I    16:40:08.186    [DFU] Firmware file opened successfully
    V    16:40:08.186    [DFU] Connecting to DFU target...
    D    16:40:08.186    [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M)
    I    16:40:08.188    [DFU] Connected to C9:7E:87:9F:8C:E5
    V    16:40:08.188    [DFU] Discovering services...
    D    16:40:08.188    [DFU] gatt.discoverServices()
    I    16:40:08.189    [DFU] Services discovered
    D    16:40:08.194    [DFU] wait(1000)
    V    16:40:09.193    [DFU] Requesting new MTU...
    D    16:40:09.194    [DFU] gatt.requestMtu(517)
    I    16:40:09.242    [DFU] MTU changed to: 23
    V    16:40:09.242    [DFU] Enabling notifications for 8ec90001-f315-4f60-9fb8-838830daea50
    D    16:40:09.243    [DFU] gatt.setCharacteristicNotification(8ec90001-f315-4f60-9fb8-838830daea50, true)
    D    16:40:09.245    [DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
    I    16:40:09.302    [DFU] Data written to descr.8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-00
    V    16:40:09.303    [DFU] Notifications enabled for 8ec90001-f315-4f60-9fb8-838830daea50
    A    16:40:09.303    [DFU] Notifications enabled
    D    16:40:09.304    [DFU] wait(1000)
    V    16:40:10.305    [DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D    16:40:10.305    [DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I    16:40:10.352    [DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 06-01
    I    16:40:10.354    [DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-01-00-00-8E-00-00-00-C4-A4-5F-A0
    A    16:40:10.356    [DFU] Command object info received (Max size = 256, Offset = 142, CRC = A05FA4C4)
    A    16:40:10.357    [DFU] Received CRC match Init packet
    V    16:40:10.357    [DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D    16:40:10.357    [DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I    16:40:10.411    [DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I    16:40:10.412    [DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-0A
    E    16:40:10.414    [DFU] Remote DFU error: OPERATION FAILED
    V    16:40:10.414    [DFU] Disconnecting...
    D    16:40:10.431    [DFU] gatt.disconnect()
    I    16:40:10.431    [DFU] Disconnected
    D    16:40:10.431    [DFU] gatt.refresh() (hidden)
    D    16:40:10.431    [DFU] gatt.close()
    D    16:40:10.431    [DFU] wait(600)
    I    16:40:10.711    Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    I    16:40:10.892    Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
    I    16:40:11.492    Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
