nRF52840 with SDK v17 - Application CRC check in secure bootloader always fails
My dev environment is as follows:
nrf52840 + s140 +SD7.0.1 + SDK17.0.0.9 + SES + nrfutil v6.1.0
I started my development for DFU and utilized secure buttonless DFU bootloader provided along with SDK. Things worked well. I also wrote a post build script which generated the bootloader settings hex file and then it merged all the 4 hex files viz application+soft device+bootloader+bootloader settings into one hex file for production usage. This all worked well in both debug as well as release configuration until I tried to further optimize the "Release" configuration.
For optimization, I configured the release configuration to:
- strip the debug information with gcc debug level set to none
- used app_config.h file to stop the nrf, and RTT logs
After this, the bootloader CRC check for application always fails and thus bootloader always enters into dfu. I have confirmed this with whatever possible bootloader debugging. Even after reverting the project configuration settings, I'm not able to get the bootloader calculate the CRC which is written into bootloader_settings. I have also checked that the start address and size passed to compute the CRC in bootloader is correct but still it does not match the CRC calculated by nrfutil.
Although I have very minor changes in my bootloader (compared to the one in SDK), but, I do have seen the same behavior with raw bootloader provided along with SDK.
Can someone please help me on this?
Thanks
