I'm designing my own algorithm for direction finding and for that i need IQ value as input. In NCS v1.6.0, in the locator exemple for aoa, the IQ value are store in a int8_t type in struct bt_df_per_adv_sync_iq_samples_report -> bt_hci_le_iq_sample.
However, in nrf52833 product specification chapter 6.18.12.7, IQ value are 12 bits signed. I don't understand why Nordic decide to cut 4 bit (even if it's LSB) from IQ value. There's more in hci.c, in le_df_connectionless_iq_report function, where we can see
static void le_df_connectionless_iq_report(struct pdu_data *pdu_rx,
struct node_rx_pdu *node_rx,
struct net_buf *buf)
struct bt_hci_evt_le_connectionless_iq_report *sep;
struct node_rx_iq_report *iq_report;
struct lll_sync *lll;
uint8_t samples_cnt;
int16_t iq_tmp;
int16_t rssi;
uint8_t idx;
iq_report = (struct node_rx_iq_report *)node_rx;
if (!(event_mask & BT_EVT_MASK_LE_META_EVENT) ||
!(le_event_mask & BT_EVT_MASK_LE_CONNECTIONLESS_IQ_REPORT)) {
return;
lll = iq_report->hdr.rx_ftr.param;
/* TX LL thread has higher priority than RX thread. It may happen that
* host succefully disables CTE sampling in the meantime.
* It should be verified here, to avoid reporint IQ samples after
* the functionality was disabled.
if (ull_df_sync_cfg_is_disabled_or_requested_to_disable(&lll->df_cfg)) {
/* Dropp further processing of the event. */
return;
/* If there are no IQ samples due to insufficient resources
* HCI event should inform about it by store single octet with
* special I_sample and Q_sample data.
samples_cnt = (!iq_report->sample_count ? 1 : iq_report->sample_count);
sep = meta_evt(buf, BT_HCI_EVT_LE_CONNECTIONLESS_IQ_REPORT,
(sizeof(*sep) +
(samples_cnt * sizeof(struct bt_hci_le_iq_sample))));
rssi = RSSI_DBM_TO_DECI_DBM(iq_report->hdr.rx_ftr.rssi);
sep->sync_handle = sys_cpu_to_le16(iq_report->hdr.handle);
sep->rssi = sys_cpu_to_le16(rssi);
sep->rssi_ant_id = iq_report->rssi_ant_id;
sep->cte_type = iq_report->cte_info.type;
sep->chan_idx = lll->data_chan_id;
sep->per_evt_counter = sys_cpu_to_le16(lll->event_counter);
if (sep->cte_type == BT_HCI_LE_AOA_CTE) {
sep->slot_durations = iq_report->local_slot_durations;
} else if (sep->cte_type == BT_HCI_LE_AOD_CTE_1US) {
sep->slot_durations = BT_HCI_LE_ANTENNA_SWITCHING_SLOT_1US;
} else {
sep->slot_durations = BT_HCI_LE_ANTENNA_SWITCHING_SLOT_2US;
sep->packet_status = iq_report->packet_status;
if (iq_report->packet_status == BT_HCI_LE_CTE_INSUFFICIENT_RESOURCES) {
sep->sample[0].i = BT_HCI_LE_CTE_REPORT_NO_VALID_SAMPLE;
sep->sample[0].q = BT_HCI_LE_CTE_REPORT_NO_VALID_SAMPLE;
sep->sample_count = 0;
} else {
for (idx = 0; idx < samples_cnt; ++idx) {
/*iq_tmp = IQ_SHIFT_12_TO_8_BIT(iq_report->sample[idx].i);
sep->sample[idx].i = (int8_t)iq_tmp;
iq_tmp = IQ_SHIFT_12_TO_8_BIT(iq_report->sample[idx].q);
sep->sample[idx].q = (int8_t)iq_tmp;*/
sep->sample[idx].i = iq_report->sample[idx].i;
sep->sample[idx].q = iq_report->sample[idx].q;
sep->sample_count = samples_cnt;
I comment the ligne which shift the value from 12bit to 8bit. Even in III_df_types.h, the IQ sample are define as int16_t.
I would like to understand why, maybe i'm missing something.
Thanks
