BLE NUS Central using Fanstel BWG840 gateway and 20 peripheral connections using movesense sensors and running S140 soft device
We are trying to create a network using 20 movesense sensors and BWG840 Fanstel gateway acting as the central. The gateway is running a modified ble app uart multilink code from GitHub for connecting to the sensors. While developing and testing using the setup, we came across few odd behaviors. It would be great if someone can help us in figuring out the same.
  1. If the peripherals are advertising before the gateway starts running, the gateway code crashes with a fatal error. The code hits the NRF_BREAKPOINT_COND and halts. Is this expected? Is there any workaround for this behavior?
  2. If the peripherals are being turned on one by one, the code works perfectly. We can connect to these sensors and control them as per our use case. Is there any mandatory requirement like sensors have to be turned on in a sequential manner?
  3. Do we need to make some modifications in the connection interval and timing as we increase the sensor count?
  4. When we increase the sensor count to 19 in sdk_config.h using the macros mentioned below
    // <o> NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - Maximum number of peripheral links.
    #ifndef NRF_SDH_BLE_PERIPHERAL_LINK_COUNT
    #define NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 0
    // <o> NRF_SDH_BLE_CENTRAL_LINK_COUNT - Maximum number of central links.
    #ifndef NRF_SDH_BLE_CENTRAL_LINK_COUNT
    #define NRF_SDH_BLE_CENTRAL_LINK_COUNT 19
    // <o> NRF_SDH_BLE_TOTAL_LINK_COUNT - Total link count.
    // <i> Maximum number of total concurrent connections using the default configuration.
    #ifndef NRF_SDH_BLE_TOTAL_LINK_COUNT
    #define NRF_SDH_BLE_TOTAL_LINK_COUNT 19
    Code fails with error message nrf_sdh_ble: sd_ble_enable() returned nrf_error_no_mem. But the RAM start address was modified in the linker script to the value shown in the log message. But still, this message comes? Is 18 sensors the maximum possible?
We have attached the code and images we have captured using the setup
 * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "ble_advdata.h"
#define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
#define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
BLE_NUS_C_ARRAY_DEF(m_ble_nus_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);       /**< BLE Nordic UART Service (NUS) client instances. */
NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                        /**< BLE GATT Queue instance. */
               NRF_SDH_BLE_CENTRAL_LINK_COUNT,
               NRF_BLE_GQ_QUEUE_SIZE);
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
///**@brief NUS UUID. */
//static ble_uuid_t const m_nus_uuid =
//    .uuid = BLE_UUID_NUS_SERVICE,
//    .type = NUS_SERVICE_UUID_TYPE
static char const m_target_periph_name[] = "Movesense";
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Nordic UART Service Client errors.
static void nus_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    ret = nrf_ble_scan_start(&m_scan);
    APP_ERROR_CHECK(ret);
    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    ret_code_t err_code;
  bool local_name_flag;
    switch(p_scan_evt->scan_evt_id)
	case NRF_BLE_SCAN_EVT_FILTER_MATCH:
           ble_gap_evt_adv_report_t const * p_adv_report;
           //adv. report from a device that passed the filter criteria
           p_adv_report = p_scan_evt->params.filter_match.p_adv_report;
           NRF_LOG_INFO(" filter match %d",p_adv_report);
             //TODO: parse adv report data with "Advertising data encoder" module. Ref. https://infocenter.nordicsemi.com/topic/sdk_nrf5_v17.0.2/group__ble__sdk__lib__advdata.html
           local_name_flag = ble_advdata_name_find(p_scan_evt->params.filter_match.p_adv_report->data.p_data,p_scan_evt->params.filter_match.p_adv_report->data.len, m_target_periph_name);
           if(local_name_flag)
             NRF_LOG_INFO(" Local name %s \r\n",p_scan_evt->params.filter_match.p_adv_report->data.p_data);
           local_name_flag = false;
         case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
              err_code = p_scan_evt->params.connecting_err.err_code;
         } break;
         case NRF_BLE_SCAN_EVT_CONNECTED:
              ble_gap_evt_connected_t const * p_connected =
                               p_scan_evt->params.connected.p_connected;
             NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                      p_connected->peer_addr.addr[0],
                      p_connected->peer_addr.addr[1],
                      p_connected->peer_addr.addr[2],
                      p_connected->peer_addr.addr[3],
                      p_connected->peer_addr.addr[4],
                      p_connected->peer_addr.addr[5]
         } break;
         case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
             NRF_LOG_INFO("Scan timed out.");
             scan_start();
         } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c[p_evt->conn_handle], p_evt);
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
        while (app_uart_put('\n') == NRF_ERROR_BUSY);
//    if (ECHOBACK_BLE_UART_DATA)
//        for(int c = 0; c < NRF_SDH_BLE_CENTRAL_LINK_COUNT; c++)
//            // Send data back to the peripheral.
//            do
//                ret_val = ble_nus_c_string_send(&m_ble_nus_c[c], p_data, data_len);
//                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY) && (ret_val != NRF_ERROR_INVALID_STATE))
//                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
//                    APP_ERROR_CHECK(ret_val);
//            } while (ret_val == NRF_ERROR_BUSY);
 * @details This function receives a single character from the app_uart module and appends it to
 *          a string. The string is sent over BLE when the last character received is a
 *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= (m_ble_nus_max_data_len)))
                    do
                        ret_val = ble_nus_c_string_send(&m_ble_nus_c[c], data_array, index);
                        if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                    } while (ret_val == NRF_ERROR_RESOURCES);
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
 * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
 * @brief Function for handling shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_CONNECTED:
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c[p_ble_evt->evt.gap_evt.conn_handle], p_ble_evt->evt.gap_evt.conn_handle, NULL);
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
            if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                // Resume scanning.
                scan_start();
            NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
            // Pairing not supported.
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in] event  Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_ble_nus_c[c].conn_handle,
/**@brief Function for initializing the UART. */
static void uart_init(void)
    .rx_pin_no    = NRF_GPIO_PIN_MAP(1, 1),
    .tx_pin_no    = NRF_GPIO_PIN_MAP(1, 2),
    .use_parity   = false,
    .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                     UART_RX_BUF_SIZE,
                     UART_TX_BUF_SIZE,
                     uart_event_handle,
                     APP_IRQ_PRIORITY_LOWEST,
                     err_code);
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler   = ble_nus_c_evt_handler;
    init.error_handler = nus_error_handler;
    init.p_gatt_queue  = &m_ble_gatt_queue;
        err_code = ble_nus_c_init(&m_ble_nus_c[c], &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
  bsp_event_t startup_event;
  nrf_gpio_cfg_output(NRF_GPIO_PIN_MAP(1, 0));
  nrf_gpio_cfg_output(11);
  nrf_gpio_pin_clear(NRF_GPIO_PIN_MAP(1, 0));
  nrf_gpio_pin_clear(11);
  nrf_delay_ms(300);
  nrf_gpio_pin_set(NRF_GPIO_PIN_MAP(1, 0));
  nrf_gpio_pin_set(11);
  nrf_delay_ms(300);
  nrf_delay_ms(300);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
    ble_db_discovery_init_t db_init;
    memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
    db_init.evt_handler  = db_disc_handler;
    db_init.p_gatt_queue = &m_ble_gatt_queue;
    ret_code_t err_code = ble_db_discovery_init(&db_init);
 * @details Handles any pending log operations, then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
    // Initialize.
    log_init();
    timer_init();
    uart_init();
    buttons_leds_init();
    db_discovery_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    nus_c_init();
    ble_conn_state_init();
    scan_init();
    // Start execution.
    printf("BLE UART central example started.\r\n");
    NRF_LOG_INFO("BLE UART central example started.");
    scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
  • Hi Simon,
    Sorry for the late update. As suggested by you, i made the following changes in code to check if discovery is complete, but there was no change in behavior. Please correct me if I am doing something terribly wrong.
    discovery_flag=false;
    // Resume scanning.
    scan_start();
    discovery_flag=true;
    scan_start();
    ret_code_t ret;
    if(discovery_flag==false)
  • Hi
    In the ble_nus_c.c file and the ble_nus_c_on_db_disc_evt() you should be able to get the BLE_DB_DISCOVERY_COMPLETE triggered, so I'm not sure what is happening here. Are you able to do a sniffer trace so we can see what is happening on the air here?
    Simon
