Double pairing request with android
I am testing several phones with a specific App that I connect to my nRF52832. Some phones pair nicely but others do not pair as expected. They display two pairing requests.
- I have checked that my BLE device only sends one pairing request which is the case
- I tried increasing the PM_HANDLER_SEC_DELAY_MS and also setting it to zero but in both cases we would still get two pairing requests
- I allow repairing of already bonded peers
- As described here: https://devzone.nordicsemi.com/f/nordic-q-a/76912/double-pairing-prompt-in-android this behavior might be due to having several services and being peripheral. In my setting the nRF acts as central and connects to the phone which is in peripheral role. Then the phone exposes services as server which the nRF discovers as client. The nRF also exposes services.
What could be the reason we get two pairing requests with some android phones?
When I log the connection trace I get the following messages:
  • - The encryption operations are taking so long because I wait 10s before pressing "pair" on the phone at every pair request to see what triggers the second pair request.
    - I also tested with parameters of 30ms interval and 0 slave latency but this does not make a difference. But I will try to go down as low as 7.5ms with the interval to see if it makes a difference.
    After a test with the nRF Connect Desktop BLE Application where I also received two pairing requests with "just works" LESC bonding I now think this is standard behaviour for "Just Works" pairing on some android phones. What I also observed is that when using for example passkey entry or passkey comparison pairing method the phone also gets two pairing requests. One without any passkeys and the second one with the key comparison/entry dialogue.
    I think when I do not need to compare keys or similar I still get a dialogue, just without anything.
    But I don't know how to find a workaround from my side to prevent this
  • Hi
    I found an old case which seems to discuss the same issue, but it doesn't seem like a solution was found unfortunately.
    Most of the Android expertise is also on holiday, just to complicate it further ;)
    Tomorrow I will do some testing with the phones I have available here, trying to figure out what the difference is between phones that show this issue and those that don't. Hopefully that can give some more clues.
    Best regards
    Torbjørn
  • Ok thank you.
    You can try with the nRF Desktop App Bluetoot Low Energy Application. There just connect to a Samsung (also double request) or Pixel phone. Then bond and specify "no keyboard, no display" to use "just works" (parameters as specified here). The phone should show two pairing requests.
  • Hi
    Have you been able to reproduce the issue based on one of the standard SDK examples?
    As an example, should I be able to use the ble_app_hrs_c example on the nRF5 side, and set up the peripheral on the phone in the nRF Connect app?
    I tried this without being able to reproduce the issue, but at the moment I am testing on my own Huawei P20 Pro, which might behave differently compared to the Samsung and the Pixel you have tested with.
    Best regards
    Torbjørn
    I have tested the ble_app_hrs_c with the Samsung Galaxy A51 and the Redmi 8 which had the double pairing request problem with my nRF device.
    -> They both show the same behaviour with a double pairing request in the nRF Connect App.
    Can we therefore conclude that its a problem in the BLE stack of these phones?
