I have a question regarding diffie-hellman.
What exactly are we doing with diffie-hellman key? Do we use it to create another key? Or is it the key itself?
Thanks!
Thanks!
I assume you are referring to LE Secure Connections (LESC), which is where a Diffie–Hellman key exchange is used in Bluetooth. That is used so that the two peers can exchange their public keys with each other to generate a shared secret that no one else can know, even an attacker that has intercepted all of the communication. This in turn is used to generate a encryption key.
You can read more about LESC here, and refer to the Bluetooth specification for all details.
I know that with diffie-hellman, both sides generates a key, without sharing private keys.
After it's done - we are we doing with that key? Do we use it to generate another key?
After that - we use that shared secret key and together with both sides's addresses and rand numbers, we create the LTK?
Exactly.
Do we know the exact generation function?
Yes, see Bluetooth Core specification Vol 3 Part H, "LE Secure Connections key generation function f5".
Thanks!
Can you please tell me in which phase does authentication (passkey etc...) occur?
Phase 2, Authentication Stage 1.
If you're curious about such low-level things, please read Bluetooth Core spec (Vol 3 Part H) - the whole pairing process is explained in details.
Thanks!
Can you please give me the link for the spec?
https://www.bluetooth.com/specifications/specs/core-specification/
Wow, a new version appeared four days ago...
